I had an odd occurrence a few days ago where influxdb kept timing out. Once this happened no matter what I tried it would give a 400 error. Since I did not have much data yet I just dropped the db and deleted the influx config in iotawatt. NOTE to delete the config I had to upload the index.htm since mine just did nothing.
I have re-added a few measurements and it is updating influxdb fine now, but when i try to add a tag I get this JS error.
Uncaught TypeError: Cannot read properties of null (reading ‘setAttribute’)
at influxTagAdd ((index):2334)
at HTMLButtonElement.onclick ((index):1)
I suspect this is due to the new version of the index.htm, since I did not get this before.
These are known problems. The current ALPHA/BETA release 02_07_05 should fix all of them. Auto-update MINOR is slated to upgrade to 02_07_05 sometime next week. You can get immediate relief by switching to BETA until then.
So influxdb v1 updates stopped working last night again. Same issue in that it gets a query failed 400. Note it ran fine for about a day and a half with no changes to the system. I confirmed I can still make queries to the influxdb just fine via curl.
The above occurred with the 02_06_06 and is still occurring with 02_07_05
Adding some more info. Looks like the issue started with a HEAP issue:
12/28/21 10:05:19 historyLog: Last log entry 12/28/21 10:05:00
12/28/21 10:05:19 Updater: Auto-update is current for class MINOR.
12/28/21 10:09:41 influxDB_v1: stopped, Last post 02/06/06 01:28:16
12/28/21 10:11:49 influxDB_v1: stopped, Last post 02/06/06 01:28:16
12/28/21 10:15:45 influxDB_v1: Starting, interval:10, url:http://influxdb.home.thetank.org:8086
12/28/21 10:15:45 influxDB_v1: Start posting at 12/28/21 10:15:50
12/28/21 22:04:19 WiFi disconnected.
12/28/21 22:04:23 WiFi connected. SSID=TheTank, IP=10.x.x.x, channel=6, RSSI -85d
12/29/21 2236:18 Heap memory has degraded below safe minimum, restarting.
NOTE on wifi, I have 2 unifi APs one within about 10 feet of the iotawatt and when it connects to that AP it gets a signal of about -65db, and if it connects to the one on the top floor it is in the -72 to -77 range first time I see -85 from the far AP, note not sure why it selects the worse AP so often.
I sized down all of my long device names in influx. That did not seem to resolve the query 400 error. I then removed the tag “name: $name” since it was redundant. That seemed to get it working again.
