On “Restart”, the iotawatt unit is not longer starting services… so I can’t access the logs (for example) and I don’t see “WiFi” status. How can I reset/fix this?
Here’s the most recent restart message list… notice it stops after “HTTP server started”
1/29/23 16:52:36z Real Time Clock is running. Unix time 1675011156
1/29/23 16:52:36z Reset Reason: Power-fail restart.
1/29/23 16:52:36z ESP8266 ID: 14622785, RTC PCF8523 (68)
1/29/23 16:52:36z IoTaWatt 5.0, Firmware version 02_07_05
1/29/23 16:52:36z SPIFFS mounted.
1/29/23 08:52:36 Local time zone: -8:00, using DST/BST when in effect.
1/29/23 08:52:36 device name: IotaWatt
1/29/23 08:52:39 Connecting with WiFiManager.
1/29/23 08:52:44 HTTP server started
Here’s previous (few hours ago) Restart - showing that log and other services started OK.
1/28/23 15:35:52z Real Time Clock is running. Unix time 1674920152
1/28/23 15:35:52z Reset reason: Software/System restart
1/28/23 15:35:52z Trace: 1:2, 1:3, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:2[1], 8:2, 9:2, 1:2, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:2[2], 8:2, 9:2, 1:2, 1:3, 1:3, 1:1[2], 1:2, 9:0, 9:0, 8:2, 8:2, 1:2
1/28/23 15:35:52z ESP8266 ID: 14622785, RTC PCF8523 (68)
1/28/23 15:35:52z IoTaWatt 5.0, Firmware version 02_07_05
1/28/23 15:35:52z SPIFFS mounted.
1/28/23 07:35:52 Local time zone: -8:00, using DST/BST when in effect.
1/28/23 07:35:52 device name: IotaWatt
1/28/23 07:35:52 HTTP server started
1/28/23 08:47:26 WiFi connected. SSID=RANDOM1, IP=192.168.2.174, channel=11, RSSI -67db
1/28/23 08:47:26 MDNS responder started for hostname IotaWatt
1/28/23 08:47:26 LLMNR responder started for hostname IotaWatt
1/28/23 08:47:26 timeSync: service started.
1/28/23 09:59:01 statService: started.
1/28/23 12:18:33 Updater: service started. Auto-update class is NONE
1/28/23 12:18:33 dataLog: service started.
1/28/23 12:18:33 dataLog: Last log entry 01/28/23 06:19:40
1/28/23 12:18:34 historyLog: service started.
1/28/23 12:18:34 historyLog: Last log entry 01/28/23 05:02:00
1/29/23 07:09:50 dataLog: datalog WDT - restarting
View of the main “Status” screen - notice there’s no WiFi section and Logs are not available.
