Hi there,
I am trying to configure export to grif sensor for Home Assistant Energy page as mentiooned here
https://docs.iotawatt.com/en/master/integrators.html
but It seems my intergators page is missing those functions, I only see min and max. How can I add grid.neg?
Cheers,
Alex
I think you need to read the instructions again. It sounds like you are expecting the .neg and .pos to be in the setup of the integrator, but they are are in the setup of the output.
You need to create the integrator which can include 1 or more channels with math as its input. You then need to create an output which uses the integrator as its input.
@frogmore is right. The .pos and .neg are variants of the integrator and, once the integrator is created, will show up in the inputs list and can be incorporated in outputs.
Thank you very much @frogmore @overeasy . Of course you are right and I was need to read properly. Found and done everything now.
Cheers,
Alex
