I am having trouble finding out why I am getting a lot of null data now since I added another phase VT and CT, I have replaced the SD card, install a new Wi-Fi AP within 1 metre of the IotaWatt, paused uploading to PVoutput. Any ideas?
My setup has 3 separate off grid inverters running 3 VTs one for each inverter, also 3 separate CT one for each inverter load, has been working a charm with 2 inverters until I added the 3rd setup
message log
7/19/22 23:16:30z Trace: 8:9, 1:2, 1:3, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
7/19/22 23:16:30z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/19/22 23:16:30z IoTaWatt 5.0, Firmware version 02_07_05
7/19/22 23:16:30z SPIFFS mounted.
7/20/22 09:16:30 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 09:16:30 device name: IotaOG
7/20/22 09:16:30 HTTP server started
7/20/22 09:17:12 WiFi connected. SSID=2.4 google home assist -2G, IP=192.168.141.183, channel=1, RSSI -52db
7/20/22 09:17:12 MDNS responder started for hostname IotaOG
7/20/22 09:17:12 LLMNR responder started for hostname IotaOG
7/20/22 09:17:12 timeSync: service started.
7/20/22 09:17:12 statService: started.
7/20/22 09:17:12 Updater: service started. Auto-update class is MINOR
7/20/22 09:17:12 dataLog: service started.
7/20/22 09:17:12 dataLog: Last log entry 07/20/22 09:06:50
7/20/22 09:17:12 historyLog: service started.
7/20/22 09:17:12 historyLog: Last log entry 07/20/22 08:35:00
7/20/22 09:17:14 Updater: Auto-update is current for class MINOR.
7/20/22 09:17:20 PVoutput: started
7/20/22 09:17:22 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 09:17:23 PVoutput: Reload status beginning 07/19/22 13:15:00
7/20/22 09:23:55 dataLog: datalog WDT - restarting
7/19/22 23:23:56z Real Time Clock is running. Unix time 1658273036
7/19/22 23:23:56z Reset reason: Software/System restart
7/19/22 23:23:56z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:2[3], 8:2[14], 9:2, 1:2, 1:3, 1:3, 1:1[3], 1:2[13], 9:0[13], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2
7/19/22 23:23:56z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/19/22 23:23:56z IoTaWatt 5.0, Firmware version 02_07_05
7/19/22 23:23:56z SPIFFS mounted.
7/20/22 09:23:56 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 09:23:56 device name: IotaOG
7/20/22 09:23:56 HTTP server started
7/20/22 09:23:57 timeSync: service started.
7/20/22 09:23:57 statService: started.
7/20/22 09:23:57 dataLog: service started.
7/20/22 09:23:57 dataLog: Last log entry 07/20/22 09:18:55
7/20/22 09:24:00 historyLog: service started.
7/20/22 09:24:00 historyLog: Last log entry 07/20/22 09:18:00
7/20/22 09:28:30 Disconnect command received.
7/20/22 09:29:00 dataLog: datalog WDT - restarting
7/19/22 23:29:01z Real Time Clock is running. Unix time 1658273341
7/19/22 23:29:01z Reset reason: Software/System restart
7/19/22 23:29:01z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:2[3], 8:2[14], 9:2, 1:2, 1:3, 1:3, 1:1[3], 1:2[13], 9:0[13], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2
7/19/22 23:29:01z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/19/22 23:29:01z IoTaWatt 5.0, Firmware version 02_07_05
7/19/22 23:29:01z SPIFFS mounted.
7/20/22 09:29:01 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 09:29:01 device name: IotaOG
7/20/22 09:29:01 HTTP server started
7/19/22 23:30:55z Real Time Clock is running. Unix time 1658273455
7/19/22 23:30:55z Reset Reason: Power-fail restart.
7/19/22 23:30:55z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/19/22 23:30:55z IoTaWatt 5.0, Firmware version 02_07_05
7/19/22 23:30:55z SPIFFS mounted.
7/20/22 09:30:55 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 09:30:55 device name: IotaOG
7/20/22 09:30:58 Connecting with WiFiManager.
7/20/22 09:32:18 HTTP server started
7/20/22 09:32:18 WiFi connected. SSID=Laundry AP, IP=192.168.1.109, channel=6, RSSI -42db
7/20/22 09:32:18 MDNS responder started for hostname IotaOG
7/20/22 09:32:18 LLMNR responder started for hostname IotaOG
7/20/22 09:33:40 timeSync: service started.
7/20/22 09:33:40 statService: started.
7/20/22 09:33:40 Updater: service started. Auto-update class is MINOR
7/20/22 09:33:41 dataLog: service started.
7/20/22 09:33:41 dataLog: Last log entry 07/20/22 09:24:00
7/20/22 09:33:45 historyLog: service started.
7/20/22 09:33:45 historyLog: Last log entry 07/20/22 09:18:00
7/20/22 09:33:45 PVoutput: started
7/20/22 09:35:59 Updater: Auto-update is current for class MINOR.
7/20/22 09:36:00 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 09:36:00 PVoutput: Reload status beginning 07/19/22 13:15:00
7/20/22 10:03:01 Disconnect command received.
7/20/22 00:03:34z Real Time Clock is running. Unix time 1658275414
7/20/22 00:03:34z Reset Reason: Power-fail restart.
7/20/22 00:03:34z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/20/22 00:03:34z IoTaWatt 5.0, Firmware version 02_07_05
7/20/22 00:03:34z SPIFFS mounted.
7/20/22 10:03:34 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 10:03:34 device name: IotaOG
7/20/22 10:03:37 Connecting with WiFiManager.
7/20/22 00:04:50z Real Time Clock is running. Unix time 1658275490
7/20/22 00:04:50z Reset reason: Software/System restart
7/20/22 00:04:50z Trace: 34:5, 34:6[5], 34:10[1], 34:30, 34:10[2], 34:30, 34:10[2], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:5, 34:5, 34:5, 34:6[1], 34:10, 22:205, 22:206, 22:207, 11:55, 11:70
7/20/22 00:04:50z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/20/22 00:04:50z IoTaWatt 5.0, Firmware version 02_07_05
7/20/22 00:04:50z SPIFFS mounted.
7/20/22 10:04:50 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 10:04:50 device name: IotaOG
7/20/22 10:04:50 HTTP server started
7/20/22 00:05:27z Real Time Clock is running. Unix time 1658275527
7/20/22 00:05:27z Reset Reason: Power-fail restart.
7/20/22 00:05:27z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/20/22 00:05:27z IoTaWatt 5.0, Firmware version 02_07_05
7/20/22 00:05:27z SPIFFS mounted.
7/20/22 10:05:27 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 10:05:27 device name: IotaOG
7/20/22 10:05:30 Connecting with WiFiManager.
7/20/22 10:06:56 HTTP server started
7/20/22 10:07:30 WiFi connected. SSID=Laundry AP, IP=192.168.1.109, channel=6, RSSI -51db
7/20/22 10:07:30 MDNS responder started for hostname IotaOG
7/20/22 10:07:30 LLMNR responder started for hostname IotaOG
7/20/22 10:07:30 timeSync: service started.
7/20/22 10:07:31 statService: started.
7/20/22 10:07:31 Updater: service started. Auto-update class is MINOR
7/20/22 10:07:31 dataLog: service started.
7/20/22 10:07:31 dataLog: Last log entry 07/20/22 10:02:35
7/20/22 10:07:32 historyLog: service started.
7/20/22 10:07:32 historyLog: Last log entry 07/20/22 10:02:00
7/20/22 10:07:32 PVoutput: started
7/20/22 10:07:34 Updater: Auto-update is current for class MINOR.
7/20/22 10:07:34 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 10:07:35 PVoutput: Reload status beginning 07/19/22 13:15:00
7/20/22 10:13:37 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 10:13:37 PVoutput: Reload status beginning 07/19/22 13:15:00
7/20/22 10:14:00 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 10:14:01 PVoutput: Reload status beginning 07/19/22 13:15:00
7/20/22 10:15:40 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 10:15:40 PVoutput: Reload status beginning 07/19/22 13:15:00
7/20/22 10:51:52 Restart command received.
7/20/22 00:51:53z Real Time Clock is running. Unix time 1658278313
7/20/22 00:51:53z Reset reason: Software/System restart
7/20/22 00:51:53z Trace: 9:0[13], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1[13], 1:2[14], 9:0[14], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:2, 10:3
7/20/22 00:51:53z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/20/22 00:51:53z IoTaWatt 5.0, Firmware version 02_07_05
7/20/22 00:51:53z SPIFFS mounted.
7/20/22 10:51:53 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 10:51:53 device name: IotaOG
7/20/22 10:51:53 HTTP server started
7/20/22 10:51:53 timeSync: service started.
7/20/22 10:51:53 statService: started.
7/20/22 10:51:54 dataLog: service started.
7/20/22 10:51:54 dataLog: Last log entry 07/20/22 10:49:30
7/20/22 10:53:45 Restart command received.
7/20/22 00:53:47z Real Time Clock is running. Unix time 1658278427
7/20/22 00:53:47z Reset reason: Software/System restart
7/20/22 00:53:47z Trace: 9:0[13], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1[13], 1:2[14], 9:0[14], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:2, 10:3
7/20/22 00:53:47z ESP8266 ID: 16309962, RTC PCF8523 (68)
7/20/22 00:53:47z IoTaWatt 5.0, Firmware version 02_07_05
7/20/22 00:53:47z SPIFFS mounted.
7/20/22 10:53:47 Local time zone: +10:00, using DST/BST when in effect.
7/20/22 10:53:47 device name: IotaOG
7/20/22 10:53:47 HTTP server started
7/20/22 10:54:10 timeSync: service started.
7/20/22 10:54:10 statService: started.
7/20/22 10:54:10 Updater: service started. Auto-update class is MINOR
7/20/22 10:54:10 dataLog: service started.
7/20/22 10:54:10 dataLog: Last log entry 07/20/22 10:51:05
7/20/22 10:54:12 historyLog: service started.
7/20/22 10:54:12 historyLog: Last log entry 07/20/22 10:49:00
7/20/22 10:54:12 WiFi connected. SSID=Laundry AP, IP=192.168.1.109, channel=6, RSSI -50db
7/20/22 10:54:12 MDNS responder started for hostname IotaOG
7/20/22 10:54:12 LLMNR responder started for hostname IotaOG
7/20/22 10:54:12 PVoutput: started
7/20/22 10:54:13 Updater: Auto-update is current for class MINOR.
7/20/22 10:54:13 PVoutput: System LTO Off Grid, interval 5, donator mode
7/20/22 10:54:14 PVoutput: Reload status beginning 07/19/22 13:15:00
CSV Data from graph over 10 mins
2022-07-20 11:17:45, null, null
2022-07-20 11:17:50, null, null
2022-07-20 11:17:55, null, null
2022-07-20 11:18:00, null, null
2022-07-20 11:18:05, null, null
2022-07-20 11:18:10, null, null
2022-07-20 11:18:15, null, null
2022-07-20 11:18:20, null, null
2022-07-20 11:18:25, null, null
2022-07-20 11:18:30, null, null
2022-07-20 11:18:35, null, null
2022-07-20 11:18:40, null, null
2022-07-20 11:18:45, null, null
2022-07-20 11:18:50, null, null
2022-07-20 11:18:55, null, null
2022-07-20 11:19:00, null, null
2022-07-20 11:19:05, null, null
2022-07-20 11:19:10, null, null
2022-07-20 11:19:15, null, null
2022-07-20 11:19:20, null, null
2022-07-20 11:19:25, null, null
2022-07-20 11:19:30, null, null
2022-07-20 11:19:35, null, null
2022-07-20 11:19:40, 55.3, 266.3
2022-07-20 11:19:45, null, null
2022-07-20 11:19:50, null, null
2022-07-20 11:19:55, null, null
2022-07-20 11:20:00, 55.4, 288.6
2022-07-20 11:20:05, 55.7, 288.6
2022-07-20 11:20:10, null, null
2022-07-20 11:20:15, null, null
2022-07-20 11:20:20, null, null
2022-07-20 11:20:25, null, null
2022-07-20 11:20:30, null, null
2022-07-20 11:20:35, null, null
2022-07-20 11:20:40, null, null
2022-07-20 11:20:45, null, null
2022-07-20 11:20:50, null, null
2022-07-20 11:20:55, null, null
2022-07-20 11:21:00, null, null
2022-07-20 11:21:05, null, null
2022-07-20 11:21:10, null, null
2022-07-20 11:21:15, null, null
2022-07-20 11:21:20, null, null
2022-07-20 11:21:25, null, null
2022-07-20 11:21:30, null, null
2022-07-20 11:21:35, null, null
2022-07-20 11:21:40, null, null
2022-07-20 11:21:45, null, null
2022-07-20 11:21:50, null, null
2022-07-20 11:21:55, null, null
2022-07-20 11:22:00, null, null
2022-07-20 11:22:05, null, null
2022-07-20 11:22:10, null, null
2022-07-20 11:22:15, null, null
2022-07-20 11:22:20, null, null
2022-07-20 11:22:25, null, null
2022-07-20 11:22:30, null, null
2022-07-20 11:22:35, null, null
2022-07-20 11:22:40, null, null
2022-07-20 11:22:45, null, null
2022-07-20 11:22:50, null, null
2022-07-20 11:22:55, null, null
2022-07-20 11:23:00, null, null
2022-07-20 11:23:05, null, null
2022-07-20 11:23:10, null, null
2022-07-20 11:23:15, null, null
2022-07-20 11:23:20, null, null
2022-07-20 11:23:25, null, null
2022-07-20 11:23:30, null, null
2022-07-20 11:23:35, null, null
2022-07-20 11:23:40, null, null
2022-07-20 11:23:45, null, null
2022-07-20 11:23:50, null, null
2022-07-20 11:23:55, null, null
2022-07-20 11:24:00, null, null
2022-07-20 11:24:05, null, null
2022-07-20 11:24:10, null, null
2022-07-20 11:24:15, null, null
2022-07-20 11:24:20, null, null
2022-07-20 11:24:25, null, null
2022-07-20 11:24:30, null, null
2022-07-20 11:24:35, null, null
2022-07-20 11:24:40, null, null
2022-07-20 11:24:45, null, null
2022-07-20 11:24:50, null, null
2022-07-20 11:24:55, null, null
2022-07-20 11:25:00, null, null
2022-07-20 11:25:05, null, null
2022-07-20 11:25:10, null, null
2022-07-20 11:25:15, null, null
2022-07-20 11:25:20, null, null
2022-07-20 11:25:25, null, null
2022-07-20 11:25:30, null, null
2022-07-20 11:25:35, null, null
2022-07-20 11:25:40, null, null
2022-07-20 11:25:45, null, null
2022-07-20 11:25:50, null, null
2022-07-20 11:25:55, null, null
2022-07-20 11:26:00, null, null
2022-07-20 11:26:05, null, null
2022-07-20 11:26:10, null, null
2022-07-20 11:26:15, null, null
2022-07-20 11:26:20, null, null
2022-07-20 11:26:25, null, null
2022-07-20 11:26:30, null, null
2022-07-20 11:26:35, 55.4, 187.9
2022-07-20 11:26:40, null, null
2022-07-20 11:26:45, null, null
2022-07-20 11:26:50, null, null
2022-07-20 11:26:55, null, null
2022-07-20 11:27:00, null, null
2022-07-20 11:27:05, null, null
2022-07-20 11:27:10, null, null
2022-07-20 11:27:15, null, null
2022-07-20 11:27:20, null, null
2022-07-20 11:27:25, null, null
2022-07-20 11:27:30, null, null
2022-07-20 11:27:35, null, null
2022-07-20 11:27:40, null, null
