Here’s the terminal capture. There’s nothing here that’s obvious to me. I can pull the SD card if necessary.
The last three lines showed up while I was trying to access the device’s web server from another device.
Thanks!
SPI started.
6/08/20 13:31:37z Real Time Clock is running. Unix time 1591623097
6/08/20 13:31:37z Reset reason: External System
6/08/20 13:31:37z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4
6/08/20 13:31:37z ESP8266 ChipID: 2529712
6/08/20 13:31:37z IoTaWatt 5.0, Firmware version 02_05_08
6/08/20 13:31:37z SPIFFS mounted.
6/08/20 13:31:37z Local time zone: +0:00
6/08/20 13:31:37z device name: IotaWatt
6/08/20 13:31:37z HTTP server started
6/08/20 13:31:37z timeSync: service started.
6/08/20 13:31:37z statService: started.
6/08/20 13:31:38z dataLog: service started.
6/08/20 13:31:39z dataLog: Last log entry 06/08/20 13:31:35
6/08/20 13:31:39z historyLog: service started.
6/08/20 13:31:40z historyLog: Last log entry 06/08/20 13:31:00
6/08/20 13:31:43z Updater: service started. Auto-update class is MINOR
6/08/20 13:31:43z WiFi connected. SSID=Valhala-N, IP=192.168.0.120, channel=4, RSSI -83db
6/08/20 13:31:43z MDNS responder started for hostname IotaWatt
6/08/20 13:31:43z LLMNR responder started for hostname IotaWatt
6/08/20 13:31:44z Updater: Auto-update is current for class MINOR.
Server: sent less data than expected. file index.htm, sent 2920, expected 108633
Server: sent less data than expected. file index.htm, sent 4380, expected 108633
Server: sent less data than expected. file cnfstyle.css, sent 2920, expected 6075
