Reason it’s a pain is that i don’t want to measure at the main. I want to measure my usage outside the solar feed (2 systems)
I could probably do it with an extra two clamps, and set the iota to add the two clamps together)
But it’s too late now. And space woupd be an issue to fit two more clamps.
Which size CT clamps did you use? My setup looks similar to yours - 3 phase on C63 breakers. I ordered the 50A 10mm clamps and haven’t had my electrician try the install yet. I’m wondering if these are going to fit or if I should have gotten the next size up clamps.
