Here is the log that you posted:
1/02/22 16:36:28 WiFi disconnected.
1/02/22 16:43:19 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -82db
1/02/22 16:49:34 WiFi disconnected.
1/03/22 01:12:20z Real Time Clock is running. Unix time 1641172340
1/03/22 01:12:20z Reset Reason: Power-fail restart.
1/03/22 01:12:20z ESP8266 ID: 16309911, RTC PCF8523
1/03/22 01:12:20z IoTaWatt 5.0, Firmware version 02_06_06
1/03/22 01:12:20z SPIFFS mounted.
1/02/22 17:12:21 Local time zone: -8:00
1/02/22 17:12:21 device name: IotaWatt
1/02/22 17:12:24 Connecting with WiFiManager.
1/02/22 17:14:36 Did not connect after power-fail. Restarting to reset WiFi.
1/03/22 01:14:37z Real Time Clock is running. Unix time 1641172477
1/03/22 01:14:37z Reset reason: Software/System restart
1/03/22 01:14:37z Trace: 0:0, 0:0, 11:0, 11:4, 11:5, 11:5, 11:10, 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:31, 11:30, 11:35, 11:40, 11:45, 11:70
1/03/22 01:14:37z ESP8266 ID: 16309911, RTC PCF8523
1/03/22 01:14:37z IoTaWatt 5.0, Firmware version 02_06_06
1/03/22 01:14:37z SPIFFS mounted.
1/02/22 17:14:37 Local time zone: -8:00
1/02/22 17:14:37 device name: IotaWatt
1/02/22 17:14:37 HTTP server started
1/02/22 17:14:37 timeSync: service started.
1/02/22 17:14:37 statService: started.
1/02/22 17:14:37 dataLog: service started.
1/02/22 17:14:37 dataLog: Last log entry 01/02/22 17:12:10
1/02/22 17:14:42 historyLog: service started.
1/02/22 17:14:42 historyLog: Last log entry 01/02/22 17:12:00
1/02/22 17:19:59 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -88db
1/02/22 17:19:59 MDNS responder started for hostname IotaWatt
1/02/22 17:19:59 LLMNR responder started for hostname IotaWatt
1/02/22 17:19:59 Updater: service started. Auto-update class is MAJOR
1/02/22 17:21:10 WiFi disconnected.
1/02/22 17:54:09 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -90db
1/02/22 17:55:14 WiFi disconnected.
1/02/22 18:16:52 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/02/22 18:17:59 WiFi disconnected.
1/02/22 18:22:14 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -87db
1/02/22 18:23:19 WiFi disconnected.
1/02/22 18:30:36 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -91db
1/02/22 18:31:44 WiFi disconnected.
1/02/22 18:38:48 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/02/22 18:40:11 WiFi disconnected.
1/02/22 18:51:30 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/02/22 18:52:47 WiFi disconnected.
1/02/22 18:58:07 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -88db
1/02/22 19:03:38 WiFi disconnected.
1/02/22 19:11:16 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -90db
1/02/22 19:12:15 WiFi disconnected.
1/02/22 19:26:07 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -89db
1/02/22 19:27:19 WiFi disconnected.
1/02/22 19:42:09 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 19:50:32 WiFi disconnected.
1/02/22 20:11:46 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/02/22 20:12:54 WiFi disconnected.
1/02/22 20:23:45 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -87db
1/02/22 20:24:58 WiFi disconnected.
1/02/22 20:36:30 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -87db
1/02/22 20:40:59 WiFi disconnected.
1/02/22 20:46:32 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/02/22 21:03:08 WiFi disconnected.
1/02/22 21:07:57 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 21:13:10 WiFi disconnected.
1/02/22 21:17:28 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 21:27:24 WiFi disconnected.
1/02/22 21:33:44 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -87db
1/02/22 21:39:08 WiFi disconnected.
1/02/22 21:43:50 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -87db
1/02/22 21:45:19 WiFi disconnected.
1/02/22 21:50:25 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/02/22 22:00:54 WiFi disconnected.
1/02/22 22:06:32 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/02/22 22:07:43 WiFi disconnected.
1/02/22 22:19:00 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 22:27:37 WiFi disconnected.
1/02/22 22:39:36 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/02/22 22:41:32 WiFi disconnected.
1/02/22 22:48:11 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 22:50:07 WiFi disconnected.
1/02/22 22:55:44 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 22:56:12 WiFi disconnected.
1/02/22 23:03:14 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/02/22 23:05:43 WiFi disconnected.
1/02/22 23:11:54 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/02/22 23:18:50 WiFi disconnected.
1/02/22 23:29:25 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/02/22 23:41:21 WiFi disconnected.
1/02/22 23:54:25 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/02/22 23:54:54 WiFi disconnected.
1/03/22 00:14:09 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 00:15:38 WiFi disconnected.
1/03/22 00:24:20 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 00:28:49 WiFi disconnected.
1/03/22 00:32:57 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -83db
1/03/22 00:34:26 WiFi disconnected.
1/03/22 00:39:35 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -83db
1/03/22 00:42:04 WiFi disconnected.
1/03/22 00:46:36 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -83db
1/03/22 00:54:32 WiFi disconnected.
1/03/22 01:01:51 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -83db
1/03/22 01:03:20 WiFi disconnected.
1/03/22 01:07:36 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 01:11:05 WiFi disconnected.
1/03/22 01:23:42 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -86db
1/03/22 01:28:11 WiFi disconnected.
1/03/22 01:32:51 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -85db
1/03/22 01:37:47 WiFi disconnected.
1/03/22 01:48:04 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 01:53:33 WiFi disconnected.
1/03/22 01:59:31 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 02:07:53 WiFi disconnected.
1/03/22 02:12:41 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 02:15:10 WiFi disconnected.
1/03/22 02:23:43 WiFi connected. SSID=1535, IP=169.254.152.222, channel=1, RSSI -84db
1/03/22 02:23:57 WiFi disconnected.
1/03/22 02:24:56 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -76db
1/03/22 02:25:06 Updater: Invalid response from server. HTTPcode: -4
1/03/22 02:30:08 Updater: Auto-update is current for class MAJOR.
1/03/22 06:33:24 WiFi disconnected.
1/03/22 06:38:17 WiFi connected. SSID=1535, IP=169.254.152.222, channel=11, RSSI -74db
1/03/22 06:49:35 WiFi disconnected.
1/03/22 06:58:13 WiFi connected. SSID=1535, IP=169.254.152.222, channel=11, RSSI -73db
1/03/22 06:59:55 WiFi disconnected.
1/03/22 07:04:24 WiFi connected. SSID=1535, IP=169.254.152.222, channel=11, RSSI -73db
1/03/22 07:08:03 WiFi disconnected.
1/03/22 07:08:37 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -73db
1/03/22 07:09:41 WiFi disconnected.
1/03/22 07:28:44 WiFi connected. SSID=1535, IP=169.254.152.222, channel=11, RSSI -73db
1/03/22 07:30:32 WiFi disconnected.
1/03/22 07:36:21 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -70db
1/03/22 08:36:48 WiFi disconnected.
1/03/22 08:36:59 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -69db
1/03/22 13:20:08 WiFi disconnected.
1/03/22 13:20:09 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -70db
1/03/22 13:35:50 WiFi disconnected.
1/03/22 13:36:53 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -72db
1/03/22 17:37:26 Updater: update tables from 0.0.4 to 0.0.5
1/03/22 18:37:32 Updater: update tables from 0.0.4 to 0.0.5
1/03/22 19:37:38 Updater: update tables from 0.0.4 to 0.0.5
1/03/22 20:25:25 WiFi disconnected.
1/03/22 20:30:56 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -73db
1/03/22 20:36:24 WiFi disconnected.
1/03/22 20:43:23 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -71db
1/03/22 20:43:24 Updater: update tables from 0.0.4 to 0.0.5
1/03/22 20:49:09 WiFi disconnected.
1/03/22 20:50:37 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -77db
1/03/22 21:01:04 WiFi disconnected.
1/03/22 21:02:10 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -77db
1/03/22 21:33:09 WiFi disconnected.
1/03/22 21:33:13 WiFi connected. SSID=1535, IP=192.168.86.46, channel=11, RSSI -74db
1/03/22 21:43:30 Updater: update tables from 0.0.4 to 0.0.5
1/03/22 22:43:36 Updater: update tables from 0.0.4 to 0.0.5
1/03/22 23:43:46 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 00:43:52 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 01:43:58 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 02:44:04 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 03:44:10 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 04:44:16 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 05:44:22 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 06:44:28 Updater: update tables from 0.0.4 to 0.0.5
1/04/22 07:44:34 Updater: update tables from 0.0.4 to 0.0.5
I don’t have any time reference for when your problems started, but notice that the IP assigned to the IoTaWatt sometimes is 169.254.152.222 and sometimes is 192.168.86.46. The former seems to be associated a problem where the connecting device cannot communicate with a DHCP service to assign an IP (among other things). You would not be able to communicate with the IoTaWatt if it doesn’t have an IP that is in your local subnet. When you get assigned 192.168.86.46, you are probably in the local subnet and should be able to communicate.
This behavior seems to come on and go away, possibly something with your router, or possibly something with your environment. By that I mean that there could be something that is also using the 2.4GHz band and interfering with the connection. It could be a lot of metal ductwork interfering, it could be some IOT devices gone wild, I don’t know.
In terms of trying things:
You can try accessing using the IP address 192.168.86.46, which may work better when the router has assigned a valid subnet IP address.
You could try starting a different router and connecting both the IoTaWatt and your browser device to it to see if it communicates.
Do you have a picture of the IoTaWatt in its surroundings and the ceiling that separates it from the router?
