I was able to recover the config.txt as once in a few dozen times the PC could read the card. However, I am unable to update the config on the new card. Now that I’ve installed the new SD card it seems that I cannot delete, upload/overwrite, edit, save or do ANYTHING to modify the config.txt unless I use the web UI.
Is the ONLY way to change the config.txt directly to take out the SD card and do so on a computer?
If I try to use the ACE editor I get this when trying to save ERROR[403]:
I did all that but my problem surfaced when I wanted to edit the config.txt. Turned out it was impossible. Cannot recover an existing config unless you remove the card and copy it.
