Hi,
I have just installed my new IotaWatt V5 Firmware version 02_05_12 device. Unfortunately, I am having severe issues with the wi-fi constantly dropping – connecting – disconnecting – connecting – disconnecting etc. Occasionally the system will stay connected for maybe 10 minutes then drops and constantly tries to re-connect then drops etc.
I have enclosed the IotaWatt log for reference:-
START
4/04/21 15:19:38z ESP8266 ChipID: 12345678
4/04/21 15:19:38z IoTaWatt 5.0, Firmware version 02_05_12
4/04/21 15:19:38z SPIFFS mounted.
4/04/21 15:19:38z Local time zone: +0:00
4/04/21 15:19:38z device name: IotaWatt
4/04/21 15:19:38z HTTP server started
4/04/21 15:19:38z timeSync: service started.
4/04/21 15:19:38z statService: started.
4/04/21 15:19:38z dataLog: service started.
4/04/21 15:19:38z dataLog: Last log entry 04/04/21 14:15:15
4/04/21 15:19:38z historyLog: service started.
4/04/21 15:19:38z historyLog: Last log entry 04/04/21 14:15:00
4/04/21 15:22:17z Real Time Clock is running. Unix time 1617549737
4/04/21 15:22:17z Power failure detected.
4/04/21 15:22:17z Reset reason: Power on
4/04/21 15:22:17z ESP8266 ChipID: 12345678
4/04/21 15:22:17z IoTaWatt 5.0, Firmware version 02_05_12
4/04/21 15:22:17z SPIFFS mounted.
4/04/21 15:22:17z Local time zone: +0:00
4/04/21 15:22:17z device name: IotaWatt
4/04/21 15:22:20z Connecting with WiFiManager.
4/04/21 15:27:56z HTTP server started
4/04/21 15:27:56z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/04/21 15:27:56z MDNS responder started for hostname IotaWatt
4/04/21 15:27:56z LLMNR responder started for hostname IotaWatt
4/04/21 15:27:57z timeSync: service started.
4/04/21 15:27:57z statService: started.
4/04/21 15:27:57z Updater: service started. Auto-update class is MINOR
4/04/21 15:27:57z dataLog: service started.
4/04/21 15:27:57z dataLog: Last log entry 04/04/21 15:22:05
4/04/21 15:27:57z historyLog: service started.
4/04/21 15:27:57z historyLog: Last log entry 04/04/21 15:22:00
4/04/21 15:27:59z Updater: Auto-update is current for class MINOR.
4/04/21 15:33:26z WiFi disconnected.
4/04/21 15:33:28z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/05/21 04:00:10z WiFi disconnected.
4/05/21 04:00:35z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/05/21 04:39:58z WiFi disconnected.
4/05/21 04:40:01z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/05/21 05:45:15z WiFi disconnected.
4/05/21 05:45:16z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 06:26:51z WiFi disconnected.
4/05/21 06:26:52z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -75db
4/05/21 06:34:25z WiFi disconnected.
4/05/21 06:34:26z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 06:39:46z WiFi disconnected.
4/05/21 06:39:47z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/05/21 09:52:41z WiFi disconnected.
4/05/21 09:52:42z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/05/21 09:57:57z WiFi disconnected.
4/05/21 09:57:58z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/05/21 10:27:06z WiFi disconnected.
4/05/21 10:27:08z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 11:05:42z WiFi disconnected.
4/05/21 11:05:43z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 14:05:57z WiFi disconnected.
4/05/21 14:05:58z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -79db
4/05/21 14:11:10z WiFi disconnected.
4/05/21 14:11:11z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -79db
4/05/21 22:07:28z WiFi disconnected.
4/05/21 22:07:29z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 22:12:43z WiFi disconnected.
4/05/21 22:12:44z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 22:17:54z WiFi disconnected.
4/05/21 22:17:55z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/05/21 22:23:23z WiFi disconnected.
4/05/21 22:23:24z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/05/21 22:36:05z WiFi disconnected.
4/05/21 22:36:06z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/05/21 22:41:28z WiFi disconnected.
4/05/21 22:41:29z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/05/21 22:46:52z WiFi disconnected.
4/05/21 22:46:53z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/05/21 22:52:10z WiFi disconnected.
4/05/21 22:52:11z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 00:36:24z WiFi disconnected.
4/06/21 00:36:25z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 00:41:49z WiFi disconnected.
4/06/21 00:41:50z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 00:47:07z WiFi disconnected.
4/06/21 00:47:08z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 01:27:14z WiFi disconnected.
4/06/21 01:27:15z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 01:52:20z WiFi disconnected.
4/06/21 01:52:21z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -84db
4/06/21 03:05:52z WiFi disconnected.
4/06/21 03:05:55z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 04:05:42z WiFi disconnected.
4/06/21 04:05:43z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 04:11:10z WiFi disconnected.
4/06/21 04:11:11z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 04:16:37z WiFi disconnected.
4/06/21 04:16:38z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 04:22:03z WiFi disconnected.
4/06/21 04:22:04z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 04:36:50z WiFi disconnected.
4/06/21 04:36:51z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 04:58:07z WiFi disconnected.
4/06/21 04:58:09z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -75db
4/06/21 05:05:59z WiFi disconnected.
4/06/21 05:06:02z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 06:05:40z WiFi disconnected.
4/06/21 06:05:41z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 06:11:06z WiFi disconnected.
4/06/21 06:11:08z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 06:42:40z WiFi disconnected.
4/06/21 06:42:41z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 06:47:50z WiFi disconnected.
4/06/21 06:47:51z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 08:05:49z WiFi disconnected.
4/06/21 08:05:50z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 08:16:33z WiFi disconnected.
4/06/21 08:16:34z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -77db
4/06/21 08:21:44z WiFi disconnected.
4/06/21 08:21:45z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 08:27:10z WiFi disconnected.
4/06/21 08:27:11z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 08:37:11z WiFi disconnected.
4/06/21 08:37:14z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -76db
4/06/21 08:42:33z WiFi disconnected.
4/06/21 08:42:36z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -74db
4/06/21 10:22:23z WiFi disconnected.
4/06/21 10:22:24z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/06/21 10:27:38z WiFi disconnected.
4/06/21 10:27:39z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.144, channel=6, RSSI -78db
4/06/21 10:43:19z WiFi disconnected.
4/06/21 10:43:45z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=6, RSSI -77db
4/06/21 10:48:06z Restart command received.
4/06/21 09:48:08z Real Time Clock is running. Unix time 1617702488
4/06/21 09:48:08z Reset reason: Software/System restart
4/06/21 09:48:08z Trace: 1:4, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
4/06/21 09:48:08z ESP8266 ChipID: 12345678
4/06/21 09:48:08z IoTaWatt 5.0, Firmware version 02_05_12
4/06/21 09:48:08z SPIFFS mounted.
4/06/21 10:48:08z Local time zone: +0:00
4/06/21 10:48:08z Using Daylight Saving Time (BST) when in effect.
4/06/21 10:48:08z device name: IotaWatt
4/06/21 10:48:08z HTTP server started
4/06/21 10:48:08z timeSync: service started.
4/06/21 10:48:08z statService: started.
4/06/21 10:48:09z dataLog: service started.
4/06/21 10:48:09z dataLog: Last log entry 04/06/21 10:48:05
4/06/21 10:48:12z Updater: service started. Auto-update class is MINOR
4/06/21 10:48:13z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=6, RSSI -74db
4/06/21 10:48:13z MDNS responder started for hostname IotaWatt
4/06/21 10:48:13z LLMNR responder started for hostname IotaWatt
4/06/21 10:48:13z Updater: Auto-update is current for class MINOR.
4/06/21 10:49:08z historyLog: service started.
4/06/21 10:49:08z historyLog: Last log entry 04/06/21 10:48:00
4/06/21 11:09:35z WiFi disconnected.
4/06/21 11:09:37z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=6, RSSI -77db
4/06/21 11:23:19z WiFi disconnected.
4/06/21 11:23:32z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -79db
4/06/21 13:19:12z WiFi disconnected.
4/06/21 13:19:13z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -80db
4/06/21 13:28:41z WiFi disconnected.
4/06/21 13:28:42z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -83db
4/06/21 13:44:21z WiFi disconnected.
4/06/21 13:44:22z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -81db
4/06/21 14:03:43z WiFi disconnected.
4/06/21 14:03:44z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -82db
4/06/21 14:19:10z WiFi disconnected.
4/06/21 14:19:11z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -84db
4/06/21 14:28:48z WiFi disconnected.
4/06/21 14:28:50z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -83db
4/06/21 15:28:33z WiFi disconnected.
4/06/21 15:28:34z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -82db
4/06/21 16:21:41z WiFi disconnected.
4/06/21 16:21:42z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -80db
4/06/21 16:46:44z WiFi disconnected.
4/06/21 16:55:09z WiFi connected. SSID=BT_SERVER_XX_2.4GHz, IP=192.168.1.10, channel=9, RSSI -85db
4/06/21 17:22:08z Disconnect command received.
4/06/21 17:22:08z WiFi disconnected.
END
The router that I am using is a LinkSys WRT32X with DDWRT installed - Firmware: DD-WRT v3.0-r44483 std (10/02/20).
I have given the IotaWatt a reserved IP address of – 192.168.1.10 and have tried different wi-fi channels with no improvement in connection duration.
I have also enclosed the LinkSys log for reference:-
START
Apr 6 17:05:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: authenticated
Apr 6 17:10:42 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: disassociated due to inactivity
Apr 6 17:10:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Apr 6 17:10:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfMLME: auth request, signal -69 (Accepted)
Apr 6 17:10:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfMLME: assoc request, signal -69 (Accepted)
Apr 6 17:10:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: associated (aid 1)
Apr 6 17:10:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfRADIUS: starting accounting session A9CDFB603D28CB96
Apr 6 17:10:43 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfWPA: pairwise key handshake completed (RSN)
Apr 6 17:10:43 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPREQUEST(br0) 192.168.1.10 8x:xx:x5:xx:xx:xf
Apr 6 17:10:43 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPACK(br0) 192.168.1.10 8x:xx:x5:xx:xx:xfIotaWatt
Apr 6 17:10:43 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPDISCOVER(br0) 8x:xx:x5:xx:xx:xf
Apr 6 17:10:43 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPOFFER(br0) 192.168.1.10 8x:xx:x5:xx:xx:xf
Apr 6 17:10:44 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: authenticated
Apr 6 17:16:09 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: disassociated due to inactivity
Apr 6 17:16:10 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Apr 6 17:16:10 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfMLME: auth request, signal -70 (Accepted)
Apr 6 17:16:10 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfMLME: assoc request, signal -69 (Accepted)
Apr 6 17:16:10 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: associated (aid 1)
Apr 6 17:16:10 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfRADIUS: starting accounting session 2268969BFF7484BD
Apr 6 17:16:10 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfWPA: pairwise key handshake completed (RSN)
Apr 6 17:16:10 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPREQUEST(br0) 192.168.1.10 8x:xx:x5:xx:xx:xf
Apr 6 17:16:10 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPACK(br0) 192.168.1.10 8x:xx:x5:xx:xx:xfIotaWatt
Apr 6 17:16:10 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPDISCOVER(br0) 8x:xx:x5:xx:xx:xf
Apr 6 17:16:10 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPOFFER(br0) 192.168.1.10 8x:xx:x5:xx:xx:xf
Apr 6 17:16:11 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPREQUEST(br0) 192.168.1.10 8x:xx:x5:xx:xx:xf
Apr 6 17:16:11 BT_SERVER_XX daemon.info dnsmasq-dhcp[1534]: DHCPACK(br0) 192.168.1.10 8x:xx:x5:xx:xx:xfIotaWatt
Apr 6 17:16:16 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: authenticated
Apr 6 17:16:30 BT_SERVER_XX daemon.info httpd[1761]: httpd : Authentication fail
Apr 6 17:22:08 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: disassociated
Apr 6 17:22:09 BT_SERVER_XX daemon.info hostapd: ath1: STA 8x:xx:x5:xx:xx:xfIEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
END
I have other wi-fi devices running on this router without any issue. Very close to the IotaWatt is a Nest thermostat which works perfectly.
Any help would be most appreciated as I can’t wait to have it up and running.
Further information can be provided if required.
Regards
Robert
