I just received my new iotawatt but for some reason no logs seems to be generated or retained.
Real Time Clock not running.
Reset reason: Software/System restart
Trace: 105:97[35], 188:157[170], 137:195[144], 115:90[107], 175:121[154], 111:72[55], 70:77[176], 131:32[5], 225:187[185], 145:88[47], 105:83[228], 131:208[161], 63:220[219], 111:137[106], 23:156[42], 76:71[128], 177:177[121], 2:54[100], 200:25[40], 28:249[83], 141:88[21], 211:117[192], 134:10[142], 70:212[145], 108:100[207], 29:163[221], 99:23[44], 186:168[201], 68:53[34], 47:244[105], 220:150[85], 109:242[113]
ESP8266 ID: 14595149, RTC PCF8523 (68)
IoTaWatt 5.0, Firmware version 02_07_05
SPIFFS mounted.
Local time zone: +0:00
device name: IotaWatt
Connecting with WiFiManager.
Reset reason: External System
Trace: 105:97[35], 189:157[170], 137:195[144], 115:90[111], 191:121[154], 111:72[55], 71:77[176], 131:32[5], 225:187[185], 144:88[63], 105:83[228], 131:192[161], 63:221[211], 111:137[104], 23:156[42], 76:71[128], 177:177[121], 2:54[100], 200:89[40], 28:248[83], 141:88[21], 219:101[224], 142:10[142], 78:212[145], 108:100[223], 21:163[221], 99:23[44], 186:168[193], 68:117[34], 46:244[109], 92:134[85], 237:240[113]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=iot, IP=10.0.13.101, channel=6, RSSI -47db
timeSync: service started.
statService: started.
influxDB_v2: HTTPS specified but no HTTPSproxy server configured, stopping.
influxDB_v2: Invalid configuration.
Updater: Invalid response from server. HTTPcode: -4
influxDB_v2: Starting, interval:5, url:http://10.22.0.131:8086
influxDB_v2: Start posting 01/26/23 00:00:05
Restart command received.
Trace: 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1, 20:2, 20:31, 20:32, 20:4, 20:42, 1:6[6], 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
SPIFFS mounted.
Local time zone: -5:00, using DST/BST when in effect.
HTTP server started
WiFi connected. SSID=iot, IP=10.0.13.101, channel=6, RSSI -50db
influxDB_v2: stopped, Last post 01/26/23 00:00:00
Trace: 11:55, 11:70, 1:4, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[14], 1:6[4], 14:0, 14:1, 1:6[6], 1:3, 10:2, 10:3
SPIFFS mounted.
device name: Iota01
HTTP server started
WiFi connected. SSID=iot, IP=10.0.13.101, channel=6, RSSI -49db
MDNS responder started for hostname Iota01
LLMNR responder started for hostname Iota01
Trace: 105:97[35], 188:153[170], 137:195[144], 114:90[111], 175:121[154], 106:64[55], 102:77[176], 131:32[5], 225:187[185], 144:216[59], 105:91[228], 131:193[160], 95:221[219], 111:137[106], 22:156[42], 205:69[128], 177:177[105], 2:54[100], 200:25[40], 28:249[83], 141:88[5], 243:103[224], 142:10[142], 78:212[145], 108:100[223], 29:163[221], 99:151[44], 186:168[201], 68:117[34], 110:245[105], 220:134[85], 109:240[113]
SPIFFS mounted.
device name: Iota01
HTTP server started
WiFi connected. SSID=iot, IP=10.0.13.101, channel=6, RSSI -48db
Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 10:2, 10:3
SPIFFS mounted.
device name: Iota01
HTTP server started
influxDB_v2: Start posting 01/25/23 00:00:05
deletelog=both command received.
Trace: 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1, 20:2, 20:31, 20:32, 20:4, 20:42, 1:6[6], 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:21, 10:23
SPIFFS mounted.
device name: Iota01
HTTP server started
Trace: 20:42, 1:6[6], 1:1[12], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:0, 10:17, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:21, 10:23
SPIFFS mounted.
device name: Iota01
HTTP server started
Trace: 1:3, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[9], 1:2[10], 9:0[10], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
SPIFFS mounted.
device name: Iota01
HTTP server started
Influx upload does not seem to work either but I assume it needs access to logged data to work.
I tried to use the http://10.0.13.101/command?deletelog=both command to see if it would recreate them but it does not seem to work either.
