I setup a new setup. The main ct’s are showing the correct watts (US 240 Volts). The other CT’s (breakers) are showing 4 to 5x’s the actually wattage. The voltage is correct on the status page. The message log shows IoTaWatt 5.0, Firmware 02_05_09. Is there something I am missing? Thanks
Sounds like you may have 50A CTs setup as 200A CTs. Can you post a screenshot of the inputs?
That worked. I follow the instructions and selected the esc24200ct. After your message, I changed each input to the correct accuct. Thanks
