iotamsgs.log
11/04/22 14:50:22z Real Time Clock is running. Unix time 1667573422
11/04/22 14:50:22z Reset reason: Software/System restart
11/04/22 14:50:22z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1, 20:2, 20:3, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:2
11/04/22 14:50:22z ESP8266 ID: 12668703, RTC PCF8523 (68)
11/04/22 14:50:22z IoTaWatt 5.0, Firmware version 02_07_05
11/04/22 14:50:22z SPIFFS mounted.
11/05/22 01:50:22 Local time zone: +10:00, using DST/BST when in effect.
11/05/22 01:50:22 device name: IotaWatt
11/05/22 01:50:22 HTTP server started
11/05/22 01:50:22 influxDB_v1: Starting, interval:5, url:http://hassio.lan.tonyrothwell.id.au:8086
11/05/22 01:50:22 timeSync: service started.
11/05/22 01:50:22 statService: started.
11/05/22 01:50:22 dataLog: service started.
11/05/22 01:50:25 dataLog: Last log entry 11/05/22 01:50:20
11/05/22 01:50:27 historyLog: service started.
11/05/22 01:50:27 historyLog: Last log entry 11/05/22 01:50:00
11/05/22 02:10:08 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -64db
11/05/22 02:10:08 MDNS responder started for hostname IotaWatt
11/05/22 02:10:08 LLMNR responder started for hostname IotaWatt
11/05/22 02:10:08 Updater: service started. Auto-update class is MINOR
11/05/22 02:10:22 Updater: Auto-update is current for class MINOR.
11/05/22 02:10:24 influxDB_v1: Start posting at 11/04/22 22:50:15
11/05/22 03:11:46 WiFi disconnected.
11/05/22 03:11:48 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/05/22 03:50:29 WiFi disconnected.
11/05/22 03:50:44 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/05/22 04:10:55 Updater: Invalid response from server. HTTPcode: -14
11/05/22 04:54:54 WiFi disconnected.
11/05/22 04:56:32 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/05/22 08:11:38 Updater: Invalid response from server. HTTPcode: -4
11/05/22 09:54:16 WiFi disconnected.
11/05/22 10:14:46 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -62db
11/05/22 12:55:22 WiFi disconnected.
11/05/22 13:00:54 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/05/22 14:03:14 WiFi disconnected.
11/05/22 14:05:52 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/05/22 17:03:19 WiFi disconnected.
11/05/22 17:08:08 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/05/22 18:03:26 WiFi disconnected.
11/05/22 18:38:13 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -62db
11/05/22 19:39:25 Updater: Invalid response from server. HTTPcode: -11
11/05/22 20:01:01 Heap memory has degraded below safe minimum, restarting.
11/05/22 09:01:01z Real Time Clock is running. Unix time 1667638861
11/05/22 09:01:01z Reset reason: Software/System restart
11/05/22 09:01:01z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
11/05/22 09:01:01z ESP8266 ID: 12668703, RTC PCF8523 (68)
11/05/22 09:01:01z IoTaWatt 5.0, Firmware version 02_07_05
11/05/22 09:01:01z SPIFFS mounted.
11/05/22 20:01:01 Local time zone: +10:00, using DST/BST when in effect.
11/05/22 20:01:01 device name: IotaWatt
11/05/22 20:01:01 HTTP server started
11/05/22 20:01:01 influxDB_v1: Starting, interval:5, url:http://hassio.lan.tonyrothwell.id.au:8086
11/05/22 20:01:01 timeSync: service started.
11/05/22 20:01:01 statService: started.
11/05/22 20:01:01 dataLog: service started.
11/05/22 20:01:04 dataLog: Last log entry 11/05/22 20:01:00
11/05/22 20:01:06 historyLog: service started.
11/05/22 20:01:06 historyLog: Last log entry 11/05/22 20:01:00
11/05/22 20:04:15 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -62db
11/05/22 20:04:15 MDNS responder started for hostname IotaWatt
11/05/22 20:04:15 LLMNR responder started for hostname IotaWatt
11/05/22 20:04:15 Updater: service started. Auto-update class is MINOR
11/05/22 20:04:51 Updater: Invalid response from server. HTTPcode: -4
11/05/22 20:08:22 influxDB_v1: Start posting at 11/05/22 18:30:15
11/05/22 21:04:25 Updater: Auto-update is current for class MINOR.
11/06/22 01:05:19 Updater: Invalid response from server. HTTPcode: -14
11/06/22 02:05:30 Updater: Invalid response from server. HTTPcode: -11
11/06/22 02:15:18 WiFi disconnected.
11/06/22 02:15:27 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -62db
11/06/22 08:15:26 WiFi disconnected.
11/06/22 08:16:08 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -62db
11/06/22 09:07:45 Updater: Invalid response from server. HTTPcode: -14
11/06/22 10:02:54 Heap memory has degraded below safe minimum, restarting.
11/05/22 23:02:55z Real Time Clock is running. Unix time 1667689375
11/05/22 23:02:55z Reset reason: Software/System restart
11/05/22 23:02:55z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:2, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
11/05/22 23:02:55z ESP8266 ID: 12668703, RTC PCF8523 (68)
11/05/22 23:02:55z IoTaWatt 5.0, Firmware version 02_07_05
11/05/22 23:02:55z SPIFFS mounted.
11/06/22 10:02:55 Local time zone: +10:00, using DST/BST when in effect.
11/06/22 10:02:55 device name: IotaWatt
11/06/22 10:02:55 HTTP server started
11/06/22 10:02:55 influxDB_v1: Starting, interval:5, url:http://hassio.lan.tonyrothwell.id.au:8086
11/06/22 10:02:55 timeSync: service started.
11/06/22 10:02:55 statService: started.
11/06/22 10:02:55 dataLog: service started.
11/06/22 10:02:58 dataLog: Last log entry 11/06/22 10:02:50
11/06/22 10:03:00 historyLog: service started.
11/06/22 10:03:00 historyLog: Last log entry 11/06/22 10:02:00
11/06/22 10:03:09 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -61db
11/06/22 10:03:09 MDNS responder started for hostname IotaWatt
11/06/22 10:03:09 LLMNR responder started for hostname IotaWatt
11/06/22 10:03:09 Updater: service started. Auto-update class is MINOR
11/06/22 10:03:32 Updater: Auto-update is current for class MINOR.
11/06/22 11:03:14 WiFi disconnected.
11/06/22 11:09:39 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/06/22 11:10:01 Updater: Invalid response from server. HTTPcode: -4
11/06/22 11:39:26 influxDB_v1: Start posting at 11/06/22 07:38:10
11/06/22 13:03:06 WiFi disconnected.
11/06/22 13:03:16 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -63db
11/06/22 13:09:57 Updater: Invalid response from server. HTTPcode: -11
11/06/22 14:03:18 WiFi disconnected.
11/06/22 14:04:12 WiFi connected. SSID=Can't stop the Wifi, Mal, IP=192.168.42.204, channel=1, RSSI -62db
11/06/22 14:10:10 Updater: Invalid response from server. HTTPcode: -4
So the updater didn’t have any valid responses when it was checking (I think) and it was restarting every day or so due to the heap memory degrading… as in too little free memory?
I might just put a blank config on the SD card and see if it come back, just in case…
