No problem on the log. Here is the full log.
10/28/19 15:06:04z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 15:06:04z SPIFFS mounted.
10/28/19 20:06:05 Local time zone: +5:00
10/28/19 20:06:05 device name: IotaWatt
10/28/19 20:06:05 MDNS responder started for hostname IotaWatt
10/28/19 20:06:05 LLMNR responder started for hostname IotaWatt
10/28/19 20:06:05 HTTP server started
10/28/19 20:06:05 timeSync: service started.
10/28/19 20:06:05 statService: started.
10/28/19 20:06:05 Updater: service started. Auto-update class is MINOR
10/28/19 20:06:05 dataLog: service started.
10/28/19 20:06:06 dataLog: Last log entry 10/28/19 20:06:00
10/28/19 20:06:06 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -62db
10/28/19 20:06:06 Updater: Auto-update is current for class MINOR.
10/28/19 20:06:10 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/28/19 20:06:11 EmonService: Start posting at 10/28/19 20:06:00
10/28/19 15:07:01z Real Time Clock is running. Unix time 1572275221
10/28/19 15:07:01z Reset reason: Exception
10/28/19 15:07:01z Trace: 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1
10/28/19 15:07:01z ESP8266 ChipID: 6348181
10/28/19 15:07:01z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 15:07:01z SPIFFS mounted.
10/28/19 20:07:02 Local time zone: +5:00
10/28/19 20:07:02 device name: IotaWatt
10/28/19 20:07:02 MDNS responder started for hostname IotaWatt
10/28/19 20:07:02 LLMNR responder started for hostname IotaWatt
10/28/19 20:07:02 HTTP server started
10/28/19 20:07:02 timeSync: service started.
10/28/19 20:07:02 statService: started.
10/28/19 20:07:02 Updater: service started. Auto-update class is MINOR
10/28/19 20:07:02 dataLog: service started.
10/28/19 20:07:03 dataLog: Last log entry 10/28/19 20:06:55
10/28/19 20:07:03 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -62db
10/28/19 20:07:03 Updater: Auto-update is current for class MINOR.
10/28/19 20:07:07 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/28/19 20:07:08 EmonService: Start posting at 10/28/19 20:06:55
10/28/19 20:08:02 historyLog: service started.
10/28/19 20:08:02 historyLog: Last log entry 10/28/19 20:06:00
10/28/19 15:12:53z Real Time Clock is running. Unix time 1572275573
10/28/19 15:12:53z Reset reason: Software/System restart
10/28/19 15:12:53z Trace: 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1
10/28/19 15:12:53z ESP8266 ChipID: 6348181
10/28/19 15:12:53z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 15:12:53z SPIFFS mounted.
10/28/19 20:12:54 Local time zone: +5:00
10/28/19 20:12:54 device name: IotaWatt
10/28/19 20:12:54 MDNS responder started for hostname IotaWatt
10/28/19 20:12:54 LLMNR responder started for hostname IotaWatt
10/28/19 20:12:54 HTTP server started
10/28/19 20:12:54 timeSync: service started.
10/28/19 20:12:54 statService: started.
10/28/19 20:12:54 Updater: service started. Auto-update class is MINOR
10/28/19 20:12:55 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -61db
10/28/19 20:12:55 dataLog: service started.
10/28/19 20:12:55 dataLog: Last log entry 10/28/19 20:12:50
10/28/19 20:12:56 Updater: Auto-update is current for class MINOR.
10/28/19 20:12:59 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/28/19 20:13:00 EmonService: Start posting at 10/28/19 20:12:50
10/28/19 20:13:54 historyLog: service started.
10/28/19 20:13:54 historyLog: Last log entry 10/28/19 20:12:00
10/28/19 21:52:52 EmonService: HTTP response -11, retrying.
10/28/19 22:55:23z Real Time Clock is running. Unix time 1572303323
10/28/19 22:55:23z Reset reason: Exception
10/28/19 22:55:23z Trace: 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1
10/28/19 22:55:23z ESP8266 ChipID: 6348181
10/28/19 22:55:23z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 22:55:23z SPIFFS mounted.
10/29/19 03:55:24 Local time zone: +5:00
10/29/19 03:55:24 device name: IotaWatt
10/29/19 03:55:24 MDNS responder started for hostname IotaWatt
10/29/19 03:55:24 LLMNR responder started for hostname IotaWatt
10/29/19 03:55:24 HTTP server started
10/29/19 03:55:24 timeSync: service started.
10/29/19 03:55:24 statService: started.
10/29/19 03:55:24 Updater: service started. Auto-update class is MINOR
10/29/19 03:55:24 dataLog: service started.
10/29/19 03:55:25 dataLog: Last log entry 10/29/19 03:55:20
10/29/19 03:55:25 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -63db
10/29/19 03:55:25 Updater: Auto-update is current for class MINOR.
10/29/19 03:55:29 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/29/19 03:55:30 EmonService: Start posting at 10/28/19 21:52:10
10/29/19 03:56:24 historyLog: service started.
10/29/19 03:56:24 historyLog: Last log entry 10/29/19 03:55:00
10/29/19 03:57:29 EmonService: HTTP response -11, retrying.
10/29/19 04:24:56 Restart command received.
10/28/19 23:24:58z Real Time Clock is running. Unix time 1572305098
10/28/19 23:24:58z Reset reason: Software/System restart
10/28/19 23:24:58z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[8], 1:2[10], 9:0[10], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
10/28/19 23:24:58z ESP8266 ChipID: 6348181
10/28/19 23:24:58z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 23:24:58z SPIFFS mounted.
10/29/19 04:24:59 Local time zone: +5:00
10/29/19 04:24:59 device name: IotaWatt
10/29/19 04:24:59 MDNS responder started for hostname IotaWatt
10/29/19 04:24:59 LLMNR responder started for hostname IotaWatt
10/29/19 04:24:59 HTTP server started
10/29/19 04:24:59 timeSync: service started.
10/29/19 04:24:59 statService: started.
10/29/19 04:24:59 Updater: service started. Auto-update class is MINOR
10/29/19 04:24:59 dataLog: service started.
10/29/19 04:25:00 dataLog: Last log entry 10/29/19 04:24:55
10/29/19 04:25:00 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -62db
10/29/19 04:25:00 Updater: Auto-update is current for class MINOR.
10/29/19 04:25:04 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/29/19 04:25:05 EmonService: Start posting at 10/28/19 21:53:25
10/29/19 04:25:59 historyLog: service started.
10/29/19 04:25:59 historyLog: Last log entry 10/29/19 04:24:00
10/29/19 04:27:08 EmonService: HTTP response -11, retrying.
10/28/19 23:44:07z Real Time Clock is running. Unix time 1572306247
10/28/19 23:44:07z Reset reason: Exception
10/28/19 23:44:07z Trace: 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1
10/28/19 23:44:07z ESP8266 ChipID: 6348181
10/28/19 23:44:07z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 23:44:07z SPIFFS mounted.
10/29/19 04:44:08 Local time zone: +5:00
10/29/19 04:44:08 device name: IotaWatt
10/29/19 04:44:08 MDNS responder started for hostname IotaWatt
10/29/19 04:44:08 LLMNR responder started for hostname IotaWatt
10/29/19 04:44:08 HTTP server started
10/29/19 04:44:08 timeSync: service started.
10/29/19 04:44:08 statService: started.
10/29/19 04:44:08 Updater: service started. Auto-update class is MINOR
10/29/19 04:44:08 dataLog: service started.
10/29/19 04:44:09 dataLog: Last log entry 10/29/19 04:44:05
10/29/19 04:44:09 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -62db
10/29/19 04:44:09 Updater: Auto-update is current for class MINOR.
10/29/19 04:44:35 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/29/19 04:44:37 EmonService: Start posting at 10/28/19 21:54:40
10/28/19 23:44:44z Real Time Clock is running. Unix time 1572306284
10/28/19 23:44:44z Reset reason: Exception
10/28/19 23:44:44z Trace: 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1
10/28/19 23:44:44z ESP8266 ChipID: 6348181
10/28/19 23:44:44z IoTaWatt 5.0, Firmware version 02_04_02
10/28/19 23:44:44z SPIFFS mounted.
10/29/19 04:44:45 Local time zone: +5:00
10/29/19 04:44:45 device name: IotaWatt
10/29/19 04:44:45 MDNS responder started for hostname IotaWatt
10/29/19 04:44:45 LLMNR responder started for hostname IotaWatt
10/29/19 04:44:45 HTTP server started
10/29/19 04:44:45 timeSync: service started.
10/29/19 04:44:45 statService: started.
10/29/19 04:44:45 Updater: service started. Auto-update class is MINOR
10/29/19 04:44:45 dataLog: service started.
10/29/19 04:44:46 dataLog: Last log entry 10/29/19 04:44:40
10/29/19 04:44:46 WiFi connected. SSID=FBI Surveillance Van Cat1, IP=192.168.1.13, channel=11, RSSI -60db
10/29/19 04:44:46 Updater: Auto-update is current for class MINOR.
10/29/19 04:44:50 EmonService: started. url=192.168.1.21:80/emoncms, node=IotaWatt, interval=5
10/29/19 04:44:51 EmonService: Start posting at 10/28/19 21:55:55
10/29/19 04:45:45 historyLog: service started.
10/29/19 04:45:45 historyLog: Last log entry 10/29/19 04:44:00
10/29/19 04:46:50 EmonService: HTTP response -11, retrying.
