If you’re building the firmware from source using PlatformIO, you may hit a compile error:
fatal error: CBC.h: No such file or directory
The root cause: platformio.ini references the rweather arduinolibs repo as a dependency, which pulls in the Crypto library. However, CBC.h lives in a separate library called CryptoLegacy in the same repo, and PlatformIO doesn’t pull it automatically.
Fix: manually copy both libraries into the project’s local lib/ folder so PlatformIO finds them without fetching from the remote.
- Clone the arduinolibs repo somewhere temporary:
git clone GitHub - rweather/arduinolibs: Arduino Cryptography Library · GitHub - Copy both library folders into Firmware/lib/:
cp -r arduinolibs/libraries/Crypto /Firmware/lib/Crypto
cp -r arduinolibs/libraries/CryptoLegacy /Firmware/lib/CryptoLegacy - Delete the cloned repo — it’s no longer needed.
PlatformIO’s local lib/ directory takes precedence over remote dependencies, so the build will now find both Crypto.h and CBC.h and complete successfully.
