I am trying to view a “miscellaneous” loads by writing a formula. Basically my Mains added together minus all known loads. However even though I clearly have a load subtracted, in this case the hot tub it is still showing up in the graph for misc loads. writing a formula subtracting the hot tub twice does however remove it from the misc. load. The hot tub is a 240/120 unit, and I have both leads running through the CT one in the opposite direction. See images for clarity. This happens with all other output formulas that try to eliminate the hot tub load.
Thanks in advance. The Iota watt has already paid for itself as I discovered the contact on my well pressure pump were not opening complete and pump was running a continuous 800 watt load.
Matt
