Outputs not working
I had a power failure the other day and since then my Outputs aren’t collecting information.
You can see that my circuits are all being monitored… but my Outputs are 0?
Here’s my most recent log after a restart:
It looks like your Grid integration is not yet synchronized. In the restart message log, it shows last entry at 9/9/24 21:04:10. In the status display, it has advanced to 9/10/24 05:49:55.
The restart was at 12:11:02 and the status display was at 12:16:05 - about 5 minutes. In that time the integrator appears to be working to integrate to the current time and has integrated about 6,300 datalog entries. At that rate it should have caught up to present about 15 minutes later at around 12:31.
The integrator will not yield zero until it is synchronized with the current time. If it did not synchronize by the time you read this, there is probably something amiss with it and you should delete then recreate the integrator.
thank you! yes, my integrator must have got corrupted in some way… deleting it and restarting (and then waiting 10 mins) seems to have done the trick. I think after I deleted it and saw nothing I was a bit perplexed but as you said… it started working eventually.
