Hi there
I’m in Denmark where every household (well almost) has three phase input.
Some equipment are distributed on differnet phases so I need to measure each phase.
We have smart meters here in Denmark, so I can pull it from the meter, my problem with that is that the meter is outside, built in to the wall, and I can’t get wires pushed out to it, so I need a different solution.
I’ve taken some pictures of my small electrical setup.
My idea is to have the input measured, and then each group as well, there aren’t much space though, so I might have to settle with just measuring the input.
As you might be able to see some of the groups are three phases as well.
Looks pretty straightforward. It will be tight getting the CTs in there. The mains no problem. It looks like most of the others can be measured on the output side. All 50A.breakers. I count 13 if you can get them on everything. If any are difficult or impossible, and they are the only unmeasured on a phase, you can get by subtracting the others from the main.
Hi Ken, I have a similar set up to you, and was wondering were you successful in buying and setting up iotawatt 8 months ago? Would be great to hear how it went!
