You can split one but not both. My recommendation would be to split the AC ref with a CCTV DC splitter cable and use separate USB power supplies for the two units.
Is the ground loop relative the USB V- or USB shield? Some devices bond V- and shield, does the IoTaWatt?
I ask because I’m trying to fit this into a recessed enclosure using a USB receptacle since I’m not sure I can fit the USB adapters. The receptacles generally have a pair of ports with isolated V+/V-, but usually bond USB shield to earth ground.
I don’t know. Schematic for ESP8266 is open so you can look it up. USB plugs are for chargers. I recommend actual power supplies. They are pretty small.
Just closing the loop on this one. The ESP8266 has a few design variants, but USB shield does get tied to system GND in some of them. Therefore, I agree with you that using a USB receptacle (with USB shield bonded to earth ground) is unwise.
I have switched to a larger enclosure and will be using USB power supplies (though probably will need to get ones with cords exiting vertically, but that shouldn’t be difficult). Thanks for the tips!
