Hi.
Got some electrical work done today and power was cut-off for about 4 hours.
It all restarted nicely, but I noticed that the time set wasn’t correct so I just rebooted via the web interface.
Now I can’t connect to the iotatwatt.
I can see that it gets an IP address via the wifi router, put I can’t ping it.
The LED light is flickering like a network card would. They aren’t regular flashes nor does the LED turns off, it just flickers in intensity.
I tried power-cycling the unit with no luck.
Now going back to the unit, it does the same light flickering but green only.
Any ideas?
