Hi,
The PVoutput uploader has generally worked well for me, but right now it’s stuck. It says “PVoutput: Running, Last update 07/02/2106 6:28:16 am”. If I click “Stop” then it does not stop. I’ve tried restarting the device many times with no change.
I’ve tried deleting the PVOutput Config, restarting the device, then reconfiguring, but no luck. Even after I’ve deleted the PVOutput configuration, the " PVoutput: Running, Last update 07/02/2106 6:28:16 am " message remains on the status page.
I am a PVOutput doner.
Any ideas?
What is the PVoutput name?
That looks OK . Can I see your PVoutput setup please?
See screenshot attached It’s been all working fine for literally years. It appears to have failed after the power went out and the device restarted I think.
emoncms uploader is working fine.
(NOTE: I’ve played around with the pvoutput config over the last few days - deleted it, replaced it)
That looks OK as well. When IoTaWatt starts an uploader, it first queries the server to find out the date and time of last upload and seamlessly uploads from then.
The PVoutput API is “Get Status Service”. The first two data items returned are the date and time of last upload. Given that everything else looks OK, I suspect that you are getting a bad date from that API.
I’ve hotlinked the PVoutput description in case you want to try to try it with CURL. If not, you can send me your API key in a Private Message and I will check it.
Thanks for the response! Sorry about delay - was away for a few days.
I’ll PM you my API key I think…
Hi,
same issue here - do you have a solution?
Thanks
After a lengthy dialogue on a private thread, the problem turned out to be a bad SDcard. I suspect you may have a damaged datalog. If you want to post your message log, a screenshot of the status display and a screenshot of the PVoutput setup I’ll take a look and see if it might be something else. I’d also like to see a link to your PVoutput site.
Here ist the message log - looks strange…
6/24/25 20:57:36z Real Time Clock is running. Unix time 1750798656
6/24/25 20:57:36z Reset reason: Software/System restart
6/24/25 20:57:36z Trace: 31:1, 31:2[5], 31:120, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[5], 31:120, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[33], 1:6[4], 33:0, 33:1, 33:2, 33:10, 33:10, 33:10
6/24/25 20:57:36z ESP8266 ID: 6910698, RTC PCF8523 (68)
6/24/25 20:57:36z IoTaWatt 4.x, Firmware version 02_08_03
6/24/25 20:57:36z SPIFFS mounted.
6/24/25 22:57:36 Local time zone: +1:00, using DST/BST when in effect.
6/24/25 22:57:36 device name: IotaWatt
6/24/25 22:57:36 HTTP server started
6/24/25 22:57:36 emoncms: Starting, interval:10, url:http://emoncms.org
6/24/25 22:57:36 influxDB_v1: Starting, interval:10, url:http://openhab.fritz.box:8086
6/24/25 22:57:36 timeSync: service started.
6/24/25 22:57:36 statService: started.
6/24/25 22:57:37 dataLog: service started.
6/24/25 22:57:37 dataLog: Last log entry 06/24/25 22:55:35
6/24/25 22:57:41 grid: Started
6/24/25 22:57:41 grid: New log starting 06/23/25 22:57:40
6/24/25 22:57:41 pv_sum: Started
6/24/25 22:57:41 pv_sum: Couldn’t open integration file /iotawatt/integrations//pv_sum.log.
6/24/25 22:57:42 historyLog: service started.
6/24/25 22:57:42 historyLog: Log file open failed: 2, service halted.
6/24/25 22:57:44 Updater: service started. Auto-update class is BETA
6/24/25 22:57:44 WiFi connected. SSID=HiddenK, IP=192.168.0.65, channel=13, RSSI -68db
6/24/25 22:57:44 emoncms: Start posting at 06/24/25 22:55:20
6/24/25 22:57:46 Updater: Auto-update is current for class BETA.
6/24/25 23:10:58 pv_sum: Started
6/24/25 23:10:58 pv_sum: Couldn’t open integration file /iotawatt/integrations//pv_sum.log.
6/24/25 23:12:52 pv_sum: Started
6/24/25 23:12:52 pv_sum: Couldn’t open integration file /iotawatt/integrations//pv_sum.log.
6/24/25 23:20:56 pv_sum: Started
It looks like SDcard. Both your history log and the integration log for pv_sum can’t be opened.
I’d recommend building a new SDcard and not copying any of the .log files.
ok - thanks - will try this afternoon
Hi overeasy,
Took a bit longer - needed to find propper SD card.
Today built new SD card as described in your related post.
checked old SD card - many errors - after fixing - RGR → new SD card.
used original config.txt - all Ok
issue with PVOutPut fixed - only missed data for last 7 month - but that was my fault - not recognizing the issue.
Thanks for your as always perfect support.
Guenta
