Hi,
I’ve setup PVOutput for my solar array and its working well, but I saw recently I can use Iotawatt to push data into it.
The solar installer didn’t install my Iotawatt properly so I only have 1 CT and the Voltage working at the moment. I have to pay another electrician to pull the board back apart and hook up the rest of the CT hopefully soon.
I noticed when adding PVOutput data uploader that I can’t simply select voltage only. It seems I must also select either consumption or generation to see a save button.
Is it possible to work around this somehow and just push voltage up? I’m already feeding in data via the Enphase direct integration with PVOutput, so the generation/consumption isn’t needed.
So was just hoping in the short term to fill in the voltage column.
Not even sure what purpose it serves, but I just didn’t like have a blank column.
thanks,
Ryan
