My unit has been doing some serious background working in the last few days to the point where it no longer reliably responds when I ask for data. I can occasionally get connected to it but it stopped talking to PVOUTPUT yesterday.
I can (occasionally) get a look at the log and it would appear to be continually trying to download and install new firmware (02_05_09).
As far back in the log as is interesting, it seems to cycle through this sequence every minute or so.
I did resort to my first manual restart in six months but (as expected) no change.
Any clues?
6/15/20 22:13:01z Real Time Clock is running. Unix time 1592259181
6/15/20 22:13:01z Reset reason: Software/System restart
6/15/20 22:13:01z Trace: 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:6, 3:6, 3:6, 3:6, 3:6, 3:6, 1:6, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
6/15/20 22:13:02z ESP8266 ChipID: 6144641
6/15/20 22:13:02z IoTaWatt 5.0, Firmware version 02_05_08
6/15/20 22:13:02z SPIFFS mounted.
6/16/20 08:13:03 Local time zone: +10:00
6/16/20 08:13:03 Using Daylight Saving Time (BST) when in effect.
6/16/20 08:13:03 device name: IotaWatt
6/16/20 08:13:04 HTTP server started
6/16/20 08:13:04 timeSync: service started.
6/16/20 08:13:04 statService: started.
6/16/20 08:13:04 dataLog: service started.
6/16/20 08:13:06 dataLog: Last log entry 06/16/20 08:12:30
6/16/20 08:13:06 historyLog: service started.
6/16/20 08:13:07 historyLog: Last log entry 06/16/20 08:12:00
6/16/20 08:13:09 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10
6/16/20 08:13:11 WiFi connected. SSID=Frog, IP=192.168.0.106, channel=6, RSSI -55db
6/16/20 08:13:11 MDNS responder started for hostname IotaWatt
6/16/20 08:13:11 LLMNR responder started for hostname IotaWatt
6/16/20 08:13:12 Updater: service started. Auto-update class is MINOR
6/16/20 08:13:14 PVoutput: started
6/16/20 08:13:14 EmonService: Start posting at 06/15/20 18:20:00
6/16/20 08:13:14 Updater: Update from 02_05_08 to 02_05_09
6/16/20 08:13:16 Updater: download 02_05_09
6/16/20 08:13:46 dataLog: datalog WDT - restarting
6/15/20 22:13:47z Real Time Clock is running. Unix time 1592259227
6/15/20 22:13:47z Reset reason: Software/System restart
6/15/20 22:13:47z Trace: 1:3, 1:4, 1:5[3], 3:0, 3:6, 3:6, 3:6, 3:6, 3:6, 3:6, 1:6, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101, 21:101[1]
6/15/20 22:13:48z ESP8266 ChipID: 6144641
6/15/20 22:13:48z IoTaWatt 5.0, Firmware version 02_05_08
6/15/20 22:13:48z SPIFFS mounted.
6/16/20 08:13:49 Local time zone: +10:00
6/16/20 08:13:49 Using Daylight Saving Time (BST) when in effect.
6/16/20 08:13:49 device name: IotaWatt
6/16/20 08:13:50 HTTP server started
6/16/20 08:13:50 timeSync: service started.
6/16/20 08:13:50 statService: started.
6/16/20 08:13:51 dataLog: service started.
6/16/20 08:13:52 dataLog: Last log entry 06/16/20 08:13:15
6/16/20 08:13:52 historyLog: service started.
6/16/20 08:13:53 historyLog: Last log entry 06/16/20 08:13:00
6/16/20 08:13:55 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10
6/16/20 08:13:56 WiFi connected. SSID=Frog, IP=192.168.0.106, channel=6, RSSI -55db
6/16/20 08:13:56 MDNS responder started for hostname IotaWatt
6/16/20 08:13:56 LLMNR responder started for hostname IotaWatt
6/16/20 08:13:57 Updater: service started. Auto-update class is MINOR
6/16/20 08:13:59 EmonService: Start posting at 06/15/20 18:20:00
6/16/20 08:13:59 Updater: Update from 02_05_08 to 02_05_09
6/16/20 08:14:00 Updater: download 02_05_09
6/16/20 08:14:01 PVoutput: started
6/16/20 08:14:31 dataLog: datalog WDT - restarting
6/15/20 22:14:32z Real Time Clock is running. Unix time 1592259272
6/15/20 22:14:32z Reset reason: Software/System restart
6/15/20 22:14:32z Trace: 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:6, 3:6, 3:6, 3:6, 3:6, 3:6, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
6/15/20 22:14:33z ESP8266 ChipID: 6144641
6/15/20 22:14:33z IoTaWatt 5.0, Firmware version 02_05_08
6/15/20 22:14:33z SPIFFS mounted.
6/16/20 08:14:34 Local time zone: +10:00
6/16/20 08:14:34 Using Daylight Saving Time (BST) when in effect.
6/16/20 08:14:35 device name: IotaWatt
6/16/20 08:14:35 HTTP server started
6/16/20 08:14:35 timeSync: service started.
6/16/20 08:14:35 statService: started.
6/16/20 08:14:36 dataLog: service started.
6/16/20 08:14:37 dataLog: Last log entry 06/16/20 08:14:00
6/16/20 08:14:37 historyLog: service started.
6/16/20 08:14:38 historyLog: Last log entry 06/16/20 08:13:00
6/16/20 08:14:40 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10
6/16/20 08:14:41 WiFi connected. SSID=Frog, IP=192.168.0.106, channel=6, RSSI -56db
6/16/20 08:14:41 MDNS responder started for hostname IotaWatt
6/16/20 08:14:41 LLMNR responder started for hostname IotaWatt
6/16/20 08:14:42 Updater: service started. Auto-update class is MINOR
6/16/20 08:14:44 EmonService: Start posting at 06/15/20 18:20:00
6/16/20 08:14:44 Updater: Update from 02_05_08 to 02_05_09
6/16/20 08:14:45 Updater: download 02_05_09
6/16/20 08:14:46 PVoutput: started
6/16/20 08:15:16 dataLog: datalog WDT - restarting
6/15/20 22:15:17z Real Time Clock is running. Unix time 1592259317
6/15/20 22:15:17z Reset reason: Software/System restart
6/15/20 22:15:17z Trace: 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:6, 3:6, 3:6, 3:6, 3:6, 3:6, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
6/15/20 22:15:18z ESP8266 ChipID: 6144641
6/15/20 22:15:18z IoTaWatt 5.0, Firmware version 02_05_08
6/15/20 22:15:18z SPIFFS mounted.
6/16/20 08:15:19 Local time zone: +10:00
6/16/20 08:15:19 Using Daylight Saving Time (BST) when in effect.
6/16/20 08:15:20 device name: IotaWatt
6/16/20 08:15:20 HTTP server started
6/16/20 08:15:20 timeSync: service started.
6/16/20 08:15:20 statService: started.
6/16/20 08:15:21 dataLog: service started.
6/16/20 08:15:22 dataLog: Last log entry 06/16/20 08:14:45
6/16/20 08:15:22 historyLog: service started.
6/16/20 08:15:23 historyLog: Last log entry 06/16/20 08:14:00
6/16/20 08:15:25 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10
6/16/20 08:15:26 WiFi connected. SSID=Frog, IP=192.168.0.106, channel=6, RSSI -55db
6/16/20 08:15:26 MDNS responder started for hostname IotaWatt
6/16/20 08:15:26 LLMNR responder started for hostname IotaWatt
