My Iotawatt has started to reboot when I open the graph page. The WiFi appears to drop and reconnect according to my Unifi instance. I do have Emoncms and PV Output uploading and have started using HA integration. Could I be hitting it a bit hard perhaps?
10/24/22 09:57:53z Real Time Clock is running. Unix time 1666605473
10/24/22 09:57:53z Reset reason: Exception
10/24/22 09:57:53z Trace: 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[4], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
10/24/22 09:57:53z ESP8266 ID: 6308217, RTC PCF8523 (68)
10/24/22 09:57:53z IoTaWatt 5.0, Firmware version 02_07_05
10/24/22 09:57:53z SPIFFS mounted.
10/24/22 17:57:53 Local time zone: +8:00
10/24/22 17:57:53 device name: IotaWatt
10/24/22 17:57:53 HTTP server started
10/24/22 17:57:53 emoncms: Starting, interval:5, url:http://192.168.1.200
10/24/22 17:57:53 timeSync: service started.
10/24/22 17:57:53 statService: started.
10/24/22 17:57:53 dataLog: service started.
10/24/22 17:57:54 dataLog: Last log entry 10/24/22 17:57:50
10/24/22 17:57:58 historyLog: service started.
10/24/22 17:57:58 historyLog: Last log entry 10/24/22 17:57:00
10/24/22 17:57:59 WiFi connected. SSID=Richo IOT, IP=10.0.0.10, channel=5, RSSI -59db
10/24/22 17:57:59 MDNS responder started for hostname IotaWatt
10/24/22 17:57:59 LLMNR responder started for hostname IotaWatt
10/24/22 17:57:59 Updater: service started. Auto-update class is BETA
10/24/22 17:57:59 emoncms: Start posting at 10/24/22 17:57:45
10/24/22 17:58:01 Updater: Auto-update is current for class BETA.
10/24/22 17:58:02 PVoutput: started
