Hi all,
My first IotaWatt works great. This second one has been giving us no connectivity for a few months and I’m finally taking time now to troubleshoot it.
Symptoms:
- The device briefly connects to WiFi and gets an IP address, but by the time I go to ping it, it’s gone
- Within a few minutes throws a red / red / red LED light status code
I’ve connected the USB cable to my Mac, and I’ve opened a program called Serial and started a connection with a Baud Rate of 115200, and I’m able to see output in the terminal as soon as I reconnect it. Here’s the full output:
[Connected]
Ғ"٥name: Iow2
5/31/23 13:11:32 HTTP server started
5/31/23 13:11:36 WiFi connected. SSID=IoT, IP=10.51.95.67, channel=11, RSSI -52db
5/31/23 13:11:36 MDNS responder started for hostname Iow2
5/31/23 13:11:36 LLMNR responder started for hostname Iow2
5/31/23 13:11:36 timeSync: service started.
User exception (panic/abort/assert)
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Panic src/include/DataSource.h:93 const uint8_t* BufferedStreamDataSource<TStream>::get_buffer(size_t) [with TStream = Stream; uint8_t = unsigned char; size_t: Assertion 'cb == stream_rem' failed.
>>>stack>>>
ctx: cont
sp: 3fff2570 end: 3fff27f0 offset: 0000
3fff2570: 3fff5094 00000200 00000238 40239181
3fff2580: 000000fe 00000000 00000000 00000000
3fff2590: 00000000 00000000 00000000 4027e64c
3fff25a0: 3fff1278 ffffffff 3fff4104 000005b4
3fff25b0: 000005b4 00000000 3fff4104 4022ec0a
3fff25c0: 007a1200 464ce8e4 00462700 4022ec3e
3fff25d0: 4010553d 004627e1 3fff1344 4021eeca
3fff25e0: 3ffeef70 3fff1344 00000001 000005b4
3fff25f0: 00000000 000005b4 3fff51fc 4021f0a9
3fff2600: 4022f43d 00000001 00026e62 00026e62
3fff2610: 00000001 00000001 3fff51fc 4021f16a
3fff2620: 3fff51fc 3fff2674 00000000 4021f674
3fff2630: 3fff0760 3fff2650 00026e62 00000000
3fff2640: 3fff0760 00000001 00026e62 4021ce80
3fff2650: 65646e00 74682e78 80ff006d 00000001
3fff2660: 3fff0810 3fff0784 00000020 40100cbf
3fff2670: 3fff3f54 4023d6a8 00000000 000003e8
3fff2680: 4023b7dc 3fff40ac 3fff40ec 00000000
3fff2690: 00000000 3fff0f44 69646500 40220074
3fff26a0: 80ff26f0 74786574 6d74682f 8900006c
3fff26b0: 00000000 3fff07a0 3fff26e0 4022d33c
3fff26c0: 3fff26f0 8000395a 3fff4c00 4023b7dc
3fff26d0: 4020dfb0 3fff07a0 00000000 4021d1b4
3fff26e0: 646e692f 682e7865 8a006d74 4023b7c8
3fff26f0: 6000002f 80fffe22 81100500 00003967
3fff2700: 00000000 3fff07a0 3fff0760 4023b7d2
3fff2710: 82450000 3ee622f8 80ff4554 40207d29
3fff2720: 0042495b 80000000 3fff5400 0000008f
3fff2730: 80005054 3fff0968 3fff4554 402113c0
3fff2740: 3fff07a0 3fff0968 3fff4514 00000000
3fff2750: 00000001 3fff3eb4 3fff0760 00dfe091
3fff2760: 007a1200 46139d99 00000000 00dfe091
3fff2770: 00000001 3fff0784 3fff0760 40207dcb
3fff2780: 3fff2a4c 4021e594 3fff0970 00dfe091
3fff2790: 00000000 0000020d 3fff0970 4022e4e2
3fff27a0: 3fff10e8 0000020d 3fff0970 40207f47
3fff27b0: 3fff4514 00000000 00000001 401001ac
3fff27c0: 3fffdad0 00000000 3fff11f8 3fff1238
3fff27d0: 3fffdad0 00000000 3fff11f8 4022e5c4
3fff27e0: feefeffe feefeffe 3ffe8604 40100fb9
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
SPI started.
5/31/23 16:11:43z Real Time Clock is running. Unix time 1685549503
5/31/23 16:11:43z Reset reason: Software/System restart
5/31/23 16:11:43z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[3], 1:2, 9:0, 9:0, 8:4, 8:2, 8:2, 1:2, 1:3, 10:13
5/31/23 16:11:43z ESP8266 ID: 14634031, RTC PCF8523 (68)
5/31/23 16:11:43z IoTaWatt 5.0, Firmware version 02_07_05
5/31/23 16:11:43z SPIFFS mounted.
5/31/23 13:11:43 Local time zone: -4:00, using DST/BST when in effect.
5/31/23 13:11:43 device name: Iow2
5/31/23 13:11:43 HTTP server started
5/31/23 13:11:43 timeSync: service started.
5/31/23 13:11:46 statService: started.
5/31/23 13:11:46 dataLog: service started.
5/31/23 13:11:46 dataLog: Log file open failed. 2
5/31/23 13:11:46 Program halted.
Based on this forum post, it seems like wiping the SD card might fix it, but @overeasy asked if we could provide more details first, so I figure I’ll leave this here for a bit in case it is helpful.
My next step is I’ll remove the Micro SD card and mount it to look for more information.
