Hi,
I am running IoTaWatt 5.0, Firmware version 02_07_04 configured to upload to and influxDB instance on local LAN. I have a repeated issue where the Iotawatt will stop uploading to InfluxDB, which apparently corresponds to every time the unit reboots (for whatever reason - manually rebooting the unit causes the issue).
The uploader status is ‘Query failed, code 400, response:’
The only way I have found to restart the upload is to clear the Iotawatt logs and then to perform the ‘voodoo’ steps of deleting the tag set entries in the Influx configuration and re-adding them. This consistently works.
Any help with this would be greatly appreciated as I cannot see anything obviously wrong from a configuration perspective. Most recent log below.
Many thanks
Jon
12/11/21 12:33:23z Real Time Clock is running. Unix time 1639226003
12/11/21 12:33:23z Reset reason: Software/System restart
12/11/21 12:33:23z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:21, 10:22
12/11/21 12:33:23z ESP8266 ID: 12704066, RTC PCF8523
12/11/21 12:33:23z IoTaWatt 5.0, Firmware version 02_07_04
12/11/21 12:33:23z SPIFFS mounted.
12/11/21 12:33:23z Local time zone: +0:00, using DST/BST when in effect.
12/11/21 12:33:23z device name: IotaWatt
12/11/21 12:33:23z HTTP server started
12/11/21 12:33:23z influxDB_v1: Starting, interval:10, url:[blanked out]
12/11/21 12:33:23z timeSync: service started.
12/11/21 12:33:23z statService: started.
12/11/21 12:33:23z dataLog: service started.
12/11/21 12:33:23z dataLog: Last log entry 12/11/21 12:33:20
12/11/21 12:33:23z historyLog: service started.
12/11/21 12:33:23z historyLog: first entry 11/27/21 16:27:00
12/11/21 12:33:27z deletelog=current command received.
12/11/21 12:33:30z Real Time Clock is running. Unix time 1639226010
12/11/21 12:33:30z Reset reason: Software/System restart
12/11/21 12:33:30z Trace: 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[14], 1:6[4], 14:0, 14:4, 14:5, 14:7, 14:8, 1:6[6], 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:21, 10:21
12/11/21 12:33:30z ESP8266 ID: 12704066, RTC PCF8523
12/11/21 12:33:30z IoTaWatt 5.0, Firmware version 02_07_04
12/11/21 12:33:30z SPIFFS mounted.
12/11/21 12:33:30z Local time zone: +0:00, using DST/BST when in effect.
12/11/21 12:33:30z device name: IotaWatt
12/11/21 12:33:30z HTTP server started
12/11/21 12:33:30z influxDB_v1: Starting, interval:10, url:[blanked out]
12/11/21 12:33:30z timeSync: service started.
12/11/21 12:33:30z statService: started.
12/11/21 12:33:30z dataLog: service started.
12/11/21 12:33:30z dataLog: New current log created.
12/11/21 12:33:30z dataLog: Last history entry: 11/27/21 18:07:00
12/11/21 12:33:36z WiFi connected. SSID=riverside-services_IoT, IP=192.168.2.65, channel=11, RSSI -77db
12/11/21 12:33:36z MDNS responder started for hostname IotaWatt
12/11/21 12:33:36z LLMNR responder started for hostname IotaWatt
12/11/21 12:33:36z Updater: service started. Auto-update class is BETA
12/11/21 12:33:37z Updater: Auto-update is current for class BETA.
12/11/21 12:34:04z influxDB_v1: Start posting at 12/11/21 12:33:40
12/11/21 12:34:35z historyLog: service started.
12/11/21 12:34:35z historyLog: Last log entry 11/27/21 18:07:00
12/11/21 12:42:49z Restart command received.
12/11/21 12:42:51z Real Time Clock is running. Unix time 1639226571
12/11/21 12:42:51z Reset reason: Software/System restart
12/11/21 12:42:51z Trace: 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[14], 1:6[4], 14:0, 1:6[6], 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
12/11/21 12:42:51z ESP8266 ID: 12704066, RTC PCF8523
12/11/21 12:42:51z IoTaWatt 5.0, Firmware version 02_07_04
12/11/21 12:42:51z SPIFFS mounted.
12/11/21 12:42:51z Local time zone: +0:00, using DST/BST when in effect.
12/11/21 12:42:51z device name: IotaWatt
12/11/21 12:42:51z HTTP server started
12/11/21 12:42:51z influxDB_v1: Starting, interval:10, url:[blanked out]
12/11/21 12:42:51z timeSync: service started.
12/11/21 12:42:51z statService: started.
12/11/21 12:42:51z dataLog: service started.
12/11/21 12:42:51z dataLog: Last log entry 12/11/21 12:42:45
12/11/21 12:42:51z historyLog: service started.
12/11/21 12:42:51z historyLog: Last log entry 12/10/21 23:51:00
12/11/21 12:43:04z WiFi connected. SSID=riverside-services_IoT, IP=192.168.2.65, channel=11, RSSI -78db
12/11/21 12:43:04z MDNS responder started for hostname IotaWatt
12/11/21 12:43:04z LLMNR responder started for hostname IotaWatt
12/11/21 12:43:04z Updater: service started. Auto-update class is BETA
12/11/21 12:43:06z Updater: Auto-update is current for class BETA.
