Hi all,
I purchased and installed an IoTaWatt last July and it has been great. I have had zero issues with the device pushing data into my InfluxDB server until March 15th. I should note that nothing has changed with my network or InfluxDB, and all other devices (IoT, servers, desktops, etc.) are able to log successfully.
The IoTaWatt was running 02_05_02 on the MINOR update channel. I changed to a new database and reset passwords. Still nothing. I changed to BETA channel and it updated to 02_05_05. Same thing, no go.
You’ll note that the InfluxDB server is on one subnet and the IoTaWatt is on another - along with all the other IoT that is reporting fine.
Would it be possible to turn on debug logging on the IoTaWatt?
This is what the log is currently telling me:
3/21/20 23:36:37z Real Time Clock is running. Unix time 1584833797
3/21/20 23:36:37z Reset reason: Software/System restart
3/21/20 23:36:37z Trace: 1:5[7], 7:0, 7:5, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:5, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:5, 1:6, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
3/21/20 23:36:37z ESP8266 ChipID: 2518017
3/21/20 23:36:37z IoTaWatt 5.0, Firmware version 02_05_05
3/21/20 23:36:37z SPIFFS mounted.
3/21/20 16:36:37 Local time zone: -8:00
3/21/20 16:36:37 Using Daylight Saving Time (BST) when in effect.
3/21/20 16:36:37 device name: IotaWatt
3/21/20 16:36:37 HTTP server started
3/21/20 16:36:37 timeSync: service started.
3/21/20 16:36:37 statService: started.
3/21/20 16:36:38 dataLog: service started.
3/21/20 16:36:39 dataLog: Last log entry 03/21/20 16:36:35
3/21/20 16:36:39 historyLog: service started.
3/21/20 16:36:40 historyLog: Last log entry 03/21/20 16:36:00
3/21/20 16:36:42 influxDB: started, url=http://192.168.2.10:8086, db=iotawatt3, interval=5
3/21/20 16:36:42 Updater: service started. Auto-update class is BETA
3/21/20 16:36:42 WiFi connected. SSID=REDATED, IP=192.168.50.32, channel=1, RSSI -60db
3/21/20 16:36:44 Updater: Auto-update is current for class BETA.
3/21/20 16:40:22 influxDB: last entry query failed: -4, retrying.
