Hi,
I have a bunch of push-pin CTs (rated 60A in, 0.45V out) from an old TED (energy detective).
Can I solder stereo jacks onto them and use them with the IotaWatt I just purchased?
If so, how should I solder the wire onto jacks provided? I would be soldering a two-wire (pos/neg) onto a stereo jack that technically is three-wire (right, left, and ground). Am I correct to assume that I simply don’t ground the jack and solder the two-wire pos to the jack right and vice versa for the neg wire?
Thanks!
