Bought a new SD Card. Copied all the files from the SD Folder on Git. Plugged in new card and unable to restart unit. My old SD card in gone, computer will not recognize it. Is there a way to get this IotaWatt unit working again? Thank you
What is the failure mode? What is the LED state when you power up?
Solid green. Tried setting it up with WiFi and cannot see unit. Does it need alot of time to recognize new card? Thank you very much for the reply
That indicates the unit is connected to WiFi. Have you tried to access iotawatt.local?
No did not try that. I stepped away from the unit but when I get back I will give that a try. Thank you.
It works!! Cannot thank you enough!! I just want to say this unit has an excellent design! I was able to get my config file from the unit and use that to set up. Looking forward to these being available again! I have had this unit for a very long time. I bought a high endurance SD card so hopefully that lasts a bit longer. Thank you
