Iotawatt device automatically upgraded itself to 2.06.02 9 days ago. Since then it has restarted three times, each time with the message: Reset reason: Exception.
I only noticed today. It is set to send data to local emoncms instance, and graphs weren’t showing up. I can now see that it is resending all historical data. Screenshot shows part of the “Status” screen.
And here is the message log since the upgrade
5/03/21 19:41:28z Updater: Update from 02_05_12 to 02_06_02
5/03/21 19:41:28z Updater: download 02_06_02
5/03/21 19:41:34z Updater: Release downloaded 6374ms, size 830712
5/03/21 19:41:42z Updater: signature verified
5/03/21 19:41:51z Updater: firmware upgraded to version 02_06_02
5/03/21 19:41:51z Updater: Firmware updated, restarting.
5/03/21 18:41:59z Real Time Clock is running. Unix time 1620067319
5/03/21 18:41:59z Reset reason: Software/System restart
5/03/21 18:41:59z Trace: 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:20, 21:21, 21:21[1], 21:30, 21:99, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:6, 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:7
5/03/21 18:41:59z ESP8266 ChipID: 2428636
5/03/21 18:41:59z IoTaWatt 5.0, Firmware version 02_06_02
5/03/21 18:41:59z Updater: Installing update files for version 02_06_02
5/03/21 18:41:59z Updater: Installing GRAPH.JS
5/03/21 18:41:59z Updater: Installing GRAPH2.HTM
5/03/21 18:41:59z Updater: Installing GRAPH2.JS
5/03/21 18:41:59z Updater: Installing INDEX.HTM
5/03/21 18:41:59z Updater: Installing TABLES.TXT
5/03/21 18:41:59z Updater: Installing CNFSTYLE.CSS
5/03/21 18:42:00z Updater: Installing EDIT.HTM
5/03/21 18:42:00z Updater: Installing GRAPH.HTM
5/03/21 18:42:00z Updater: Installation complete.
5/03/21 18:42:00z SPIFFS mounted.
5/03/21 19:42:00z Local time zone: +0:00
5/03/21 19:42:00z Using Daylight Saving Time (BST) when in effect.
5/03/21 19:42:00z device name: energi
5/03/21 19:42:00z HTTP server started
5/03/21 19:42:00z emoncms: Starting, interval:10, url:http://emoncms.graabek.com
5/03/21 19:42:00z timeSync: service started.
5/03/21 19:42:00z statService: started.
5/03/21 19:42:00z dataLog: service started.
5/03/21 19:42:02z dataLog: Last log entry 05/03/21 19:41:30
5/03/21 19:42:02z historyLog: service started.
5/03/21 19:42:02z historyLog: Last log entry 05/03/21 19:41:00
5/03/21 19:42:05z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=1, RSSI -71db
5/03/21 19:42:05z MDNS responder started for hostname energi
5/03/21 19:42:05z LLMNR responder started for hostname energi
5/03/21 19:42:05z Updater: service started. Auto-update class is MINOR
5/03/21 19:42:05z emoncms: Start posting at 05/03/21 19:41:20
5/03/21 19:42:07z Updater: Auto-update is current for class MINOR.
5/04/21 03:02:43z WiFi disconnected.
5/04/21 03:02:46z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=6, RSSI -73db
5/04/21 23:28:54z Real Time Clock is running. Unix time 1620170934
5/04/21 23:28:54z Reset reason: Exception
5/04/21 23:28:54z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
5/04/21 23:28:54z ESP8266 ChipID: 2428636
5/04/21 23:28:54z IoTaWatt 5.0, Firmware version 02_06_02
5/04/21 23:28:54z SPIFFS mounted.
5/05/21 00:28:54z Local time zone: +0:00
5/05/21 00:28:54z Using Daylight Saving Time (BST) when in effect.
5/05/21 00:28:54z device name: energi
5/05/21 00:28:54z HTTP server started
5/05/21 00:28:54z emoncms: Starting, interval:10, url:http://emoncms.graabek.com
5/05/21 00:28:54z timeSync: service started.
5/05/21 00:28:54z statService: started.
5/05/21 00:28:54z dataLog: service started.
5/05/21 00:28:55z dataLog: Last log entry 05/05/21 00:28:50
5/05/21 00:28:55z historyLog: service started.
5/05/21 00:28:56z historyLog: Last log entry 05/05/21 00:28:00
5/05/21 00:28:59z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=6, RSSI -75db
5/05/21 00:28:59z MDNS responder started for hostname energi
5/05/21 00:28:59z LLMNR responder started for hostname energi
5/05/21 00:28:59z Updater: service started. Auto-update class is MINOR
5/05/21 00:28:59z emoncms: Start posting at 05/05/21 00:26:30
5/05/21 00:29:01z Updater: Auto-update is current for class MINOR.
5/05/21 03:00:21z WiFi disconnected.
5/05/21 03:00:24z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=13, RSSI -73db
5/06/21 03:02:36z WiFi disconnected.
5/06/21 03:02:42z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=13, RSSI -80db
5/10/21 03:01:25z WiFi disconnected.
5/10/21 03:01:26z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=13, RSSI -75db
5/10/21 09:50:44z Real Time Clock is running. Unix time 1620640244
5/10/21 09:50:44z Reset reason: Exception
5/10/21 09:50:44z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
5/10/21 09:50:44z ESP8266 ChipID: 2428636
5/10/21 09:50:44z IoTaWatt 5.0, Firmware version 02_06_02
5/10/21 09:50:44z SPIFFS mounted.
5/10/21 10:50:44z Local time zone: +0:00
5/10/21 10:50:44z Using Daylight Saving Time (BST) when in effect.
5/10/21 10:50:44z device name: energi
5/10/21 10:50:44z HTTP server started
5/10/21 10:50:44z emoncms: Starting, interval:10, url:http://emoncms.graabek.com
5/10/21 10:50:44z timeSync: service started.
5/10/21 10:50:44z statService: started.
5/10/21 10:50:44z dataLog: service started.
5/10/21 10:50:45z dataLog: Last log entry 05/10/21 10:50:40
5/10/21 10:50:45z historyLog: service started.
5/10/21 10:50:46z historyLog: Last log entry 05/10/21 10:50:00
5/10/21 10:50:49z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=13, RSSI -75db
5/10/21 10:50:49z MDNS responder started for hostname energi
5/10/21 10:50:49z LLMNR responder started for hostname energi
5/10/21 10:50:49z Updater: service started. Auto-update class is MINOR
5/10/21 10:50:49z emoncms: Start posting at 05/10/21 10:48:20
5/10/21 10:50:51z Updater: Auto-update is current for class MINOR.
5/12/21 03:01:33z WiFi disconnected.
5/12/21 03:01:37z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=1, RSSI -72db
5/12/21 06:48:22z Real Time Clock is running. Unix time 1620802102
5/12/21 06:48:22z Reset reason: Exception
5/12/21 06:48:22z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
5/12/21 06:48:22z ESP8266 ChipID: 2428636
5/12/21 06:48:22z IoTaWatt 5.0, Firmware version 02_06_02
5/12/21 06:48:22z SPIFFS mounted.
5/12/21 07:48:22z Local time zone: +0:00
5/12/21 07:48:22z Using Daylight Saving Time (BST) when in effect.
5/12/21 07:48:22z device name: energi
5/12/21 07:48:22z HTTP server started
5/12/21 07:48:22z emoncms: Starting, interval:10, url:http://emoncms.graabek.com
5/12/21 07:48:22z timeSync: service started.
5/12/21 07:48:22z statService: started.
5/12/21 07:48:22z dataLog: service started.
5/12/21 07:48:24z dataLog: Last log entry 05/12/21 07:48:20
5/12/21 07:48:24z historyLog: service started.
5/12/21 07:48:24z historyLog: Last log entry 05/12/21 07:48:00
5/12/21 07:48:29z WiFi connected. SSID=38ch, IP=172.16.1.9, channel=1, RSSI -71db
5/12/21 07:48:29z MDNS responder started for hostname energi
5/12/21 07:48:29z LLMNR responder started for hostname energi
5/12/21 07:48:29z Updater: service started. Auto-update class is MINOR
5/12/21 07:48:29z emoncms: Start posting at 05/11/20 21:17:10
5/12/21 07:48:31z Updater: Auto-update is current for class MINOR.
