I would like to replace the 2gb sdcard inside my Iotawatt (DIY), so I bought an industrial Kingston 8gb sdcit2/8gb.
I copied old files inside and put it in my iotawatt, but not response, except solid red led, no matter what.
I tried with sd card files from github, formatting in fat16/fat32… nothing.
I tried any cheap sd card, and it works.
Solid red, for a production IotaWatt, would actually be a red glow rather than bright red and would mean that the unit has not connected to WiFi. There is also a condition that I’ve seen where the ESP8266 nodeMCU has an electrical problem and never actually boots up, leaving the led solid red. Since you have a DIY unit, I would suspect the later.
Some SD card always work on this iotawatt unit and other units I have, other SD cards never work on iotawatt units.
I think I found something, I hope.
Here is the tests I made.
I put the SD card inside, 19AC on, and I plug micro USB 5V.
ADATA SDHC I class 1 16gb : red glow.
ExtremePRO SDHC I class 1 16gb : works.
SandDisk SDHC I class 1 32gb : works.
Shandian SDHC I class 1 16gb : red glow.
OLECO I SDHC class 1 16gb : works.
Kingston INDUSTRIAL SDHC class 10 8gb : red glow.
Now I plug 19AC on, microUSB 5V and quickly insert Sd card
ADATA SDHC I class 1 16gb : works.
Shandian SDHC I class 1 16gb : works.
Kingston INDUSTRIAL SDHC class 10 8gb : works.
But once I reset the esp8266, red glow, and I have to insert sd card quickly after power on esp8266 to make the unit work again.
If you are getting a solid (or glowing) red led with no SDcard inserted, the problem is not the SDcard. You should get green-red-red sequence. It is a problem with the PCB. I really can’t help you with that.
No SD card, I have green-red-red.
With “bad” SD card inserted, I have red glow.
When I insert “bad” SD card right after power the unit on, green blink.
