This is the same network I’ve setup heaps of units on, so I don’t think it’s hostile to others.
I just took one of the units to a new network. It worked on this new network.
I’ll paste the log of this (‘new’) unit below. Note the change of network for the last entry when it succeeded.
For extra completeness, I then tested a previously an old working unit on the original network. It’s a v5 which was configured ok previously:
Reset reason: Software/System restart
Trace: 255:21[69], 196:11[172], 239:75[69], 54:9[247], 103:45[95], 199:125[252], 218:81[128], 90:166[249], 170:13[181], 1:239[31], 104:59[62], 4:122[234], 242:194[80], 28:102[115], 203:164[224], 177:246[249], 252:196[51], 51:60[235], 63:31[235], 167:255[182], 107:228[231], 145:182[190], 127:29[84], 70:231[233], 150:164[202], 165:66[115], 55:1[35], 137:239[85], 90:22[72], 34:62[61], 169:162[176], 14:50[159]
ESP8266 ChipID: 8559155
IoTaWatt 5.0, Firmware version 02_06_02
SPIFFS mounted.
Local time zone: +0:00
device name: IotaWatt
Connecting with WiFiManager.
Reset reason: External System
Trace: 255:21[68], 196:11[172], 239:75[68], 54:9[247], 39:47[95], 199:125[254], 242:81[136], 90:166[248], 170:15[181], 1:207[31], 104:59[62], 4:122[234], 243:194[80], 12:98[115], 203:164[224], 164:247[249], 252:196[51], 51:188[235], 191:31[235], 167:255[182], 106:228[231], 145:246[190], 127:29[84], 64:247[233], 150:36[202], 169:70[115], 55:129[99], 136:239[85], 90:22[72], 34:62[61], 169:162[176], 14:50[191]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -55db
Disconnect command received.
timeSync: service started.
statService: started.
WiFi disconnected.
WiFi disconnected more than 60 minutes, restarting.
Trace: 8:2, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 1:6[6], 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:2
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -60db
Trace: 228:21[68], 196:11[172], 239:75[85], 62:9[247], 103:47[95], 199:245[252], 250:81[136], 94:166[248], 170:141[181], 1:223[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 203:164[232], 160:247[249], 252:212[51], 19:188[235], 63:15[235], 135:253[182], 107:224[231], 145:182[254], 127:29[86], 68:119[249], 146:36[202], 173:70[115], 55:129[3], 137:239[213], 88:22[72], 34:190[61], 169:34[176], 14:50[159]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -45db
Trace: 239:21[196], 196:11[172], 239:75[85], 62:9[247], 39:47[95], 199:253[252], 250:81[232], 94:166[248], 170:79[181], 65:223[31], 104:63[62], 4:122[234], 243:194[80], 28:98[115], 203:164[224], 160:247[249], 248:212[51], 17:60[235], 63:15[235], 167:255[182], 106:228[231], 145:246[254], 119:29[212], 64:119[225], 150:36[202], 161:70[114], 55:1[67], 137:239[197], 90:22[72], 34:190[61], 169:34[176], 14:50[191]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -48db
Trace: 254:21[69], 196:11[172], 239:75[85], 54:9[247], 103:47[95], 199:125[254], 250:80[192], 94:166[248], 170:13[181], 65:223[31], 104:59[62], 4:122[234], 242:194[80], 12:98[115], 203:164[224], 160:247[249], 248:196[51], 17:44[251], 191:31[235], 167:255[182], 106:196[231], 145:182[190], 127:29[84], 68:103[249], 150:36[202], 173:70[115], 55:129[67], 137:238[197], 88:20[72], 34:190[61], 169:162[176], 14:50[191]
SPIFFS mounted.
HTTP server started
Trace: 252:21[68], 192:11[172], 239:75[69], 54:9[247], 103:47[95], 199:253[252], 250:81[136], 90:166[248], 170:79[181], 65:223[31], 104:59[62], 4:122[234], 243:194[80], 12:98[115], 203:164[224], 160:231[248], 250:196[51], 17:56[235], 191:15[235], 7:255[182], 107:228[231], 145:246[158], 127:29[84], 68:119[233], 150:36[202], 169:70[115], 55:129[35], 137:239[197], 90:22[73], 34:190[61], 169:34[176], 14:50[191]
SPIFFS mounted.
HTTP server started
Trace: 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -57db
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -56db
SPIFFS mounted.
HTTP server started
Trace: 229:21[69], 196:11[172], 239:75[69], 54:9[247], 39:47[95], 199:253[252], 250:81[160], 94:166[249], 170:143[181], 65:207[31], 104:51[62], 4:122[234], 242:194[80], 28:98[115], 203:164[224], 161:247[249], 254:84[51], 17:60[235], 191:13[235], 167:255[182], 106:224[231], 145:182[190], 127:29[214], 64:115[225], 146:36[202], 173:70[115], 55:129[19], 137:239[197], 90:22[72], 34:190[60], 169:162[176], 14:50[191]
SPIFFS mounted.
HTTP server started
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -54db
Trace: 246:21[197], 196:11[172], 239:75[85], 54:9[247], 39:47[95], 199:253[252], 250:81[160], 94:166[248], 42:143[181], 65:223[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 203:164[224], 160:247[249], 254:196[51], 17:40[235], 63:15[235], 167:255[182], 122:224[231], 145:182[191], 127:29[214], 64:247[233], 150:52[202], 169:70[115], 55:129[67], 137:239[197], 90:22[72], 34:190[52], 169:162[176], 14:50[191]
SPIFFS mounted.
HTTP server started
Trace: 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 8:4
SPIFFS mounted.
HTTP server started
SPIFFS mounted.
HTTP server started
Trace: 247:21[69], 196:11[172], 239:75[85], 54:9[247], 103:47[95], 199:253[252], 234:81[128], 90:166[249], 42:141[181], 65:223[31], 104:59[62], 4:122[234], 242:194[80], 28:102[115], 203:132[224], 160:230[249], 250:68[51], 51:44[251], 191:15[235], 167:254[182], 106:224[231], 145:246[190], 127:29[84], 68:119[233], 150:36[200], 161:70[115], 55:129[3], 137:239[197], 90:22[73], 34:190[61], 169:162[176], 14:50[159]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -61db
Trace: 228:21[68], 196:11[172], 239:75[69], 62:9[247], 39:47[95], 199:253[254], 250:81[140], 90:166[248], 42:15[181], 1:255[31], 104:59[62], 5:122[234], 242:194[80], 28:98[115], 219:36[224], 160:247[249], 252:196[51], 81:104[235], 191:15[235], 167:255[182], 106:196[231], 145:182[222], 127:29[86], 64:103[233], 150:36[200], 173:70[115], 55:129[3], 137:239[197], 90:22[72], 34:190[61], 169:162[176], 14:50[159]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -70db
Trace: 244:21[69], 196:11[172], 239:75[85], 54:9[247], 39:47[95], 199:245[254], 242:81[224], 94:166[248], 42:79[181], 1:223[31], 104:63[62], 4:122[234], 242:194[80], 28:98[115], 203:164[224], 160:247[248], 250:196[51], 17:40[235], 127:31[235], 167:255[182], 122:224[231], 145:247[190], 127:29[92], 68:115[233], 150:36[202], 165:70[115], 55:129[83], 136:239[85], 90:22[72], 50:190[61], 169:162[176], 14:50[31]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -66db
Trace: 246:21[69], 196:11[172], 239:75[69], 54:9[247], 103:47[95], 199:245[252], 250:81[128], 94:166[248], 42:143[149], 65:239[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 203:165[224], 160:247[249], 248:212[51], 17:124[235], 191:15[239], 167:255[182], 106:196[231], 145:246[158], 127:29[84], 68:243[249], 150:36[202], 161:70[115], 55:129[51], 136:238[213], 90:22[105], 38:190[61], 169:162[176], 14:50[63]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -64db
Trace: 246:21[69], 68:11[172], 239:75[69], 54:9[247], 103:47[95], 199:125[252], 242:81[160], 94:166[185], 42:143[181], 65:223[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 219:164[224], 160:247[248], 252:196[51], 113:60[235], 191:31[235], 167:255[182], 123:196[231], 145:182[254], 127:157[84], 64:119[233], 150:38[202], 165:70[115], 55:129[115], 137:239[197], 88:22[72], 38:62[189], 169:162[176], 14:50[159]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -67db
Trace: 230:21[69], 192:11[172], 239:75[69], 62:9[247], 103:47[95], 199:245[254], 250:81[128], 90:166[248], 42:143[181], 65:255[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 203:164[224], 161:231[249], 248:84[51], 51:40[235], 191:31[239], 167:253[182], 107:228[231], 145:182[223], 127:29[86], 64:231[233], 150:36[200], 161:70[115], 55:129[3], 137:239[197], 90:22[72], 34:190[60], 169:162[144], 14:50[191]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -69db
Trace: 246:21[68], 64:11[172], 239:75[85], 62:9[247], 103:47[95], 199:253[252], 250:81[168], 90:166[249], 42:13[181], 65:255[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 203:36[232], 160:247[249], 252:84[51], 49:40[235], 191:29[235], 167:255[182], 107:228[231], 145:182[158], 127:29[214], 64:119[241], 150:36[202], 161:70[115], 55:129[67], 137:239[229], 88:22[104], 34:190[189], 169:162[176], 14:50[63]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=TelstraD8065D, IP=192.168.0.94, channel=5, RSSI -44db
7/04/21 03:30:12z timeSync: RTC initalized to NTP time
7/04/21 03:30:40z dataLog: service started.
7/04/21 03:30:40z dataLog: New current log created.
7/04/21 04:41:12z dataLog: datalog WDT - restarting
7/04/21 04:41:13z Real Time Clock is running. Unix time 1625373673
7/04/21 04:41:13z Reset reason: Software/System restart
7/04/21 04:41:13z Trace: 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2
7/04/21 04:41:13z ESP8266 ChipID: 8559155
7/04/21 04:41:13z IoTaWatt 5.0, Firmware version 02_06_02
7/04/21 04:41:13z SPIFFS mounted.
7/04/21 04:41:13z Local time zone: +0:00
7/04/21 04:41:13z device name: IotaWatt
7/04/21 04:41:13z HTTP server started
7/04/21 04:41:13z timeSync: service started.
7/04/21 04:41:13z statService: started.
7/04/21 07:03:59z Real Time Clock is running. Unix time 1625382239
7/04/21 07:03:59z Power failure detected.
7/04/21 07:03:59z Reset reason: External System
7/04/21 07:03:59z ESP8266 ChipID: 8559155
7/04/21 07:03:59z IoTaWatt 5.0, Firmware version 02_06_02
7/04/21 07:03:59z SPIFFS mounted.
7/04/21 07:03:59z Local time zone: +0:00
7/04/21 07:03:59z device name: IotaWatt
7/04/21 07:04:02z Connecting with WiFiManager.
7/04/21 07:04:46z HTTP server started
7/04/21 07:04:46z WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -60db
7/04/21 07:04:46z MDNS responder started for hostname IotaWatt
7/04/21 07:04:46z LLMNR responder started for hostname IotaWatt
Trace: 255:21[69], 196:11[172], 239:75[85], 54:9[247], 39:47[95], 199:245[254], 242:81[160], 90:166[248], 42:143[181], 65:223[31], 104:59[62], 4:122[234], 242:194[80], 28:98[115], 219:165[228], 177:247[248], 252:84[51], 17:44[235], 63:29[235], 167:255[182], 107:228[231], 145:246[191], 127:29[212], 64:247[233], 150:36[202], 161:70[119], 55:129[19], 137:239[213], 90:22[104], 34:190[61], 169:162[176], 14:50[31]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=NetComm 0405, IP=192.168.0.215, channel=1, RSSI -65db
