bob@iotawatt using Forum for contact as requested re ‘cracked SD card, my bad’.
C:\Users\dp>ipconfig ::
Windows IP Configuration
Wireless LAN adapter Local Area Connection* 12:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : home
IPv6 Address. . . . . . . . . . . : 2600:6c44:393f:c876:0:6eda:d246:17b1
IPv6 Address. . . . . . . . . . . : 2600:6c44:393f:c876:d86c:2e9c:9b99:af08
Temporary IPv6 Address. . . . . . : 2600:6c44:393f:c876:cce3:c5d9:16b8:acca
Link-local IPv6 Address . . . . . : fe80::d86c:2e9c:9b99:af08%4
IPv4 Address. . . . . . . . . . . : 192.168.1.4
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : fe80::bad9:4dff:fe2b:9cf0%4
192.168.1.1
Wireless LAN adapter Local Area Connection* 17:
Link-local IPv6 Address . . . . . : fe80::95bb:df48:611a:f04a%16
Autoconfiguration IPv4 Address. . : 169.254.240.74
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Ethernet adapter Bluetooth Network Connection:
C:\Users\dp>
IPv4 192.168.1.4 > > “Unable to connect
Firefox can’t establish a connection to the server at 192.168.1.4”
Couple hours reviewing entire wiki before attempting 1st connect and then did ‘connecting’ step by step (at age 72 I study first).
9vm & 5v. >> brief green, pause, RGG . >>
Cellphone showed ‘iota12707449’ (not ESPnnnnnn) tried to log on (2.4Ghz) >>
Psswrd rqstd >> copied / pasted from wiki ‘IotaWatt’ >> Pswrd incorrect >>
Trblshoot rcmnd : IoTaWatt.local/command?disconnect=yes
>> “Unable to connect
Firefox can’t establish a connection to the server at 192.168.1.4” (same as initial above never gets to config display shown in wiki >>
Tried many permutations and other suggestions. Occasionally RGG would go RRG. I pwr cycled >>
brief G pause RGG as initial.
Cracked SD removing to see files stored >> wouldn’t reboot >> RRG
Per your suggestion new SD (64GB SanDisk) cloned gits you sent to SD root >>
Still won’t boot but get RRG but / and don’t see a network on phone (or laptop).
Would like to send iotawatt unit back for eval / repair / qualification. Will hang on to CTs and wait for return. I will pay postage and inlude both SD’s (the broken and my clone).
Do I need an RMA or other? Please advise how to proceed.
I appreciate the help and apologize for the trouble.
dp
