I can connect via the serial port but I can’t make it useful. I am sure I am doing something wrong. I pulled the SD card as you recommended and opened the itoamsgs.txt file…
I am shocked. It thinks everything is just fine. The restart logs indicate that it is connected to WIFI with no issues. It shows the IP address I am using. Below are the last several entries. By all indications, it should work fine. Yet there is no update to influx, I can’t access it via http, I can’t even ping it. My router is not showing any traffic in or out. I have another unit that works just fine on the main panel (after dealing with a failed SD card) This one has been in my shed and worked flawlessly up until recently.
Very odd. Any other ideas?
Thank you
Here are some log entries:
3/27/23 18:02:40z Real Time Clock is running. Unix time 1679940160
3/27/23 18:02:40z Reset reason: Software Watchdog
3/27/23 18:02:40z Trace: 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 31:1, 1:6[6], 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 32:60, 32:60, 32:60
3/27/23 18:02:40z ESP8266 ID: 14609626, RTC PCF8523 (68)
3/27/23 18:02:40z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 18:02:40z SPIFFS mounted.
3/27/23 17:32:40 Local time zone: +0:-30
3/27/23 17:32:40 device name: shediota
3/27/23 17:32:40 HTTP server started
3/27/23 17:32:40 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
3/27/23 17:32:40 timeSync: service started.
3/27/23 17:32:41 statService: started.
3/27/23 17:32:41 dataLog: service started.
3/27/23 17:32:49 dataLog: Last log entry 03/27/23 17:32:35
3/27/23 17:32:49 Updater: service started. Auto-update class is MINOR
3/27/23 17:32:49 WiFi connected. SSID=homenet3n, IP=192.168.0.91, channel=10, RSSI -50db
3/27/23 17:32:49 historyLog: service started.
3/27/23 17:32:55 historyLog: Last log entry 03/27/23 17:32:00
3/27/23 17:32:55 Main_panel: Started
3/27/23 17:32:59 Main_panel: Last log entry 03/27/23 15:47:05
3/27/23 17:32:59 Updater: Auto-update is current for class MINOR.
3/27/23 17:33:03 influxDB_v1: Start posting at 12/11/22 08:11:30
3/27/23 18:03:08z Real Time Clock is running. Unix time 1679940188
3/27/23 18:03:08z Reset reason: Software Watchdog
3/27/23 18:03:08z Trace: 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 31:1, 1:6[6], 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 32:60, 32:60, 32:60
3/27/23 18:03:08z ESP8266 ID: 14609626, RTC PCF8523 (68)
3/27/23 18:03:08z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 18:03:08z SPIFFS mounted.
3/27/23 17:33:08 Local time zone: +0:-30
3/27/23 17:33:08 device name: shediota
3/27/23 17:33:08 HTTP server started
3/27/23 17:33:08 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
3/27/23 17:33:08 timeSync: service started.
3/27/23 17:33:09 statService: started.
3/27/23 17:33:09 dataLog: service started.
3/27/23 17:33:14 dataLog: Last log entry 03/27/23 17:33:00
3/27/23 17:33:14 Updater: service started. Auto-update class is MINOR
3/27/23 17:33:14 WiFi connected. SSID=homenet3n, IP=192.168.0.91, channel=10, RSSI -50db
3/27/23 17:33:15 historyLog: service started.
3/27/23 17:33:21 historyLog: Last log entry 03/27/23 17:33:00
3/27/23 17:33:21 Updater: Auto-update is current for class MINOR.
3/27/23 17:33:21 Main_panel: Started
3/27/23 17:33:25 Main_panel: Last log entry 03/27/23 15:47:05
3/27/23 17:33:29 influxDB_v1: Start posting at 12/11/22 08:11:30
3/27/23 18:03:32z Real Time Clock is running. Unix time 1679940212
3/27/23 18:03:32z Reset reason: Software Watchdog
3/27/23 18:03:32z Trace: 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 31:1, 1:6[6], 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 32:60, 32:60, 32:60
3/27/23 18:03:32z ESP8266 ID: 14609626, RTC PCF8523 (68)
3/27/23 18:03:32z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 18:03:32z SPIFFS mounted.
3/27/23 17:33:32 Local time zone: +0:-30
3/27/23 17:33:32 device name: shediota
3/27/23 17:33:32 HTTP server started
3/27/23 17:33:32 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
3/27/23 17:33:32 timeSync: service started.
3/27/23 17:33:33 statService: started.
3/27/23 17:33:33 dataLog: service started.
3/27/23 17:33:38 dataLog: Last log entry 03/27/23 17:33:25
3/27/23 17:33:38 Updater: service started. Auto-update class is MINOR
3/27/23 17:33:38 WiFi connected. SSID=homenet3n, IP=10.0.0.13, channel=10, RSSI -51db
3/27/23 17:33:45 historyLog: service started.
3/27/23 17:33:51 historyLog: Last log entry 03/27/23 17:33:00
3/27/23 17:33:52 Main_panel: Started
3/27/23 17:33:56 Main_panel: Last log entry 03/27/23 15:47:05
3/27/23 17:34:07 Updater: Invalid response from server. HTTPcode: -4
3/28/23 17:34:39 timeSync: No time update in last 24 hours.
3/29/23 17:35:39 timeSync: No time update in last 24 hours.
3/30/23 17:36:39 timeSync: No time update in last 24 hours.
3/31/23 17:37:39 timeSync: No time update in last 24 hours.
4/01/23 02:15:18z Real Time Clock is running. Unix time 1680315318
4/01/23 02:15:18z Reset Reason: Power-fail restart.
4/01/23 02:15:19z Real Time Clock is running. Unix time 1680315319
4/01/23 02:15:19z Reset Reason: Power-fail restart.
4/01/23 02:15:19z ESP8266 ID: 14609626, RTC PCF8523 (68)
4/01/23 02:15:19z IoTaWatt 5.0, Firmware version 02_08_02
4/01/23 02:15:19z SPIFFS mounted.
4/01/23 01:45:19 Local time zone: +0:-30
4/01/23 01:45:19 device name: shediota
4/01/23 01:45:22 Connecting with WiFiManager.
4/01/23 02:42:35z Real Time Clock is running. Unix time 1680316955
4/01/23 02:42:35z Reset Reason: Power-fail restart.
4/01/23 02:42:35z ESP8266 ID: 14609626, RTC PCF8523 (68)
4/01/23 02:42:35z IoTaWatt 5.0, Firmware version 02_08_02
4/01/23 02:42:35z SPIFFS mounted.
4/01/23 02:12:35 Local time zone: +0:-30
4/01/23 02:12:35 device name: shediota
4/01/23 02:12:38 Connecting with WiFiManager.
4/01/23 02:12:44 HTTP server started
4/01/23 02:12:45 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
4/01/23 02:12:45 WiFi connected. SSID=homenet3n, IP=192.168.0.91, channel=10, RSSI -53db
4/01/23 02:12:45 timeSync: service started.
4/01/23 02:12:45 statService: started.
4/01/23 02:12:45 Updater: service started. Auto-update class is MINOR
4/01/23 02:12:45 dataLog: service started.
4/01/23 02:12:50 dataLog: Last log entry 04/01/23 01:44:40
4/01/23 02:12:50 historyLog: service started.
4/01/23 02:12:54 historyLog: Last log entry 04/01/23 01:44:00
4/01/23 02:12:54 Updater: Auto-update is current for class MINOR.
4/01/23 02:12:54 Main_panel: Started
4/01/23 02:12:58 Main_panel: Last log entry 04/01/23 01:44:35
4/01/23 02:13:04 influxDB_v1: Start posting at 12/11/22 08:11:30
4/01/23 02:43:10z Real Time Clock is running. Unix time 1680316990
4/01/23 02:43:10z Reset reason: Software Watchdog
4/01/23 02:43:10z Trace: 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 31:1, 1:6[6], 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 32:60, 32:60, 32:60
4/01/23 02:43:10z ESP8266 ID: 14609626, RTC PCF8523 (68)
4/01/23 02:43:10z IoTaWatt 5.0, Firmware version 02_08_02
4/01/23 02:43:10z SPIFFS mounted.
4/01/23 02:13:10 Local time zone: +0:-30
4/01/23 02:13:10 device name: shediota
4/01/23 02:13:11 HTTP server started
4/01/23 02:13:11 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
4/01/23 02:13:11 timeSync: service started.
4/01/23 02:13:11 statService: started.
4/01/23 02:13:11 dataLog: service started.
4/01/23 02:13:16 dataLog: Last log entry 04/01/23 02:13:05
4/01/23 02:13:16 WiFi connected. SSID=homenet3n, IP=10.0.0.40, channel=10, RSSI -53db
4/01/23 02:13:16 Updater: service started. Auto-update class is MINOR
4/01/23 02:13:23 historyLog: service started.
4/01/23 02:13:25 historyLog: Last log entry 04/01/23 02:13:00
4/01/23 02:13:27 Main_panel: Started
4/01/23 02:13:29 Main_panel: Last log entry 04/01/23 01:45:45
4/01/23 02:13:44 Updater: Invalid response from server. HTTPcode: -4
4/01/23 02:44:31z Real Time Clock is running. Unix time 1680317071
4/01/23 02:44:31z Reset Reason: Power-fail restart.
4/01/23 02:44:31z ESP8266 ID: 14609626, RTC PCF8523 (68)
4/01/23 02:44:31z IoTaWatt 5.0, Firmware version 02_08_02
4/01/23 02:44:31z SPIFFS mounted.
4/01/23 02:14:31 Local time zone: +0:-30
4/01/23 02:14:31 device name: shediota
4/01/23 02:14:34 HTTP server started
4/01/23 02:14:34 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
4/01/23 02:14:34 WiFi connected. SSID=homenet3n, IP=10.0.0.40, channel=10, RSSI -60db
4/01/23 02:14:35 timeSync: service started.
4/01/23 02:14:35 statService: started.
4/01/23 02:14:35 Updater: service started. Auto-update class is MINOR
4/01/23 02:14:35 dataLog: service started.
4/01/23 10:51:06z Real Time Clock is running. Unix time 1680346266
4/01/23 10:51:06z Reset Reason: Power-fail restart.
4/01/23 10:51:06z ESP8266 ID: 14609626, RTC PCF8523 (68)
4/01/23 10:51:06z IoTaWatt 5.0, Firmware version 02_08_02
4/01/23 10:51:06z SPIFFS mounted.
4/01/23 10:21:06 Local time zone: +0:-30
4/01/23 10:21:06 device name: shediota
4/01/23 10:21:09 Connecting with WiFiManager.
4/01/23 10:21:15 HTTP server started
4/01/23 10:21:16 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
4/01/23 10:21:16 WiFi connected. SSID=homenet3n, IP=192.168.0.91, channel=10, RSSI -63db
4/01/23 10:21:16 timeSync: service started.
4/01/23 10:21:16 statService: started.
4/01/23 10:21:16 Updater: service started. Auto-update class is MINOR
4/01/23 10:21:16 dataLog: service started.
4/01/23 10:21:30 dataLog: Last log entry 04/01/23 02:14:00
4/01/23 10:21:30 historyLog: service started.
4/01/23 10:21:34 historyLog: Last log entry 04/01/23 02:14:00
4/01/23 10:21:34 Updater: Auto-update is current for class MINOR.
4/01/23 10:21:34 Main_panel: Started
4/01/23 10:21:38 Main_panel: Last log entry 04/01/23 02:13:55
4/01/23 10:21:43 influxDB_v1: Start posting at 12/11/22 08:11:30
4/01/23 10:51:47z Real Time Clock is running. Unix time 1680346307
4/01/23 10:51:47z Reset reason: Software Watchdog
4/01/23 10:51:47z Trace: 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 31:1, 1:6[6], 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 32:60, 32:60, 32:60
4/01/23 10:51:47z ESP8266 ID: 14609626, RTC PCF8523 (68)
4/01/23 10:51:47z IoTaWatt 5.0, Firmware version 02_08_02
4/01/23 10:51:47z SPIFFS mounted.
4/01/23 10:21:47 Local time zone: +0:-30
4/01/23 10:21:48 device name: shediota
4/01/23 10:21:48 HTTP server started
4/01/23 10:21:48 influxDB_v1: Starting, interval:10, url:http://192.168.0.235:8086
4/01/23 10:21:48 timeSync: service started.
4/01/23 10:21:48 statService: started.
4/01/23 10:21:48 dataLog: service started.
4/01/23 10:21:53 dataLog: Last log entry 04/01/23 10:21:40
4/01/23 10:21:54 WiFi connected. SSID=homenet3n, IP=192.168.0.91, channel=10, RSSI -66db
4/01/23 10:21:54 Updater: service started. Auto-update class is MINOR
4/01/23 10:21:54 historyLog: service started.
4/01/23 10:21:56 historyLog: Last log entry 04/01/23 02:14:00
4/01/23 10:21:59 Updater: Auto-update is current for class MINOR.
4/01/23 10:22:04 influxDB_v1: Start posting at 12/11/22 08:11:30
