Hi there,
I am not sure about what happened. Suddenly, without any reason I am not getting the measurements on influxdb anymore.
Firmware version: 02_08_02
I checked the status: Query failed, code 400, response: {“error”:"error parsing query: found 110, expcted
Tried to stop and start the influxdb service, reboot the device. No changes, I don’t get data anymore oninfluxdb.
I checked the logs:
7/28/23 08:26:56z Real Time Clock is running. Unix time 1690532816
7/28/23 08:26:56z Reset reason: Software/System restart
7/28/23 08:26:56z Trace: 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
7/28/23 08:26:56z ESP8266 ID: 15876447, RTC PCF8523 (68)
7/28/23 08:26:56z IoTaWatt 5.0, Firmware version 02_08_02
7/28/23 08:26:56z SPIFFS mounted.
7/28/23 10:26:56 Local time zone: +2:00
7/28/23 10:26:56 device name: IotaWatt
7/28/23 10:26:56 HTTP server started
7/28/23 10:26:56 influxDB_v1: Starting, interval:5, url:http://10.0.3.13:8086
7/28/23 10:26:56 timeSync: service started.
7/28/23 10:26:56 statService: started.
7/28/23 10:26:56 dataLog: service started.
7/28/23 10:26:56 dataLog: Last log entry 07/28/23 10:26:55
7/28/23 10:27:00 WiFi connected. SSID=200, IP=10.0.3.5, channel=6, RSSI -58db
7/28/23 10:27:00 Updater: service started. Auto-update class is MINOR
7/28/23 10:27:01 historyLog: service started.
7/28/23 10:27:01 historyLog: Last log entry 07/28/23 10:26:00
7/28/23 10:27:02 Updater: Auto-update is current for class MINOR.** Restart **
I even tried to post the data to another influxdb on a different machine. But no luck.
It was running perfectly since a couple of months ago and I have not made any change since then.
I would appreciate some help
