Hi.
Been using the IoTaWatt for a couple of months. Maybe every couple of weeks it becomes unavailable on my network. Power on / off fixes the issue.
I have changed power supplies + micro usb cable - no change.
Should I try a new micro SD card? What is the process for setting up a new card?
Other thoughts?
Thanks! Andrew
9/02/22 07:28:12 dataLog: service started.
9/02/22 07:28:12 dataLog: Last log entry 08/26/22 09:38:15
9/02/22 07:28:12 historyLog: service started.
9/02/22 07:28:12 historyLog: Last log entry 08/26/22 09:38:00
9/02/22 07:28:13 Updater: Auto-update is current for class MINOR.
9/02/22 10:28:48 Updater: Invalid response from server. HTTPcode: -4
9/03/22 01:51:55z Real Time Clock is running. Unix time 1662169915
9/03/22 01:51:55z Reset Reason: Power-fail restart.
9/03/22 01:51:55z ESP8266 ID: 15875855, RTC PCF8523 (68)
9/03/22 01:51:55z IoTaWatt 5.0, Firmware version 02_07_05
9/03/22 01:51:55z SPIFFS mounted.
9/03/22 13:51:55 Local time zone: +12:00, using DST/BST when in effect.
9/03/22 13:51:55 device name: IotaWatt
9/03/22 13:51:58 Connecting with WiFiManager.
9/03/22 13:52:03 HTTP server started
9/03/22 13:52:03 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=11, RSSI -54db
9/03/22 13:52:03 MDNS responder started for hostname IotaWatt
9/03/22 13:52:03 LLMNR responder started for hostname IotaWatt
9/03/22 13:52:03 timeSync: service started.
9/03/22 13:52:03 statService: started.
9/03/22 13:52:03 Updater: service started. Auto-update class is MINOR
9/03/22 13:52:03 dataLog: service started.
9/03/22 13:52:03 dataLog: Last log entry 09/02/22 12:42:10
9/03/22 13:52:04 historyLog: service started.
9/03/22 13:52:04 historyLog: Last log entry 09/02/22 12:42:00
9/03/22 13:52:05 Updater: Auto-update is current for class MINOR.
9/03/22 06:00:22z Real Time Clock is running. Unix time 1662184822
9/03/22 06:00:22z Reset Reason: Power-fail restart.
9/03/22 06:00:22z ESP8266 ID: 15875855, RTC PCF8523 (68)
9/03/22 06:00:22z IoTaWatt 5.0, Firmware version 02_07_05
9/03/22 06:00:22z SPIFFS mounted.
9/03/22 18:00:22 Local time zone: +12:00, using DST/BST when in effect.
9/03/22 18:00:22 device name: IotaWatt
9/03/22 18:00:25 Connecting with WiFiManager.
9/03/22 18:02:38 Did not connect after power-fail. Restarting to reset WiFi.
9/03/22 06:14:51z Real Time Clock is running. Unix time 1662185691
9/03/22 06:14:51z Reset Reason: Power-fail restart.
9/03/22 06:14:51z ESP8266 ID: 15875855, RTC PCF8523 (68)
9/03/22 06:14:51z IoTaWatt 5.0, Firmware version 02_07_05
9/03/22 06:14:51z SPIFFS mounted.
9/03/22 18:14:51 Local time zone: +12:00, using DST/BST when in effect.
9/03/22 18:14:51 device name: IotaWatt
9/03/22 18:14:54 Connecting with WiFiManager.
9/03/22 18:14:59 HTTP server started
9/03/22 18:14:59 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=2, RSSI -57db
9/03/22 18:14:59 MDNS responder started for hostname IotaWatt
9/03/22 18:14:59 LLMNR responder started for hostname IotaWatt
9/03/22 18:14:59 timeSync: service started.
9/03/22 18:14:59 statService: started.
9/03/22 18:14:59 Updater: service started. Auto-update class is MINOR
9/03/22 18:14:59 dataLog: service started.
9/03/22 18:14:59 dataLog: Last log entry 09/03/22 16:07:50
9/03/22 18:14:59 historyLog: service started.
9/03/22 18:15:00 historyLog: Last log entry 09/03/22 16:07:00
9/03/22 18:15:01 Updater: Auto-update is current for class MINOR.
9/13/22 13:18:42z Real Time Clock is running. Unix time 1663075122
9/13/22 13:18:42z Reset Reason: Power-fail restart.
9/13/22 13:18:42z ESP8266 ID: 15875855, RTC PCF8523 (68)
9/13/22 13:18:42z IoTaWatt 5.0, Firmware version 02_07_05
9/13/22 13:18:42z SPIFFS mounted.
9/14/22 01:18:42 Local time zone: +12:00, using DST/BST when in effect.
9/14/22 01:18:42 device name: IotaWatt
9/14/22 01:18:45 Connecting with WiFiManager.
9/14/22 01:20:54 Did not connect after power-fail. Restarting to reset WiFi.
9/13/22 13:20:55z Real Time Clock is running. Unix time 1663075255
9/13/22 13:20:55z Reset reason: Software/System restart
9/13/22 13:20:55z Trace: 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[3], 34:10[1], 34:30, 34:10[4], 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
9/13/22 13:20:55z ESP8266 ID: 15875855, RTC PCF8523 (68)
9/13/22 13:20:55z IoTaWatt 5.0, Firmware version 02_07_05
9/13/22 13:20:55z SPIFFS mounted.
9/14/22 01:20:55 Local time zone: +12:00, using DST/BST when in effect.
9/14/22 01:20:55 device name: IotaWatt
9/14/22 01:20:55 HTTP server started
9/14/22 01:20:55 timeSync: service started.
9/14/22 01:20:55 statService: started.
9/14/22 01:20:55 dataLog: service started.
9/14/22 01:20:55 dataLog: Last log entry 09/04/22 03:32:25
9/14/22 01:21:00 historyLog: service started.
9/14/22 01:21:00 historyLog: Last log entry 09/04/22 03:32:00
9/14/22 01:21:01 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -53db
9/14/22 01:21:01 MDNS responder started for hostname IotaWatt
9/14/22 01:21:01 LLMNR responder started for hostname IotaWatt
9/14/22 01:21:01 Updater: service started. Auto-update class is MINOR
9/14/22 01:21:02 Updater: Auto-update is current for class MINOR.
9/15/22 01:18:06 WiFi disconnected.
9/15/22 01:19:09 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -55db
9/15/22 01:19:14 WiFi disconnected.
9/15/22 01:21:17 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -55db
9/15/22 21:25:32 Updater: Invalid response from server. HTTPcode: -4
9/16/22 01:21:17 WiFi disconnected.
9/16/22 01:22:20 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -55db
9/17/22 01:22:19 WiFi disconnected.
9/17/22 01:23:23 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -55db
9/18/22 08:16:04z Real Time Clock is running. Unix time 1663488964
9/18/22 08:16:04z Reset Reason: Power-fail restart.
9/18/22 08:16:04z ESP8266 ID: 15875855, RTC PCF8523 (68)
9/18/22 08:16:04z IoTaWatt 5.0, Firmware version 02_07_05
9/18/22 08:16:04z SPIFFS mounted.
9/18/22 20:16:04 Local time zone: +12:00, using DST/BST when in effect.
9/18/22 20:16:04 device name: IotaWatt
9/18/22 20:16:07 Connecting with WiFiManager.
9/18/22 20:16:12 HTTP server started
9/18/22 20:16:12 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -54db
9/18/22 20:16:12 MDNS responder started for hostname IotaWatt
9/18/22 20:16:12 LLMNR responder started for hostname IotaWatt
9/18/22 20:16:12 timeSync: service started.
9/18/22 20:16:12 statService: started.
9/18/22 20:16:12 Updater: service started. Auto-update class is MINOR
9/18/22 20:16:13 dataLog: service started.
9/18/22 20:16:13 dataLog: Last log entry 09/17/22 14:24:45
9/18/22 20:16:13 historyLog: service started.
9/18/22 20:16:13 historyLog: Last log entry 09/17/22 14:24:00
9/18/22 20:16:14 Updater: Auto-update is current for class MINOR.
9/19/22 01:24:33 WiFi disconnected.
9/19/22 01:25:36 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -55db
9/20/22 01:25:36 WiFi disconnected.
9/20/22 01:26:39 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -55db
9/20/22 06:19:39 Updater: Invalid response from server. HTTPcode: -4
9/21/22 01:26:42 WiFi disconnected.
9/21/22 01:27:45 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
9/22/22 01:27:47 WiFi disconnected.
9/22/22 01:29:52 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
9/23/22 01:29:52 WiFi disconnected.
9/23/22 01:30:55 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -58db
9/24/22 01:30:55 WiFi disconnected.
9/24/22 01:31:57 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -58db
9/24/22 20:30:16 Updater: Invalid response from server. HTTPcode: -14
9/25/22 01:31:58 WiFi disconnected.
9/25/22 01:33:00 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
9/26/22 02:33:05 WiFi disconnected.
9/26/22 02:34:08 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
9/26/22 15:34:26 Updater: Invalid response from server. HTTPcode: -4
9/28/22 02:34:08 WiFi disconnected.
9/28/22 02:35:10 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
9/29/22 02:35:17 WiFi disconnected.
9/29/22 02:37:23 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -59db
9/30/22 02:37:23 WiFi disconnected.
9/30/22 02:38:25 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
10/01/22 02:38:25 WiFi disconnected.
10/01/22 02:39:27 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -59db
10/01/22 02:39:28 WiFi disconnected.
10/01/22 02:40:30 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -57db
10/02/22 02:40:30 WiFi disconnected.
10/02/22 02:41:32 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -56db
10/02/22 07:23:36z Real Time Clock is running. Unix time 1664695416
10/02/22 07:23:36z Reset Reason: Power-fail restart.
10/02/22 07:23:36z ESP8266 ID: 15875855, RTC PCF8523 (68)
10/02/22 07:23:36z IoTaWatt 5.0, Firmware version 02_07_05
10/02/22 07:23:36z SPIFFS mounted.
10/02/22 20:23:36 Local time zone: +12:00, using DST/BST when in effect.
10/02/22 20:23:36 device name: IotaWatt
10/02/22 20:23:39 Connecting with WiFiManager.
10/02/22 20:23:44 HTTP server started
10/02/22 20:23:44 WiFi connected. SSID=Banana, IP=192.168.0.94, channel=10, RSSI -58db
10/02/22 20:23:44 MDNS responder started for hostname IotaWatt
10/02/22 20:23:44 LLMNR responder started for hostname IotaWatt
10/02/22 20:23:44 timeSync: service started.
10/02/22 20:23:44 statService: started.
10/02/22 20:23:44 Updater: service started. Auto-update class is MINOR
10/02/22 20:23:44 dataLog: service started.
10/02/22 20:23:44 dataLog: Last log entry 10/02/22 18:59:30
10/02/22 20:23:44 historyLog: service started.
10/02/22 20:23:44 historyLog: Last log entry 10/02/22 18:59:00
10/02/22 20:23:45 Updater: Auto-update is current for class MINOR.
