I was hoping to get advice on the values that should be set in the menu for burden resistors on ports 13 and 14
Setup
- Three-phase - Direct Reference - 240v (UK)
- VTs plugged into ports 0,13,14 all Ideal 77DB-06-09(UK)
Should the setting be:
- left as default: 20
- 0 as per default for the other VT on port 0
- Another value
- Does not matter
I could not find specific advice in the docs or the existing community posts other than in the Docs: Voltage Type CT Heading. Which states that input zero has the burden resistor removed, as inputs 13 & 14 are also only for VTs I would assume the same applies and so the setting probably doesn’t apply or should best be set to 0. But any specific advice would be greatly appreciated?
