Where do I get help with making an order? The “buy” pages do not make sense for what I think I want to order. Is there a phone number I can call and have a conversation with some one to help?
Help is available here in the forum. If you don’t want it to be public, you can start a private message thread to me by clicking on my avatar and then the message button.
If you tell me what you need, I can respond with the most economical way to order the equipment. If you have questions about how it works, I can answer them. Sometimes a picture of the service helps to answer basic questions.
Here is my plan for monitoring power. I have a main panel, a keep alive panel, and two sub-panels. “chnl” is the monitored number on the base unit. I tried to the following ct’s: 2 @ 200A, 4 @ 100A, and 7 @ 50A, plus base and the 2 transformers, and the order totaled $1549.80! I was unable to delete the order and try again. Your help is appreciated.
Main panel
c/b no named amps chnl c/b no named amps chnl
40 blank 39 blank
22-38 blank 23-27 blank
20 Kitchen coffee 20 21 X-10 Surge Suppsr 15
18 House vacuum 20 19 Coupler to cabin 15
16 X-10 coupler 15 17 Kitchen Hot Plate 20
14 X-10 repeater 15 15 Clothes washer 20
12 clothes 30 13 Spare 20 1 - voltage reference
10 dryer (not used)30 11 Instant Hot 20
8 Hot Tub or 50 8-2X 9 Spare 15
6 Spa (not used)50 7 Dishwasher 20
4 Endless Pool 80 9 -2x 5 Guest Bath 20
2 Sub-panel 80 3 Emergency 100 6
A Main CB 200 2 1 Sub-panel Feed 100 7 8 leads
B panel bottom 200 3
Keep Alive panel
c/b no named amps c/b no named amps
1 Dinning outlet 20 2 Emergency Power 100
3 Kitchen outlets 20 4 Feed 100
5 Kitchen outlets 20 6 Guest bed room 20
7 wine rm A/C 20 13 8 Bath,Wine Rm lts 15
9 Kitchen outlets 20 10 Septic Pump 20 10 5 leads
11 Kitchen refer 20 11 12 Study, Din rm lts 15
13 Air Hander 20 14 Bed rm lts, outlets 15
15 Pantry refer 20 12 16 M. Bath outlets 20
17 Hyd heating 20 14 18 Nook outlets 20
19 Kitchen lights 15 20 Powder rm lts 20
21 Pantry, bath lts 15 22 Microwave, 20
23 not useable 24 Master bdrm 20
**Barn Transfer** 100 4 220v
**Shop transfer** 100 5 220v
I’ll send a photo of the panel installation.
Thanks for the help,
Bob
Darn, I see the formatting was stripped. Can I send a PDF of the Excel file? Also how do I send a photo?
Bob
You can upload the PDF using the upload symbol at the top of the editing frame ![]()
Same for a photo, or just drag and drop it into the editing frame.
I entered that order as an NA bundle with two a-la-carte 100A CTs (bundle only allows two). Price was $306.45 - free shipping. That’s assuming you are in the USA.
Thank you for the help, yes I am in the US, and that is the order I would like to make!
The power panel is shown here. The keep alive panel is across the room and I plan to run connecting cables in plastic conduit back to the main panel.
Power-Panel|666x500
My order has been made and thanks for the help.
Bob
