Hi,
Not sure if this is related to the product or someone else wrote the Home assistant integration for IotAWatt but i’m having problems.
Most of the time, I see a error, when its not in error, its unable to fetch the values (currently only trying to get the vref).
I also can’t see any outputs configured in the iosawatt interface.
here is a couple of log lines of the errors i’m facing:
Logger: homeassistant.components.iotawatt.coordinator
Source: components/iotawatt/coordinator.py:56
Integration: IoTaWatt ())
First occurred: 15:03:21 (5 occurrences)
Last logged: 15:14:22Unexpected error fetching 172.20.10.34 data: ‘NoneType’ object has no attribute ‘status_code’
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 187, in _async_refresh self.data = await self._async_update_data() File “/usr/src/homeassistant/homeassistant/components/iotawatt/coordinator.py”, line 56, in _async_update_data is_authenticated = await api.connect() File “/usr/local/lib/python3.9/site-packages/iotawattpy/iotawatt.py”, line 48, in connect if results.status_code == httpx.codes.OK: AttributeError: ‘NoneType’ object has no attribute ‘status_code’
and
Source: components/iotawatt/coordinator.py:65
Integration: IoTaWatt )
First occurred: 15:04:42 (5 occurrences)
Last logged: 15:15:42Unexpected error fetching 172.20.10.34 data: 0
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 187, in _async_refresh self.data = await self._async_update_data() File “/usr/src/homeassistant/homeassistant/components/iotawatt/coordinator.py”, line 65, in _async_update_data await self.api.update(lastUpdate=self._last_run) File “/usr/local/lib/python3.9/site-packages/iotawattpy/iotawatt.py”, line 76, in update await self._refreshSensors(timespan, lastUpdate) File “/usr/local/lib/python3.9/site-packages/iotawattpy/iotawatt.py”, line 264, in _refreshSensors sensor.setValue(values[0][idx + 1]) KeyError: 0
Anyone can chime on this ?
