it is a slow green blink.
the text file is 200MB. I have a truncated version below. This is from the update event, and 20 messages after.
1/02/22 17:01:20z Real Time Clock is running. Unix time 1641142880
1/02/22 17:01:20z Reset reason: Exception
1/02/22 17:01:20z Trace: 0:0, 11:0, 11:4, 11:5, 11:5, 11:10, 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:31, 11:30, 11:35, 31:100, 31:100, 31:100, 31:100, 31:101, 31:102
1/02/22 17:01:20z ESP8266 ID: 6735387, RTC PCF8523
1/02/22 17:01:20z IoTaWatt 5.0, Firmware version 02_06_06
1/02/22 17:01:20z SPIFFS mounted.
1/03/22 03:01:20 Local time zone: +10:00
1/03/22 03:01:20 device name: IotaWatt
1/03/22 03:01:20 HTTP server started
1/03/22 03:01:20 influxDB_v1: Starting, interval:10, url:http://192.168.100.19:8086
1/03/22 03:01:21 timeSync: service started.
1/03/22 03:01:21 statService: started.
1/03/22 03:01:21 dataLog: service started.
1/03/22 03:01:22 dataLog: Last log entry 01/03/22 02:58:50
1/03/22 03:01:26 historyLog: service started.
1/03/22 03:01:26 historyLog: Last log entry 01/03/22 02:58:00
1/03/22 03:01:31 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.9, channel=6, RSSI -77db
1/03/22 03:01:31 MDNS responder started for hostname IotaWatt
1/03/22 03:01:31 LLMNR responder started for hostname IotaWatt
1/03/22 03:01:31 Updater: service started. Auto-update class is MINOR
1/03/22 03:01:34 Updater: Auto-update is current for class MINOR.
1/03/22 03:01:46 influxDB_v1: Start posting at 01/03/22 02:57:50
1/04/22 12:05:15 Updater: Update from 02_06_06 to 02_07_05
1/04/22 12:05:15 Updater: download 02_07_05
1/04/22 12:05:21 Updater: Release downloaded 6190ms, size 951104
1/04/22 12:05:35 Updater: signature verified
1/04/22 12:05:42 Updater: firmware upgraded to version 02_07_05
1/04/22 12:05:42 Updater: Firmware updated, restarting.
1/04/22 02:05:51z Real Time Clock is running. Unix time 1641261951
1/04/22 02:05:51z Reset reason: Software/System restart
1/04/22 02:05:51z Trace: 31:0, 31:1, 31:2[3], 32:60, 32:60, 32:61, 31:1, 1:6[6], 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
1/04/22 02:05:51z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:05:51z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:05:51z Updater: Installing update files for version 02_07_05
1/04/22 02:05:51z Updater: Installing GRAPH.HTM
1/04/22 02:05:51z Updater: Installing GRAPH.JS
1/04/22 02:05:51z Updater: Installing GRAPH2.HTM
1/04/22 02:05:52z Updater: Installing GRAPH2.JS
1/04/22 02:05:53z Updater: Installing INDEX.HTM
1/04/22 02:05:55z Updater: Installing TABLES.TXT
1/04/22 02:05:55z Updater: Installing CNFSTYLE.CSS
1/04/22 02:05:56z Updater: Installing EDIT.HTM
1/04/22 02:05:56z Updater: Installing FAVICON.ICO
1/04/22 02:05:57z Updater: Installation complete.
1/04/22 02:05:58z SPIFFS mounted.
1/04/22 02:05:59z Real Time Clock is running. Unix time 1641261959
1/04/22 02:05:59z Reset reason: Exception
1/04/22 02:05:59z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:05:59z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:05:59z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:05:59z SPIFFS mounted.
1/04/22 02:06:00z Real Time Clock is running. Unix time 1641261960
1/04/22 02:06:00z Reset reason: Exception
1/04/22 02:06:00z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:00z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:00z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:00z SPIFFS mounted.
1/04/22 02:06:02z Real Time Clock is running. Unix time 1641261962
1/04/22 02:06:02z Reset reason: Exception
1/04/22 02:06:02z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:02z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:02z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:02z SPIFFS mounted.
1/04/22 02:06:03z Real Time Clock is running. Unix time 1641261963
1/04/22 02:06:03z Reset reason: Exception
1/04/22 02:06:03z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:03z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:03z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:03z SPIFFS mounted.
1/04/22 02:06:04z Real Time Clock is running. Unix time 1641261964
1/04/22 02:06:04z Reset reason: Exception
1/04/22 02:06:04z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:04z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:04z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:04z SPIFFS mounted.
1/04/22 02:06:05z Real Time Clock is running. Unix time 1641261965
1/04/22 02:06:05z Reset reason: Exception
1/04/22 02:06:05z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:05z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:05z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:05z SPIFFS mounted.
1/04/22 02:06:07z Real Time Clock is running. Unix time 1641261967
1/04/22 02:06:07z Reset reason: Exception
1/04/22 02:06:07z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:07z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:07z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:07z SPIFFS mounted.
1/04/22 02:06:08z Real Time Clock is running. Unix time 1641261968
1/04/22 02:06:08z Reset reason: Exception
1/04/22 02:06:08z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:08z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:08z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:08z SPIFFS mounted.
1/04/22 02:06:09z Real Time Clock is running. Unix time 1641261969
1/04/22 02:06:09z Reset reason: Exception
1/04/22 02:06:09z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:09z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:09z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:09z SPIFFS mounted.
1/04/22 02:06:11z Real Time Clock is running. Unix time 1641261971
1/04/22 02:06:11z Reset reason: Exception
1/04/22 02:06:11z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:11z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:11z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:11z SPIFFS mounted.
1/04/22 02:06:12z Real Time Clock is running. Unix time 1641261972
1/04/22 02:06:12z Reset reason: Exception
1/04/22 02:06:12z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:12z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:12z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:12z SPIFFS mounted.
1/04/22 02:06:13z Real Time Clock is running. Unix time 1641261973
1/04/22 02:06:13z Reset reason: Exception
1/04/22 02:06:13z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:13z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:13z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:13z SPIFFS mounted.
1/04/22 02:06:14z Real Time Clock is running. Unix time 1641261974
1/04/22 02:06:14z Reset reason: Exception
1/04/22 02:06:14z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:14z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:14z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:14z SPIFFS mounted.
1/04/22 02:06:16z Real Time Clock is running. Unix time 1641261976
1/04/22 02:06:16z Reset reason: Exception
1/04/22 02:06:16z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:16z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:16z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:16z SPIFFS mounted.
1/04/22 02:06:17z Real Time Clock is running. Unix time 1641261977
1/04/22 02:06:17z Reset reason: Exception
1/04/22 02:06:17z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:17z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:17z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:17z SPIFFS mounted.
1/04/22 02:06:18z Real Time Clock is running. Unix time 1641261978
1/04/22 02:06:18z Reset reason: Exception
1/04/22 02:06:18z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:18z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:18z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:18z SPIFFS mounted.
1/04/22 02:06:19z Real Time Clock is running. Unix time 1641261979
1/04/22 02:06:19z Reset reason: Exception
1/04/22 02:06:19z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:19z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:19z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:19z SPIFFS mounted.
1/04/22 02:06:21z Real Time Clock is running. Unix time 1641261981
1/04/22 02:06:21z Reset reason: Exception
1/04/22 02:06:21z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:21z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:21z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:21z SPIFFS mounted.
1/04/22 02:06:22z Real Time Clock is running. Unix time 1641261982
1/04/22 02:06:22z Reset reason: Exception
1/04/22 02:06:22z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:22z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:22z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:22z SPIFFS mounted.
1/04/22 02:06:23z Real Time Clock is running. Unix time 1641261983
1/04/22 02:06:23z Reset reason: Exception
1/04/22 02:06:23z Trace: 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:5, 34:5, 34:5, 34:6[1], 34:10[11], 34:5, 34:5, 34:5, 34:6[1], 34:10[11]
1/04/22 02:06:23z ESP8266 ID: 6735387, RTC PCF8523 (68)
1/04/22 02:06:23z IoTaWatt 5.0, Firmware version 02_07_05
1/04/22 02:06:23z SPIFFS mounted.
