Hello all. I have a new IoTaWatt device and I see issues with it periodically disconnecting from wifi and not reconnecting unless I power cycle. It does not appear to be a signal strength issue as RSSI is about -51. Non ESP8266 devices do not have this issue.
The wifi is an ASUS Zen Wifi XT8 2 node system. I have it configured for separate 2.4 and 5GHz bands. The 2.4GHz band has various things turned off (Wifi Agile Multiband, Target Wake Time, Protected Management Frames, etc) to try and avoid issues. Turning them off doesn’t seem to help any.
Does anybody have suggestions or information on known issues? Log below. Thanks!
10/19/21 05:51:54z Real Time Clock is running. Unix time 1634622714
10/19/21 05:51:54z Power failure detected.
10/19/21 05:51:54z Reset reason: External System
10/19/21 05:51:54z ESP8266 ChipID: 4305228
10/19/21 05:51:54z IoTaWatt 5.0, Firmware version 02_06_05
10/19/21 05:51:54z SPIFFS mounted.
10/18/21 22:51:54 Local time zone: -8:00
10/18/21 22:51:54 Using Daylight Saving Time (BST) when in effect.
10/18/21 22:51:54 device name: IotaWatt
10/18/21 22:51:57 Connecting with WiFiManager.
10/18/21 22:52:00 HTTP server started
10/18/21 22:52:00 emoncms: Starting, interval:10, url:http://10.0.0.181:8888
10/18/21 22:52:00 WiFi connected. SSID=RadioOrion24, IP=10.0.0.106, channel=3, RSSI -50db
10/18/21 22:52:00 MDNS responder started for hostname IotaWatt
10/18/21 22:52:00 LLMNR responder started for hostname IotaWatt
10/18/21 22:52:00 timeSync: service started.
10/18/21 22:52:00 statService: started.
10/18/21 22:52:00 Updater: service started. Auto-update class is MINOR
10/18/21 22:52:00 dataLog: service started.
10/18/21 22:52:00 dataLog: Last log entry 10/18/21 22:51:45
10/18/21 22:52:01 historyLog: service started.
10/18/21 22:52:01 historyLog: Last log entry 10/18/21 22:51:00
10/18/21 22:52:01 emoncms: No existing inputs found for node IotaWatt.
10/18/21 22:52:01 emoncms: Start posting at 10/18/21 22:52:10
10/18/21 22:52:03 Updater: Auto-update is current for class MINOR.
10/19/21 04:00:26 WiFi disconnected.
10/19/21 04:01:26 WiFi connected. SSID=RadioOrion24, IP=10.0.0.106, channel=9, RSSI -51db
10/19/21 18:11:57 WiFi disconnected.
10/19/21 18:12:13 WiFi connected. SSID=RadioOrion24, IP=10.0.0.106, channel=2, RSSI -52db
10/19/21 21:59:27 WiFi disconnected.
10/20/21 05:03:08z Real Time Clock is running. Unix time 1634706188
10/20/21 05:03:08z Power failure detected.
10/20/21 05:03:08z Reset reason: Power On
10/20/21 05:03:08z ESP8266 ChipID: 4305228
10/20/21 05:03:08z IoTaWatt 5.0, Firmware version 02_06_05
10/20/21 05:03:08z SPIFFS mounted.
10/19/21 22:03:08 Local time zone: -8:00
10/19/21 22:03:08 Using Daylight Saving Time (BST) when in effect.
10/19/21 22:03:08 device name: IotaWatt
10/19/21 22:03:11 Connecting with WiFiManager.
10/19/21 22:05:23 Did not connect after power-fail. Restarting to reset WiFi.
10/20/21 05:05:24z Real Time Clock is running. Unix time 1634706324
10/20/21 05:05:24z Reset reason: Software/System restart
10/20/21 05:05:24z Trace: 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:30, 11:31, 11:32, 11:31, 31:100, 31:100, 31:100, 31:100, 31:101, 31:102, 3:100, 3:101, 3:102, 31:105, 31:105, 31:106, 11:35, 11:40, 11:45, 11:70
10/20/21 05:05:24z ESP8266 ChipID: 4305228
10/20/21 05:05:24z IoTaWatt 5.0, Firmware version 02_06_05
10/20/21 05:05:24z SPIFFS mounted.
10/19/21 22:05:24 Local time zone: -8:00
10/19/21 22:05:24 Using Daylight Saving Time (BST) when in effect.
10/19/21 22:05:24 device name: IotaWatt
10/19/21 22:05:24 HTTP server started
10/19/21 22:05:24 emoncms: Starting, interval:10, url:http://10.0.0.181:8888
10/19/21 22:05:24 timeSync: service started.
10/19/21 22:05:24 statService: started.
10/19/21 22:05:24 dataLog: service started.
10/19/21 22:05:24 dataLog: Last log entry 10/19/21 22:03:00
10/19/21 22:05:24 historyLog: service started.
10/19/21 22:05:24 historyLog: Last log entry 10/19/21 22:03:00
10/19/21 22:21:07 WiFi connected. SSID=RadioOrion24, IP=10.0.0.106, channel=8, RSSI -57db
10/19/21 22:21:07 MDNS responder started for hostname IotaWatt
10/19/21 22:21:07 LLMNR responder started for hostname IotaWatt
10/19/21 22:21:07 Updater: service started. Auto-update class is MINOR
10/19/21 22:21:07 emoncms: Start posting at 10/19/21 21:58:10
10/19/21 22:21:07 Updater: Auto-update is current for class MINOR.
10/20/21 04:00:27 WiFi disconnected.
10/20/21 04:01:20 WiFi connected. SSID=RadioOrion24, IP=10.0.0.106, channel=8, RSSI -52db
10/20/21 06:22:21 Updater: Invalid response from server. HTTPcode: -4
10/20/21 18:01:12z Real Time Clock is running. Unix time 1634752872
10/20/21 18:01:12z Power failure detected.
10/20/21 18:01:12z Reset reason: Power On
10/20/21 18:01:12z ESP8266 ChipID: 4305228
10/20/21 18:01:12z IoTaWatt 5.0, Firmware version 02_06_05
10/20/21 18:01:12z SPIFFS mounted.
10/20/21 11:01:12 Local time zone: -8:00
10/20/21 11:01:12 Using Daylight Saving Time (BST) when in effect.
10/20/21 11:01:12 device name: IotaWatt
10/20/21 11:01:16 Connecting with WiFiManager.
10/20/21 11:01:18 HTTP server started
10/20/21 11:01:18 emoncms: Starting, interval:10, url:http://10.0.0.181:8888
10/20/21 11:01:18 WiFi connected. SSID=RadioOrion24, IP=10.0.0.106, channel=8, RSSI -54db
10/20/21 11:01:19 MDNS responder started for hostname IotaWatt
10/20/21 11:01:19 LLMNR responder started for hostname IotaWatt
10/20/21 11:01:19 timeSync: service started.
10/20/21 11:01:19 statService: started.
10/20/21 11:01:19 Updater: service started. Auto-update class is MINOR
10/20/21 11:01:19 dataLog: service started.
10/20/21 11:01:19 dataLog: Last log entry 10/20/21 11:01:05
10/20/21 11:01:19 historyLog: service started.
10/20/21 11:01:20 historyLog: Last log entry 10/20/21 11:01:00
10/20/21 11:01:20 emoncms: Start posting at 10/20/21 10:13:20
10/20/21 11:01:21 Updater: Auto-update is current for class MINOR.
