I recently have had a mare with my EmonCMS install, I originally installed it with Docker, and they’ve since moved away from that. I’ve since installed a new EmonCMS instance, but I’m unable to do a clean backup from the original one. My understanding is that IoTaWatt will upload the history as long as I set the history date correctly, however the history I want is in the History_Log, not Current_Log:
Is there a way to get this to upload as well? I did set the “Upload history from” date to my original IoTaWatt install date (ish):
8/07/21 18:54:44z Real Time Clock is running. Unix time 1628362484
8/07/21 18:54:44z Reset reason: Software/System restart
8/07/21 18:54:44z Trace: 15:10, 15:14[32], 15:15[2], 15:16, 15:4, 3:71, 15:10, 15:14[144], 15:15, 15:16, 3:71, 31:1, 1:6[6], 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
8/07/21 18:54:44z ESP8266 ChipID: 2516990
8/07/21 18:54:44z IoTaWatt 4.x, Firmware version 02_06_05
8/07/21 18:54:44z Updater: Installing update files for version 02_06_05
8/07/21 18:54:44z Updater: Installing GRAPH.HTM
8/07/21 18:54:44z Updater: Installing GRAPH.JS
8/07/21 18:54:44z Updater: Installing GRAPH2.HTM
8/07/21 18:54:44z Updater: Installing GRAPH2.JS
8/07/21 18:54:45z Updater: Installing INDEX.HTM
8/07/21 18:54:46z Updater: Installing TABLES.TXT
8/07/21 18:54:46z Updater: Installing CNFSTYLE.CSS
8/07/21 18:54:46z Updater: Installing EDIT.HTM
8/07/21 18:54:46z Updater: Installation complete.
8/07/21 18:54:46z SPIFFS mounted.
8/08/21 06:54:46 Local time zone: +12:00
8/08/21 06:54:47 Using Daylight Saving Time (BST) when in effect.
8/08/21 06:54:47 device name: IotaWatt
8/08/21 06:54:47 HTTP server started
8/08/21 06:54:47 emoncms: Starting, interval:10, url:http://10.111.111.36:8080
8/08/21 06:54:47 influxDB_v1: Starting, interval:10, url:http://10.111.111.35:8086
8/08/21 06:54:47 timeSync: service started.
8/08/21 06:54:47 statService: started.
8/08/21 06:54:47 dataLog: service started.
8/08/21 06:54:47 dataLog: Last log entry 08/08/21 06:54:20
8/08/21 06:54:52 historyLog: service started.
8/08/21 06:54:52 historyLog: Last log entry 08/08/21 06:54:00
8/08/21 06:54:55 WiFi connected. SSID=DCDC, IP=10.111.111.80, channel=1, RSSI -66db
8/08/21 06:54:55 MDNS responder started for hostname IotaWatt
8/08/21 06:54:55 LLMNR responder started for hostname IotaWatt
8/08/21 06:54:55 Updater: service started. Auto-update class is MINOR
8/08/21 06:54:55 emoncms: Start posting at 08/08/21 06:54:10
8/08/21 06:55:01 Updater: Auto-update is current for class MINOR.
8/08/21 06:56:14 influxDB_v1: Start posting at 08/08/21 06:53:50
8/08/21 14:07:45 WiFi disconnected.
8/08/21 14:12:02 WiFi connected. SSID=DCDC, IP=10.111.111.80, channel=1, RSSI -78db
8/08/21 14:16:46 WiFi disconnected.
8/08/21 14:17:44 WiFi connected. SSID=DCDC, IP=10.111.111.80, channel=1, RSSI -69db
8/15/21 14:51:52 WiFi disconnected.
8/15/21 14:51:53 WiFi connected. SSID=DCDC, IP=10.111.111.80, channel=1, RSSI -66db
8/15/21 15:02:59 WiFi disconnected.
8/15/21 15:03:00 WiFi connected. SSID=DCDC, IP=10.111.111.80, channel=1, RSSI -64db
8/27/21 12:41:35 emoncms: stopped, Last post 08/27/21 12:41:25
8/27/21 12:42:29 emoncms: Start posting at 08/27/21 12:41:30
