Web server does not respond, light is green
Here’s the result of those commands. iptables is not available, since it is not by default installed in HASSIO, and I’m a bit reluctant to install packages on it outside
Welcome to the Home Assistant command line.
System information
  IPv4 addresses for eth0:  192.168.1.93/24
  IPv6 addresses for eth0:  fe80::243f:2cf3:3ff:f077/64
  IPv4 addresses for wlan0:
  OS Version:               Home Assistant OS 9.2
  Home Assistant Core:      2022.10.3
  Home Assistant URL:       http://homeassistant.local:8123
  Observer URL:             http://homeassistant.local:4357
[core-ssh ~]$ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 02:42:AC:1E:21:01
          inet addr:172.30.33.1  Bcast:172.30.33.255  Mask:255.255.254.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:96927 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1690 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:20435479 (19.4 MiB)  TX bytes:512936 (500.9 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
[core-ssh ~]$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
20: eth0@if21: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
    link/ether 02:42:ac:1e:21:01 brd ff:ff:ff:ff:ff:ff
    inet 172.30.33.1/23 brd 172.30.33.255 scope global eth0
[core-ssh ~]$ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         172.30.32.1     0.0.0.0         UG    0      0        0 eth0
172.30.32.0     0.0.0.0         255.255.254.0   U     0      0        0 eth0
[core-ssh ~]$ arp -n
? (172.30.32.2) at 02:42:ac:1e:20:02 [ether]  on eth0
? (172.30.32.1) at 02:42:b3:78:f4:f0 [ether]  on eth0
[core-ssh ~]$ netstat -na
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 127.0.0.11:46109        0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:8099            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 172.30.33.1:8099        172.30.32.2:36290       ESTABLISHED
tcp        0      0 172.30.33.1:60528       172.30.32.2:80          TIME_WAIT
tcp        0    192 172.30.33.1:22          192.168.1.102:62015     ESTABLISHED
tcp        0      0 :::22                   :::*                    LISTEN
udp        0      0 127.0.0.11:45865        0.0.0.0:*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node Path
unix  2      [ ACC ]     STREAM     LISTENING     494504 /tmp/tmux-0/default
unix  2      [ ACC ]     STREAM     LISTENING      18139 s
unix  3      [ ]         STREAM     CONNECTED     623461
unix  3      [ ]         STREAM     CONNECTED     626087 /tmp/tmux-0/default
unix  2      [ ]         STREAM     CONNECTED     626302
