Haha, I actually found the 32GB card lying next to the iotawatt case. I forgot to change it, so I still had the 8GB original one in. I’ve left it there again.
Here’s the iotamsgs.txt file (trimmed it so it is under the maximum character lenght for the message)
7/05/22 15:26:23z Real Time Clock is running. Unix time 1657034783
7/05/22 15:26:23z Reset Reason: Power-fail restart.
7/05/22 15:26:23z ESP8266 ID: 480839, RTC M41T81 (68)
7/05/22 15:26:23z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 15:26:23z SPIFFS mounted.
7/05/22 17:26:23 Local time zone: +1:00, using DST/BST when in effect.
7/05/22 17:26:23 device name: Iotawatt
7/05/22 17:26:26 Connecting with WiFiManager.
7/05/22 15:26:31z Real Time Clock is running. Unix time 1657034791
7/05/22 15:26:31z Reset Reason: Power-fail restart.
7/05/22 15:26:31z ESP8266 ID: 480839, RTC M41T81 (68)
7/05/22 15:26:31z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 15:26:31z SPIFFS mounted.
7/05/22 17:26:31 Local time zone: +1:00, using DST/BST when in effect.
7/05/22 17:26:31 device name: Iotawatt
7/05/22 15:26:51z Real Time Clock is running. Unix time 1657034811
7/05/22 15:26:51z Reset Reason: Power-fail restart.
7/05/22 15:26:51z ESP8266 ID: 480839, RTC M41T81 (68)
7/05/22 15:26:51z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 15:26:51z SPIFFS mounted.
7/05/22 17:26:51 Local time zone: +1:00, using DST/BST when in effect.
7/05/22 17:26:51 device name: Iotawatt
7/05/22 15:26:56z Real Time Clock is running. Unix time 1657034816
7/05/22 15:26:56z Reset Reason: Power-fail restart.
7/05/22 15:26:56z ESP8266 ID: 480839, RTC M41T81 (68)
7/05/22 15:26:56z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 15:26:56z SPIFFS mounted.
7/05/22 17:26:56 Local time zone: +1:00, using DST/BST when in effect.
7/05/22 17:26:56 device name: Iotawatt
7/05/22 17:26:59 Connecting with WiFiManager.
7/05/22 15:29:38z Real Time Clock is running. Unix time 1657034978
7/05/22 15:29:38z Reset Reason: Power-fail restart.
7/05/22 15:29:38z ESP8266 ID: 480839, RTC M41T81 (68)
7/05/22 15:29:38z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 15:29:38z SPIFFS mounted.
7/05/22 17:29:38 Local time zone: +1:00, using DST/BST when in effect.
7/05/22 17:29:38 device name: Iotawatt
7/05/22 17:29:41 Connecting with WiFiManager.
7/05/22 17:29:44 HTTP server started
7/05/22 17:29:45 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -69db
7/05/22 17:29:45 MDNS responder started for hostname Iotawatt
7/05/22 17:29:45 LLMNR responder started for hostname Iotawatt
7/05/22 17:29:45 timeSync: service started.
7/05/22 17:29:45 statService: started.
7/05/22 17:29:45 Updater: service started. Auto-update class is MINOR
7/05/22 17:29:45 dataLog: service started.
7/05/22 17:29:45 dataLog: Last log entry 07/05/22 17:26:20
7/05/22 17:29:46 Updater: Auto-update is current for class MINOR.
7/05/22 17:29:50 historyLog: service started.
7/05/22 17:29:50 historyLog: Last log entry 07/05/22 17:26:00
7/05/22 15:38:39z Real Time Clock is running. Unix time 1657035519
7/05/22 15:38:39z Reset Reason: Power-fail restart.
7/05/22 15:38:39z ESP8266 ID: 480839, RTC M41T81 (68)
7/05/22 15:38:39z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 15:38:39z SPIFFS mounted.
7/05/22 17:38:39 Local time zone: +1:00, using DST/BST when in effect.
7/05/22 17:38:39 device name: Iotawatt
7/05/22 17:38:42 Connecting with WiFiManager.
7/05/22 17:38:45 HTTP server started
7/05/22 17:38:46 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=1, RSSI -64db
7/05/22 17:38:46 MDNS responder started for hostname Iotawatt
7/05/22 17:38:46 LLMNR responder started for hostname Iotawatt
7/05/22 17:38:46 timeSync: service started.
7/05/22 17:38:46 statService: started.
7/05/22 17:38:46 Updater: service started. Auto-update class is MINOR
7/05/22 17:38:46 dataLog: service started.
7/05/22 17:38:46 dataLog: Last log entry 07/05/22 17:31:50
7/05/22 17:38:49 Updater: Auto-update is current for class MINOR.
7/05/22 17:38:51 historyLog: service started.
7/05/22 17:38:51 historyLog: Last log entry 07/05/22 17:31:00
7/06/22 08:25:59z Real Time Clock is running. Unix time 1657095959
7/06/22 08:25:59z Reset Reason: Power-fail restart.
7/06/22 08:25:59z ESP8266 ID: 480839, RTC M41T81 (68)
7/06/22 08:25:59z IoTaWatt 5.0, Firmware version 02_07_05
7/06/22 08:25:59z SPIFFS mounted.
7/06/22 10:25:59 Local time zone: +1:00, using DST/BST when in effect.
7/06/22 10:25:59 device name: Iotawatt
7/06/22 10:26:02 Connecting with WiFiManager.
7/06/22 08:28:44z Real Time Clock is running. Unix time 1657096124
7/06/22 08:28:44z Reset Reason: Power-fail restart.
7/06/22 08:28:44z ESP8266 ID: 480839, RTC M41T81 (68)
7/06/22 08:28:44z IoTaWatt 5.0, Firmware version 02_07_05
7/06/22 08:28:44z SPIFFS mounted.
7/06/22 10:28:44 Local time zone: +1:00, using DST/BST when in effect.
7/06/22 10:28:44 device name: Iotawatt
7/06/22 10:28:47 Connecting with WiFiManager.
7/06/22 10:30:55 Did not connect after power-fail. Restarting to reset WiFi.
7/06/22 08:30:57z Real Time Clock is running. Unix time 1657096257
7/06/22 08:30:57z Reset reason: Software/System restart
7/06/22 08:30:57z Trace: 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:30[1], 11:30[2], 11:31, 11:31[1], 11:31[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
7/06/22 08:30:57z ESP8266 ID: 480839, RTC M41T81 (68)
7/06/22 08:30:57z IoTaWatt 5.0, Firmware version 02_07_05
7/06/22 08:30:57z SPIFFS mounted.
7/06/22 10:30:57 Local time zone: +1:00, using DST/BST when in effect.
7/06/22 10:30:57 device name: Iotawatt
7/06/22 10:30:57 HTTP server started
7/06/22 10:30:57 timeSync: service started.
7/06/22 10:30:57 statService: started.
7/06/22 10:30:57 dataLog: service started.
7/06/22 10:30:57 dataLog: Last log entry 07/06/22 10:25:50
7/06/22 10:31:02 historyLog: service started.
7/06/22 10:31:02 historyLog: Last log entry 07/06/22 10:25:00
7/06/22 10:31:02 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -70db
7/06/22 10:31:02 MDNS responder started for hostname Iotawatt
7/06/22 10:31:02 LLMNR responder started for hostname Iotawatt
7/06/22 10:31:02 Updater: service started. Auto-update class is MINOR
7/06/22 10:31:03 Updater: Auto-update is current for class MINOR.
7/07/22 17:05:26z Real Time Clock is running. Unix time 1657213526
7/07/22 17:05:26z Reset Reason: Power-fail restart.
7/07/22 17:05:26z ESP8266 ID: 480839, RTC M41T81 (68)
7/07/22 17:05:26z IoTaWatt 5.0, Firmware version 02_07_05
7/07/22 17:05:26z SPIFFS mounted.
7/07/22 19:05:26 Local time zone: +1:00, using DST/BST when in effect.
7/07/22 19:05:26 device name: Iotawatt
7/07/22 19:05:29 Connecting with WiFiManager.
7/07/22 17:06:20z Real Time Clock is running. Unix time 1657213580
7/07/22 17:06:20z Reset Reason: Power-fail restart.
7/07/22 17:06:20z ESP8266 ID: 480839, RTC M41T81 (68)
7/07/22 17:06:20z IoTaWatt 5.0, Firmware version 02_07_05
7/07/22 17:06:20z SPIFFS mounted.
7/07/22 19:06:20 Local time zone: +1:00, using DST/BST when in effect.
7/07/22 19:06:20 device name: Iotawatt
7/07/22 19:06:23 Connecting with WiFiManager.
7/07/22 19:08:32 Did not connect after power-fail. Restarting to reset WiFi.
7/07/22 17:08:33z Real Time Clock is running. Unix time 1657213713
7/07/22 17:08:33z Reset reason: Software/System restart
7/07/22 17:08:33z Trace: 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:30[1], 11:30[2], 11:31, 11:31[1], 11:31[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
7/07/22 17:08:33z ESP8266 ID: 480839, RTC M41T81 (68)
7/07/22 17:08:33z IoTaWatt 5.0, Firmware version 02_07_05
7/07/22 17:08:33z SPIFFS mounted.
7/07/22 19:08:33 Local time zone: +1:00, using DST/BST when in effect.
7/07/22 19:08:33 device name: Iotawatt
7/07/22 19:08:33 HTTP server started
7/07/22 19:08:33 timeSync: service started.
7/07/22 19:08:33 statService: started.
7/07/22 19:08:33 dataLog: service started.
7/07/22 19:08:33 dataLog: Last log entry 07/07/22 19:05:20
7/07/22 19:08:38 historyLog: service started.
7/07/22 19:08:38 historyLog: Last log entry 07/07/22 19:05:00
7/07/22 19:08:55 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -69db
7/07/22 19:08:55 MDNS responder started for hostname Iotawatt
7/07/22 19:08:55 LLMNR responder started for hostname Iotawatt
7/07/22 19:08:55 Updater: service started. Auto-update class is MINOR
7/07/22 19:08:56 Updater: Auto-update is current for class MINOR.
7/12/22 07:05:05 WiFi disconnected.
7/12/22 07:07:26 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -69db
7/14/22 14:22:13 WiFi disconnected.
7/14/22 14:24:15 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -69db
7/14/22 14:26:18 WiFi disconnected.
7/14/22 14:27:39 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -73db
7/16/22 06:46:17 WiFi disconnected.
7/16/22 06:49:16 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -67db
7/16/22 08:14:45 WiFi disconnected.
7/16/22 08:16:55 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -65db
7/17/22 07:44:21z Real Time Clock is running. Unix time 1658043861
7/17/22 07:44:21z Reset Reason: Power-fail restart.
7/17/22 07:44:21z ESP8266 ID: 480839, RTC M41T81 (68)
7/17/22 07:44:21z IoTaWatt 5.0, Firmware version 02_07_05
7/17/22 07:44:21z SPIFFS mounted.
7/17/22 09:44:21 Local time zone: +1:00, using DST/BST when in effect.
7/17/22 09:44:21 device name: Iotawatt
7/17/22 09:44:24 Connecting with WiFiManager.
7/17/22 09:46:57 Did not connect after power-fail. Restarting to reset WiFi.
7/17/22 07:46:58z Real Time Clock is running. Unix time 1658044018
7/17/22 07:46:58z Reset reason: Software/System restart
7/17/22 07:46:58z Trace: 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:30[1], 11:30[2], 11:31, 11:31[1], 11:31[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
7/17/22 07:46:58z ESP8266 ID: 480839, RTC M41T81 (68)
7/17/22 07:46:58z IoTaWatt 5.0, Firmware version 02_07_05
7/17/22 07:46:58z SPIFFS mounted.
7/17/22 09:46:58 Local time zone: +1:00, using DST/BST when in effect.
7/17/22 09:46:58 device name: Iotawatt
7/17/22 09:46:58 HTTP server started
7/17/22 09:46:58 timeSync: service started.
7/17/22 09:46:58 statService: started.
7/17/22 09:46:58 dataLog: service started.
7/17/22 09:46:58 dataLog: Last log entry 07/17/22 09:44:10
7/17/22 09:47:03 historyLog: service started.
7/17/22 09:47:03 historyLog: Last log entry 07/17/22 09:44:00
7/17/22 09:47:03 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=6, RSSI -61db
7/17/22 09:47:03 MDNS responder started for hostname Iotawatt
7/17/22 09:47:03 LLMNR responder started for hostname Iotawatt
7/17/22 09:47:03 Updater: service started. Auto-update class is MINOR
7/17/22 09:47:04 Updater: Auto-update is current for class MINOR.
7/17/22 13:38:07z Real Time Clock is running. Unix time 1658065087
7/17/22 13:38:07z Reset Reason: Power-fail restart.
7/17/22 13:38:07z ESP8266 ID: 480839, RTC M41T81 (68)
7/17/22 13:38:07z IoTaWatt 5.0, Firmware version 02_07_05
7/17/22 13:38:07z SPIFFS mounted.
7/17/22 15:38:07 Local time zone: +1:00, using DST/BST when in effect.
7/17/22 15:38:07 device name: Iotawatt
7/17/22 15:38:10 Connecting with WiFiManager.
7/17/22 15:40:49 Did not connect after power-fail. Restarting to reset WiFi.
7/17/22 13:40:50z Real Time Clock is running. Unix time 1658065250
7/17/22 13:40:50z Reset reason: Software/System restart
7/17/22 13:40:50z Trace: 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:30[1], 11:30[2], 11:31, 11:31[1], 11:31[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
7/17/22 13:40:50z ESP8266 ID: 480839, RTC M41T81 (68)
7/17/22 13:40:50z IoTaWatt 5.0, Firmware version 02_07_05
7/17/22 13:40:50z SPIFFS mounted.
7/17/22 15:40:50 Local time zone: +1:00, using DST/BST when in effect.
7/17/22 15:40:50 device name: Iotawatt
7/17/22 15:40:50 HTTP server started
7/17/22 15:40:50 timeSync: service started.
7/17/22 15:40:50 statService: started.
7/17/22 15:40:50 dataLog: service started.
7/17/22 15:40:50 dataLog: Last log entry 07/17/22 15:31:50
7/17/22 15:40:55 historyLog: service started.
7/17/22 15:40:55 historyLog: Last log entry 07/17/22 15:31:00
7/17/22 15:40:55 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=1, RSSI -65db
7/17/22 15:40:55 MDNS responder started for hostname Iotawatt
7/17/22 15:40:55 LLMNR responder started for hostname Iotawatt
7/17/22 15:40:55 Updater: service started. Auto-update class is MINOR
7/17/22 15:40:55 Updater: Auto-update is current for class MINOR.
7/18/22 10:33:01 WiFi disconnected.
7/18/22 10:34:55 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -70db
7/21/22 04:49:35 Updater: Invalid response from server. HTTPcode: -4
7/23/22 07:35:42 WiFi disconnected.
7/23/22 07:37:07 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -68db
7/28/22 05:53:58 WiFi disconnected.
7/28/22 05:55:53 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -67db
8/04/22 17:55:41 WiFi disconnected.
8/04/22 17:55:42 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -70db
8/08/22 15:59:17z Real Time Clock is running. Unix time 1659974357
8/08/22 15:59:17z Reset Reason: Power-fail restart.
8/08/22 15:59:17z ESP8266 ID: 480839, RTC M41T81 (68)
8/08/22 15:59:17z IoTaWatt 5.0, Firmware version 02_07_05
8/08/22 15:59:17z SPIFFS mounted.
8/08/22 17:59:17 Local time zone: +1:00, using DST/BST when in effect.
8/08/22 17:59:17 device name: Iotawatt
8/08/22 16:06:52z Real Time Clock is running. Unix time 1659974812
8/08/22 16:06:52z Reset Reason: Power-fail restart.
8/08/22 16:06:52z ESP8266 ID: 480839, RTC M41T81 (68)
8/08/22 16:06:52z IoTaWatt 5.0, Firmware version 02_07_05
8/08/22 16:06:52z SPIFFS mounted.
8/08/22 18:06:52 Local time zone: +1:00, using DST/BST when in effect.
8/08/22 18:06:52 device name: Iotawatt
8/08/22 18:06:55 Connecting with WiFiManager.
8/08/22 18:09:04 Did not connect after power-fail. Restarting to reset WiFi.
8/08/22 16:09:05z Real Time Clock is running. Unix time 1659974945
8/08/22 16:09:05z Reset reason: Software/System restart
8/08/22 16:09:05z Trace: 34:10[10], 34:30, 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
8/08/22 16:09:05z ESP8266 ID: 480839, RTC M41T81 (68)
8/08/22 16:09:05z IoTaWatt 5.0, Firmware version 02_07_05
8/08/22 16:09:05z SPIFFS mounted.
8/08/22 18:09:05 Local time zone: +1:00, using DST/BST when in effect.
8/08/22 18:09:05 device name: Iotawatt
8/08/22 18:09:05 HTTP server started
8/08/22 18:09:05 timeSync: service started.
8/08/22 18:09:05 statService: started.
8/08/22 18:09:05 dataLog: service started.
8/08/22 18:09:05 dataLog: Last log entry 08/08/22 17:59:10
8/08/22 18:09:10 historyLog: service started.
8/08/22 18:09:10 historyLog: Last log entry 08/08/22 17:59:00
8/08/22 18:09:14 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -71db
8/08/22 18:09:14 MDNS responder started for hostname Iotawatt
8/08/22 18:09:14 LLMNR responder started for hostname Iotawatt
8/08/22 18:09:14 Updater: service started. Auto-update class is MINOR
8/08/22 18:09:15 Updater: Auto-update is current for class MINOR.
8/12/22 12:18:48 Updater: Invalid response from server. HTTPcode: -4
8/15/22 15:29:12 WiFi disconnected.
8/15/22 15:29:16 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=1, RSSI -62db
8/16/22 08:18:10z Real Time Clock is running. Unix time 1660637890
8/16/22 08:18:10z Reset Reason: Power-fail restart.
8/16/22 08:18:10z ESP8266 ID: 480839, RTC M41T81 (68)
8/16/22 08:18:10z IoTaWatt 5.0, Firmware version 02_07_05
8/16/22 08:18:10z SPIFFS mounted.
8/16/22 10:18:10 Local time zone: +1:00, using DST/BST when in effect.
8/16/22 10:18:10 device name: Iotawatt
8/16/22 10:18:13 Connecting with WiFiManager.
8/16/22 10:20:22 Did not connect after power-fail. Restarting to reset WiFi.
8/16/22 08:20:23z Real Time Clock is running. Unix time 1660638023
8/16/22 08:20:23z Reset reason: Software/System restart
8/16/22 08:20:23z Trace: 34:10[10], 34:30, 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
8/16/22 08:20:23z ESP8266 ID: 480839, RTC M41T81 (68)
8/16/22 08:20:23z IoTaWatt 5.0, Firmware version 02_07_05
8/16/22 08:20:23z SPIFFS mounted.
8/16/22 10:20:23 Local time zone: +1:00, using DST/BST when in effect.
8/16/22 10:20:23 device name: Iotawatt
8/16/22 10:20:23 HTTP server started
8/16/22 10:20:23 timeSync: service started.
8/16/22 10:20:23 statService: started.
8/16/22 10:20:23 dataLog: service started.
8/16/22 10:20:23 dataLog: Last log entry 08/16/22 03:13:40
8/16/22 10:20:28 historyLog: service started.
8/16/22 10:20:28 historyLog: Last log entry 08/16/22 03:13:00
8/16/22 10:20:31 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -72db
8/16/22 10:20:31 MDNS responder started for hostname Iotawatt
8/16/22 10:20:31 LLMNR responder started for hostname Iotawatt
8/16/22 10:20:31 Updater: service started. Auto-update class is MINOR
8/16/22 10:20:32 Updater: Auto-update is current for class MINOR.
8/16/22 18:07:32 Restart command received.
8/16/22 16:07:33z Real Time Clock is running. Unix time 1660666053
8/16/22 16:07:33z Reset reason: Software/System restart
8/16/22 16:07:33z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
8/16/22 16:07:33z ESP8266 ID: 480839, RTC M41T81 (68)
8/16/22 16:07:33z IoTaWatt 5.0, Firmware version 02_07_05
8/16/22 16:07:33z SPIFFS mounted.
8/16/22 18:07:33 Local time zone: +1:00, using DST/BST when in effect.
8/16/22 18:07:33 device name: Iotawatt
8/16/22 18:07:33 HTTP server started
8/16/22 18:07:33 timeSync: service started.
8/16/22 18:07:33 statService: started.
8/16/22 18:07:33 dataLog: service started.
8/16/22 18:07:33 dataLog: Last log entry 08/16/22 18:07:30
8/16/22 18:07:38 historyLog: service started.
8/16/22 18:07:38 historyLog: Last log entry 08/16/22 18:07:00
8/16/22 18:07:38 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=1, RSSI -65db
8/16/22 18:07:38 MDNS responder started for hostname Iotawatt
8/16/22 18:07:38 LLMNR responder started for hostname Iotawatt
8/16/22 18:07:38 Updater: service started. Auto-update class is MINOR
8/16/22 18:07:39 Updater: Auto-update is current for class MINOR.
8/24/22 11:26:25 Updater: update tables from 0.0.5 to 0.0.6
8/26/22 11:00:20 WiFi disconnected.
8/26/22 11:04:05 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -70db
8/26/22 11:04:29 WiFi disconnected.
8/26/22 11:06:25 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -73db
9/19/22 16:47:40z Real Time Clock is running. Unix time 1663606060
9/19/22 16:47:40z Reset Reason: Power-fail restart.
9/19/22 16:47:40z ESP8266 ID: 480839, RTC M41T81 (68)
9/19/22 16:47:40z IoTaWatt 5.0, Firmware version 02_07_05
9/19/22 16:49:45z Real Time Clock is running. Unix time 1663606185
9/19/22 16:49:45z Reset Reason: Power-fail restart.
9/19/22 16:49:45z ESP8266 ID: 480839, RTC M41T81 (68)
9/19/22 16:49:45z IoTaWatt 5.0, Firmware version 02_07_05
9/19/22 16:49:45z SPIFFS mounted.
9/19/22 18:49:45 Local time zone: +1:00, using DST/BST when in effect.
9/19/22 18:49:45 device name: Iotawatt
9/19/22 18:49:48 Connecting with WiFiManager.
9/19/22 16:50:03z Real Time Clock is running. Unix time 1663606203
9/19/22 16:50:03z Reset Reason: Power-fail restart.
9/19/22 16:50:03z ESP8266 ID: 480839, RTC M41T81 (68)
9/19/22 16:50:03z IoTaWatt 5.0, Firmware version 02_07_05
9/19/22 16:50:03z SPIFFS mounted.
9/19/22 18:50:03 Local time zone: +1:00, using DST/BST when in effect.
9/19/22 18:50:03 device name: Iotawatt
9/19/22 18:50:06 Connecting with WiFiManager.
9/19/22 18:52:15 Did not connect after power-fail. Restarting to reset WiFi.
9/19/22 16:52:16z Real Time Clock is running. Unix time 1663606336
9/19/22 16:52:16z Reset reason: Software/System restart
9/19/22 16:52:16z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
9/19/22 16:52:16z ESP8266 ID: 480839, RTC M41T81 (68)
9/19/22 16:52:16z IoTaWatt 5.0, Firmware version 02_07_05
9/19/22 16:52:16z SPIFFS mounted.
9/19/22 18:52:16 Local time zone: +1:00, using DST/BST when in effect.
9/19/22 18:52:16 device name: Iotawatt
9/19/22 18:52:16 HTTP server started
9/19/22 18:52:16 timeSync: service started.
9/19/22 18:52:16 statService: started.
9/19/22 18:52:16 dataLog: service started.
9/19/22 18:52:16 dataLog: Last log entry 09/19/22 18:46:55
9/19/22 18:52:21 historyLog: service started.
9/19/22 18:52:21 historyLog: Last log entry 09/19/22 18:46:00
9/19/22 17:24:46z Real Time Clock is running. Unix time 1663608286
9/19/22 17:24:46z Reset Reason: Power-fail restart.
9/19/22 17:24:46z ESP8266 ID: 480839, RTC M41T81 (68)
9/19/22 17:24:46z IoTaWatt 5.0, Firmware version 02_07_05
9/19/22 17:24:46z SPIFFS mounted.
9/19/22 19:24:46 Local time zone: +1:00, using DST/BST when in effect.
9/19/22 19:24:46 device name: Iotawatt
9/19/22 19:24:49 Connecting with WiFiManager.
9/19/22 19:26:58 Did not connect after power-fail. Restarting to reset WiFi.
9/19/22 17:26:59z Real Time Clock is running. Unix time 1663608419
9/19/22 17:26:59z Reset reason: Software/System restart
9/19/22 17:26:59z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
9/19/22 17:26:59z ESP8266 ID: 480839, RTC M41T81 (68)
9/19/22 17:26:59z IoTaWatt 5.0, Firmware version 02_07_05
9/19/22 17:26:59z SPIFFS mounted.
9/19/22 19:26:59 Local time zone: +1:00, using DST/BST when in effect.
9/19/22 19:26:59 device name: Iotawatt
9/19/22 19:26:59 HTTP server started
9/19/22 19:26:59 timeSync: service started.
9/19/22 19:26:59 statService: started.
9/19/22 19:26:59 dataLog: service started.
9/19/22 19:26:59 dataLog: Last log entry 09/19/22 19:24:30
9/19/22 19:27:04 historyLog: service started.
9/19/22 19:27:04 historyLog: Last log entry 09/19/22 19:24:00
9/19/22 19:27:04 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -70db
9/19/22 19:27:04 MDNS responder started for hostname Iotawatt
9/19/22 19:27:04 LLMNR responder started for hostname Iotawatt
9/19/22 19:27:04 Updater: service started. Auto-update class is MINOR
9/19/22 19:27:05 Updater: Auto-update is current for class MINOR.
9/22/22 12:02:05 WiFi disconnected.
9/22/22 12:02:10 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=1, RSSI -63db
9/23/22 12:15:10z Real Time Clock is running. Unix time 1663935310
9/23/22 12:15:29z Real Time Clock is running. Unix time 1663935329
9/23/22 12:15:29z Reset Reason: Power-fail restart.
9/23/22 12:15:29z ESP8266 ID: 480839, RTC M41T81 (68)
9/23/22 12:15:29z IoTaWatt 5.0, Firmware version 02_07_05
9/23/22 12:15:29z SPIFFS mounted.
9/23/22 14:15:29 Local time zone: +1:00, using DST/BST when in effect.
9/23/22 14:15:29 device name: Iotawatt
9/23/22 14:15:32 Connecting with WiFiManager.
9/23/22 14:18:37 Did not connect after power-fail. Restarting to reset WiFi.
9/23/22 12:18:38z Real Time Clock is running. Unix time 1663935518
9/23/22 12:18:38z Reset reason: Software/System restart
9/23/22 12:18:38z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
9/23/22 12:18:38z ESP8266 ID: 480839, RTC M41T81 (68)
9/23/22 12:18:38z IoTaWatt 5.0, Firmware version 02_07_05
9/23/22 12:18:38z SPIFFS mounted.
9/23/22 14:18:38 Local time zone: +1:00, using DST/BST when in effect.
9/23/22 14:18:38 device name: Iotawatt
9/23/22 14:18:38 HTTP server started
9/23/22 14:18:38 timeSync: service started.
9/23/22 14:18:38 statService: started.
9/23/22 14:18:38 dataLog: service started.
9/23/22 14:18:38 dataLog: Last log entry 09/23/22 14:13:40
9/23/22 14:18:43 historyLog: service started.
9/23/22 14:18:43 historyLog: Last log entry 09/23/22 14:13:00
9/23/22 14:19:19 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=11, RSSI -73db
9/23/22 14:19:19 MDNS responder started for hostname Iotawatt
9/23/22 14:19:19 LLMNR responder started for hostname Iotawatt
9/23/22 14:19:19 Updater: service started. Auto-update class is MINOR
9/23/22 14:19:36 Updater: Invalid response from server. HTTPcode: -4
9/23/22 15:19:27 Updater: Auto-update is current for class MINOR.
9/23/22 13:56:25z Real Time Clock is running. Unix time 1663941385
9/23/22 13:56:25z Reset Reason: Power-fail restart.
9/23/22 13:56:25z ESP8266 ID: 480839, RTC M41T81 (68)
9/23/22 13:56:25z IoTaWatt 5.0, Firmware version 02_07_05
9/23/22 13:56:25z SPIFFS mounted.
9/23/22 15:56:25 Local time zone: +1:00, using DST/BST when in effect.
9/23/22 15:56:25 device name: Iotawatt
9/23/22 15:56:28 Connecting with WiFiManager.
9/23/22 15:59:12 Did not connect after power-fail. Restarting to reset WiFi.
9/23/22 13:59:14z Real Time Clock is running. Unix time 1663941554
9/23/22 13:59:14z Reset reason: Software/System restart
9/23/22 13:59:14z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
9/23/22 13:59:14z ESP8266 ID: 480839, RTC M41T81 (68)
9/23/22 13:59:14z IoTaWatt 5.0, Firmware version 02_07_05
9/23/22 13:59:14z SPIFFS mounted.
9/23/22 15:59:14 Local time zone: +1:00, using DST/BST when in effect.
9/23/22 15:59:14 device name: Iotawatt
9/23/22 15:59:14 HTTP server started
9/23/22 15:59:14 timeSync: service started.
9/23/22 15:59:14 statService: started.
9/23/22 15:59:14 dataLog: service started.
9/23/22 15:59:14 dataLog: Last log entry 09/23/22 15:56:00
9/23/22 15:59:19 historyLog: service started.
9/23/22 15:59:19 historyLog: Last log entry 09/23/22 15:56:00
9/23/22 15:59:19 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=1, RSSI -61db
9/23/22 15:59:19 MDNS responder started for hostname Iotawatt
9/23/22 15:59:19 LLMNR responder started for hostname Iotawatt
9/23/22 15:59:19 Updater: service started. Auto-update class is MINOR
9/23/22 15:59:21 Updater: Auto-update is current for class MINOR.
9/23/22 14:32:08z Real Time Clock is running. Unix time 1663943528
9/23/22 14:32:08z Reset Reason: Power-fail restart.
9/23/22 14:32:08z ESP8266 ID: 480839, RTC M41T81 (68)
9/23/22 14:32:08z IoTaWatt 5.0, Firmware version 02_07_05
9/23/22 14:32:08z SPIFFS mounted.
9/23/22 16:32:08 Local time zone: +1:00, using DST/BST when in effect.
9/23/22 16:32:08 device name: Iotawatt
9/23/22 16:32:11 Connecting with WiFiManager.
9/23/22 16:34:38 Did not connect after power-fail. Restarting to reset WiFi.
9/23/22 14:34:39z Real Time Clock is running. Unix time 1663943679
9/23/22 14:34:39z Reset reason: Software/System restart
9/23/22 14:34:39z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
9/23/22 14:34:39z ESP8266 ID: 480839, RTC M41T81 (68)
9/23/22 14:34:39z IoTaWatt 5.0, Firmware version 02_07_05
9/23/22 14:34:39z SPIFFS mounted.
9/23/22 16:34:39 Local time zone: +1:00, using DST/BST when in effect.
9/23/22 16:34:39 device name: Iotawatt
9/23/22 16:34:39 HTTP server started
9/23/22 16:34:39 timeSync: service started.
9/23/22 16:34:39 statService: started.
9/23/22 16:34:39 dataLog: service started.
9/23/22 16:34:39 dataLog: Last log entry 09/23/22 16:31:50
9/23/22 16:34:44 historyLog: service started.
9/23/22 16:34:44 historyLog: Last log entry 09/23/22 16:31:00
9/23/22 16:34:44 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=6, RSSI -61db
9/23/22 16:34:44 MDNS responder started for hostname Iotawatt
9/23/22 16:34:44 LLMNR responder started for hostname Iotawatt
9/23/22 16:34:44 Updater: service started. Auto-update class is MINOR
9/23/22 16:34:45 Updater: Auto-update is current for class MINOR.
10/07/22 09:16:49z Real Time Clock is running. Unix time 1665134209
10/07/22 09:16:49z Reset Reason: Power-fail restart.
10/07/22 09:16:49z ESP8266 ID: 480839, RTC M41T81 (68)
10/07/22 09:16:49z IoTaWatt 5.0, Firmware version 02_07_05
10/07/22 09:16:49z SPIFFS mounted.
10/07/22 11:16:49 Local time zone: +1:00, using DST/BST when in effect.
10/07/22 11:16:49 device name: Iotawatt
10/07/22 11:16:52 Connecting with WiFiManager.
10/07/22 11:19:01 Did not connect after power-fail. Restarting to reset WiFi.
10/07/22 09:19:02z Real Time Clock is running. Unix time 1665134342
10/07/22 09:19:02z Reset reason: Software/System restart
10/07/22 09:19:02z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
10/07/22 09:19:02z ESP8266 ID: 480839, RTC M41T81 (68)
10/07/22 09:19:02z IoTaWatt 5.0, Firmware version 02_07_05
10/07/22 09:19:02z SPIFFS mounted.
10/07/22 11:19:02 Local time zone: +1:00, using DST/BST when in effect.
10/07/22 11:19:02 device name: Iotawatt
10/07/22 11:19:02 HTTP server started
10/07/22 11:19:02 timeSync: service started.
10/07/22 11:19:02 statService: started.
10/07/22 11:19:02 dataLog: service started.
10/07/22 11:19:02 dataLog: Last log entry 10/07/22 10:02:40
10/07/22 11:19:07 historyLog: service started.
10/07/22 11:19:07 historyLog: Last log entry 10/07/22 10:02:00
10/07/22 11:19:07 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=6, RSSI -58db
10/07/22 11:19:07 MDNS responder started for hostname Iotawatt
10/07/22 11:19:07 LLMNR responder started for hostname Iotawatt
10/07/22 11:19:07 Updater: service started. Auto-update class is MINOR
10/07/22 11:19:08 Updater: Auto-update is current for class MINOR.
The auto update is MINOR, the wifi connects and the ip is supposed to be 192.168.1.94. I’m also connected to that network, as is every other device in the home. HASS is connected via ethernet, but they are visible to each other.
