Problems started before that. Probably around the 20th of September.
I’ll try unplugging every wifi AP in the home except for the router itself and see if that solves the issue.
Here’s the log for the last restart:
10/07/22 09:19:02z Real Time Clock is running. Unix time 1665134342
10/07/22 09:19:02z Reset reason: Software/System restart
10/07/22 09:19:02z Trace: 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[9], 34:5, 34:5, 34:5, 34:6[11], 34:10[9], 34:30, 34:10[8], 34:30, 34:10[11], 34:30, 34:10[10], 34:30, 34:10[12], 34:30, 34:10[13], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
10/07/22 09:19:02z ESP8266 ID: 480839, RTC M41T81 (68)
10/07/22 09:19:02z IoTaWatt 5.0, Firmware version 02_07_05
10/07/22 09:19:02z SPIFFS mounted.
10/07/22 11:19:02 Local time zone: +1:00, using DST/BST when in effect.
10/07/22 11:19:02 device name: Iotawatt
10/07/22 11:19:02 HTTP server started
10/07/22 11:19:02 timeSync: service started.
10/07/22 11:19:02 statService: started.
10/07/22 11:19:02 dataLog: service started.
10/07/22 11:19:02 dataLog: Last log entry 10/07/22 10:02:40
10/07/22 11:19:07 historyLog: service started.
10/07/22 11:19:07 historyLog: Last log entry 10/07/22 10:02:00
10/07/22 11:19:07 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=6, RSSI -58db
10/07/22 11:19:07 MDNS responder started for hostname Iotawatt
10/07/22 11:19:07 LLMNR responder started for hostname Iotawatt
10/07/22 11:19:07 Updater: service started. Auto-update class is MINOR
10/07/22 11:19:08 Updater: Auto-update is current for class MINOR.
10/13/22 16:16:40z Real Time Clock is running. Unix time 1665677800
10/13/22 16:16:40z Reset Reason: Power-fail restart.
10/13/22 16:16:40z ESP8266 ID: 480839, RTC M41T81 (68)
10/13/22 16:16:40z IoTaWatt 5.0, Firmware version 02_07_05
10/13/22 16:16:40z SPIFFS mounted.
10/13/22 18:16:40 Local time zone: +1:00, using DST/BST when in effect.
10/13/22 18:16:40 device name: Iotawatt
10/13/22 18:16:43 Connecting with WiFiManager.
10/13/22 18:16:47 HTTP server started
10/13/22 18:16:47 WiFi connected. SSID=Guay fai, IP=192.168.1.94, channel=6, RSSI -65db
10/13/22 18:16:47 MDNS responder started for hostname Iotawatt
10/13/22 18:16:47 LLMNR responder started for hostname Iotawatt
10/13/22 18:16:47 timeSync: service started.
10/13/22 18:16:47 statService: started.
10/13/22 18:16:47 Updater: service started. Auto-update class is MINOR
10/13/22 18:16:47 dataLog: service started.
10/13/22 18:16:47 dataLog: Last log entry 10/13/22 17:57:20
10/13/22 18:16:49 Updater: Auto-update is current for class MINOR.
10/13/22 18:16:52 historyLog: service started.
10/13/22 18:16:52 historyLog: Last log entry 10/13/22 17:57:00
10/13/22 21:17:31 Updater: Invalid response from server. HTTPcode: -4
