(2) 100Ax16mm for the 100A panel? Or do I only need 1?
Now - I would prefer to monitor each plug that plugs into each outlet so that I don’t have to isolate each plug per breaker, but not sure that can be done. If not, I guess I have to isolate or buy something else like a PDU.
My equipment is:
(1) 120VAC
(2) 240VAC
That is what I have so far in my panel, but the plan is to expand.
For each 120VAC, do I need a single 50Ax10mm?
For each 240VAC, do I need a single 50Ax10mm as well?
And, then, is there any way to put it around the power cord itself?
No, the CT goes around only one of the conductors, you will get a zero reading around the two conductor cord as the current flows equally in both conductors inside the cord and cancel each other out…
From the picture the 240V loads appear to be two-wire so yes, they can be measured with one CT and the two 120V loads can be measured with 50A CTs. So yes, it appears 4 x 50A CTs will do the trick.
I received everything. The IoTaWatt itself came with the USB power and reference power. The D-Shell on the USB power is too short or the female side is recessed too much to work. If I push with the force of 1000 horses, it will finally turn the light green - but of course when I stop pushing the power turns off once again.
Question: Is it a basic USB d-shell connection that I could use with any other power supply? I would assume any 1 amp micro-usb would be fine.
