Just got it back visibile on the main router, had to block and pause activity on the eero for IoTaWatt plus the two espressif instances.
Here’s the log:
8/25/24 14:41:12 dataLog: Last log entry 08/25/24 14:40:45
8/25/24 14:41:12 Updater: Auto-update is current for class MINOR.
8/25/24 14:41:14 historyLog: service started.
8/25/24 14:41:14 historyLog: Last log entry 08/25/24 14:40:00
8/26/24 14:39:47 WiFi disconnected.
8/26/24 14:40:04 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.1.157, channel=4, RSSI -62db
8/26/24 16:48:44 WiFi disconnected.
8/26/24 16:48:49 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -69db
8/28/24 01:14:58z Real Time Clock is running. Unix time 1724807698
8/28/24 01:14:58z Reset Reason: Power-fail restart.
8/28/24 01:14:58z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/28/24 01:14:58z IoTaWatt 5.0, Firmware version 02_08_03
8/28/24 01:14:58z SPIFFS mounted.
8/27/24 21:14:58 Local time zone: -5:00, using DST/BST when in effect.
8/27/24 21:14:58 device name: IotaWatt
8/27/24 21:15:01 Connecting with WiFiManager.
8/27/24 21:15:06 HTTP server started
8/27/24 21:15:07 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -72db
8/27/24 21:15:07 timeSync: service started.
8/27/24 21:15:07 statService: started.
8/27/24 21:15:07 Updater: service started. Auto-update class is MINOR
8/27/24 21:15:07 dataLog: service started.
8/27/24 21:15:09 dataLog: Last log entry 08/27/24 21:14:45
8/27/24 21:15:09 Updater: Auto-update is current for class MINOR.
8/27/24 21:15:12 historyLog: service started.
8/27/24 21:15:12 historyLog: Last log entry 08/27/24 21:14:00
8/29/24 16:02:30z Real Time Clock is running. Unix time 1724947350
8/29/24 16:02:30z Reset Reason: Power-fail restart.
8/29/24 16:02:30z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 16:02:30z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 16:02:30z SPIFFS mounted.
8/29/24 12:02:30 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 12:02:30 device name: IotaWatt
8/29/24 12:02:33 Connecting with WiFiManager.
8/29/24 12:02:38 HTTP server started
8/29/24 12:02:38 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -69db
8/29/24 12:02:38 timeSync: service started.
8/29/24 12:02:38 statService: started.
8/29/24 12:02:38 Updater: service started. Auto-update class is MINOR
8/29/24 12:02:39 dataLog: service started.
8/29/24 12:02:41 dataLog: Last log entry 08/29/24 12:02:00
8/29/24 12:02:42 Updater: Auto-update is current for class MINOR.
8/29/24 12:02:43 historyLog: service started.
8/29/24 12:02:43 historyLog: Last log entry 08/29/24 12:01:00
8/29/24 17:48:32z Real Time Clock is running. Unix time 1724953712
8/29/24 17:48:32z Reset Reason: Power-fail restart.
8/29/24 17:48:32z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 17:48:32z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 17:48:32z SPIFFS mounted.
8/29/24 13:48:32 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 13:48:32 device name: IotaWatt
8/29/24 13:48:35 Connecting with WiFiManager.
8/29/24 13:48:38 HTTP server started
8/29/24 13:48:38 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -54db
8/29/24 13:48:38 timeSync: service started.
8/29/24 13:48:38 statService: started.
8/29/24 13:48:38 Updater: service started. Auto-update class is MINOR
8/29/24 13:48:38 dataLog: service started.
8/29/24 13:48:42 dataLog: Last log entry 08/29/24 13:48:15
8/29/24 13:48:42 Updater: Auto-update is current for class MINOR.
8/29/24 13:48:43 historyLog: service started.
8/29/24 13:48:43 historyLog: Last log entry 08/29/24 13:48:00
8/29/24 19:30:57z Real Time Clock is running. Unix time 1724959857
8/29/24 19:30:57z Reset Reason: Power-fail restart.
8/29/24 19:30:57z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 19:30:57z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 19:30:57z SPIFFS mounted.
8/29/24 15:30:57 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 15:30:57 device name: IotaWatt
8/29/24 15:31:00 Connecting with WiFiManager.
8/29/24 15:31:03 HTTP server started
8/29/24 15:31:03 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -56db
8/29/24 15:31:04 timeSync: service started.
8/29/24 15:31:04 statService: started.
8/29/24 15:31:04 Updater: service started. Auto-update class is MINOR
8/29/24 15:31:04 dataLog: service started.
8/29/24 15:31:07 dataLog: Last log entry 08/29/24 15:27:00
8/29/24 15:31:08 Updater: Auto-update is current for class MINOR.
8/29/24 15:31:09 historyLog: service started.
8/29/24 15:31:10 historyLog: Last log entry 08/29/24 15:27:00
8/29/24 19:37:58z Real Time Clock is running. Unix time 1724960278
8/29/24 19:37:58z Reset Reason: Power-fail restart.
8/29/24 19:37:58z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 19:37:58z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 19:37:58z SPIFFS mounted.
8/29/24 15:37:58 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 15:37:58 device name: IotaWatt
8/29/24 15:38:01 Connecting with WiFiManager.
8/29/24 15:38:07 HTTP server started
8/29/24 15:38:07 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -56db
8/29/24 15:38:07 timeSync: service started.
8/29/24 15:38:10 statService: started.
8/29/24 15:38:10 Updater: service started. Auto-update class is MINOR
8/29/24 15:38:10 dataLog: service started.
8/29/24 15:38:13 dataLog: Last log entry 08/29/24 15:36:35
8/29/24 15:38:14 Updater: could not parse versions.json file.
8/29/24 15:38:15 historyLog: service started.
8/29/24 15:38:15 historyLog: Last log entry 08/29/24 15:36:00
8/29/24 19:40:11z Real Time Clock is running. Unix time 1724960411
8/29/24 19:40:11z Reset Reason: Power-fail restart.
8/29/24 19:40:11z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 19:40:11z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 19:40:11z SPIFFS mounted.
8/29/24 15:40:11 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 15:40:11 device name: IotaWatt
8/29/24 15:40:14 Connecting with WiFiManager.
8/29/24 15:40:18 HTTP server started
8/29/24 15:40:18 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -55db
8/29/24 15:40:18 timeSync: service started.
8/29/24 15:40:21 statService: started.
8/29/24 15:40:21 Updater: service started. Auto-update class is MINOR
8/29/24 15:40:22 dataLog: service started.
8/29/24 15:40:25 dataLog: Last log entry 08/29/24 15:39:55
8/29/24 15:40:25 Updater: could not parse versions.json file.
8/29/24 15:40:26 historyLog: service started.
8/29/24 15:40:26 historyLog: Last log entry 08/29/24 15:39:00
8/29/24 19:44:08z Real Time Clock is running. Unix time 1724960648
8/29/24 19:44:08z Reset Reason: Power-fail restart.
8/29/24 19:44:08z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 19:44:08z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 19:44:08z SPIFFS mounted.
8/29/24 15:44:08 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 15:44:08 device name: IotaWatt
8/29/24 15:44:11 Connecting with WiFiManager.
8/29/24 15:44:17 HTTP server started
8/29/24 15:44:17 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -56db
8/29/24 15:44:17 timeSync: service started.
8/29/24 15:44:20 statService: started.
8/29/24 15:44:20 Updater: service started. Auto-update class is MINOR
8/29/24 15:44:20 dataLog: service started.
8/29/24 15:44:24 dataLog: Last log entry 08/29/24 15:43:55
8/29/24 15:44:24 Updater: could not parse versions.json file.
8/29/24 15:44:25 historyLog: service started.
8/29/24 15:44:25 historyLog: Last log entry 08/29/24 15:43:00
8/29/24 15:45:02 WiFi disconnected.
8/29/24 15:45:05 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -72db
8/29/24 19:46:34z Real Time Clock is running. Unix time 1724960794
8/29/24 19:46:34z Reset Reason: Power-fail restart.
8/29/24 19:46:34z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 19:46:34z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 19:46:34z SPIFFS mounted.
8/29/24 15:46:34 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 15:46:34 device name: IotaWatt
8/29/24 15:46:37 Connecting with WiFiManager.
8/29/24 15:46:43 HTTP server started
8/29/24 15:46:43 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.4.90, channel=6, RSSI -72db
8/29/24 15:46:43 timeSync: service started.
8/29/24 15:46:46 statService: started.
8/29/24 15:46:46 Updater: service started. Auto-update class is MINOR
8/29/24 15:46:46 dataLog: service started.
8/29/24 15:46:50 dataLog: Last log entry 08/29/24 15:46:05
8/29/24 15:46:50 Updater: could not parse versions.json file.
8/29/24 15:46:51 historyLog: service started.
8/29/24 15:46:51 historyLog: Last log entry 08/29/24 15:46:00
8/29/24 19:53:34z Real Time Clock is running. Unix time 1724961214
8/29/24 19:53:34z Reset Reason: Power-fail restart.
8/29/24 19:53:34z ESP8266 ID: 12687021, RTC PCF8523 (68)
8/29/24 19:53:34z IoTaWatt 5.0, Firmware version 02_08_03
8/29/24 19:53:34z SPIFFS mounted.
8/29/24 15:53:34 Local time zone: -5:00, using DST/BST when in effect.
8/29/24 15:53:34 device name: IotaWatt
8/29/24 15:53:37 Connecting with WiFiManager.
8/29/24 15:53:43 HTTP server started
8/29/24 15:53:43 WiFi connected. SSID=HappyHoundBrewing, IP=192.168.1.157, channel=2, RSSI -72db
8/29/24 15:53:43 timeSync: service started.
8/29/24 15:53:44 statService: started.
8/29/24 15:53:44 Updater: service started. Auto-update class is MINOR
8/29/24 15:53:45 Updater: Auto-update is current for class MINOR.
8/29/24 15:53:45 dataLog: service started.
8/29/24 15:53:48 dataLog: Last log entry 08/29/24 15:53:15
8/29/24 15:53:49 historyLog: service started.
8/29/24 15:53:49 historyLog: Last log entry 08/29/24 15:53:00
