I can’t connect to the iotawatt via browser again (site can’t be reached), and ping shows “host unreachable”. This may have happened after recent power failures, but has happened before. I may be able to recover by rebooting router as I have before, but that causes a lot of issues on my network and I’d rather avoid that.
I did power cycle the iotawatt, but problem continues. The LED is pulsing green, which I believe means iotawatt is connected and has updated time from internet. The router shows an active WiFi connection to the proper manually assigned IP address, both before and after power cycle. However the router log is filled with a repeating sequence of entries like this:
Sep 2 10:15:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:15:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Sep 2 10:16:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:16:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Sep 2 10:17:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:17:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Sep 2 10:18:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:18:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Sep 2 10:19:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:19:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Sep 2 10:20:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:20:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Sep 2 10:21:42 dnsmasq-dhcp[1290]: DHCPDISCOVER(br0) 5c:cf:7f:69:72:e7
Sep 2 10:21:42 dnsmasq-dhcp[1290]: DHCPOFFER(br0) 192.168.1.66 5c:cf:7f:69:72:e7
Which I believe means the iotawatt is asking for an IP address, the router is offering one, but iotawatt never accepts it, just tries over and over.
What would anyone suggest as a next step?
Thanks!
