I have 2x iotawatt’s and one just dropped off the emoncms monitoring. I rebooted it but nothing
change and then realised its wifi was very intermittent. I removed it and relocated to a better reception area but no change. Seems the wifi module is kaput?
On boot its solid green then flashes a little then blanks and goes flashes red then repeats. The blue leds on wifi module seem to stop then the red comes on? Easier to watch than describe
There is a problem that is unique to Australia. It involves the unit attempting to upgrade to a new release but timing out the release download - over and over again. This doesn’t happen elsewhere. I suspect it has to do with deliberately degraded internet speed, but I have no evidence to back that up.
Not sure what “deliberately degraded internet speed” means but I am on a business grade 200MB fibre link thats very fast and stable. Its been running fine for a bit over a year then stopped 23-Mar.
Like I said, I have no evidence, but that’s the date the release was changed and others, with good internet, have had the same proble. Only in Australia. I haven’t tried to nail it down to ISP.
I have temporarily changed the release version file. Has the problem stopped?
I removed the SDcard and put it into my adapter/Mac but it doesn’t open so I think its failed maybe. I have a brand new SDcard and it works. Can I load the system onto it??
If you leave off the config.txt, the system should start with the led sequence G_R_R_R indicating no config file. You should be able to access the unit and run the file manager. There is a copy of the last good config file in the ESP8266 SPIFFS file system and you should be able to see it in the directory esp_spiffs. Download it and then upload it to the SD root.
