Now it seems like loading the http site takes a very long time.
Here are the logs; I changed the update settings from Alpha to Major to make sure it wasn’t some update that applied the ip change.
1/03/23 19:55:21 Updater: update tables from 0.0.6 to 0.0.7
1/03/23 20:55:27 Updater: update tables from 0.0.6 to 0.0.7
1/03/23 21:55:30 Updater: update tables from 0.0.6 to 0.0.7
1/03/23 22:55:33 Updater: update tables from 0.0.6 to 0.0.7
1/03/23 23:55:41 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 00:55:48 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 01:55:56 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 02:55:57 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 03:56:03 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 04:56:08 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 05:56:16 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 06:56:20 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 07:56:25 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 08:56:33 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 09:56:41 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 10:56:43 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 11:56:49 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 12:56:57 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 13:56:59 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 14:57:07 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 15:57:13 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 16:57:16 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 17:57:22 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 18:57:28 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 19:57:34 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 20:57:40 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 21:57:46 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 22:57:52 Updater: update tables from 0.0.6 to 0.0.7
1/04/23 23:57:58 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 00:58:04 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 01:58:10 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 02:58:16 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 03:58:22 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 04:58:28 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 05:58:34 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 06:58:41 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 07:58:47 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 08:58:53 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 09:58:59 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 10:59:05 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 11:59:11 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 12:53:08 WiFi disconnected.
1/05/23 12:59:34 WiFi connected. SSID=BELL939, IP=192.168.2.27, channel=1, RSSI -51db
1/05/23 12:59:36 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 13:59:42 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 14:59:49 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 15:59:55 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 17:00:01 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 18:00:08 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 19:00:14 Updater: update tables from 0.0.6 to 0.0.7
1/05/23 20:00:20 Updater: update tables from 0.0.6 to 0.0.7
1/07/23 13:26:20z Real Time Clock is running. Unix time 1673097980
1/07/23 13:26:20z Reset reason: Exception
1/07/23 13:26:20z Trace: 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:2, 21:2
1/07/23 13:26:20z ESP8266 ID: 504037, RTC M41T81 (68)
1/07/23 13:26:20z IoTaWatt 5.0, Firmware version 02_08_01
1/07/23 13:26:20z SPIFFS mounted.
1/07/23 08:26:20 Local time zone: -5:00, using DST/BST when in effect.
1/07/23 08:26:20 device name: energy
1/07/23 08:26:20 HTTP server started
1/07/23 08:26:20 influxDB_v2: Starting, interval:10, url:http://192.168.2.202:8086
1/07/23 08:26:20 timeSync: service started.
1/07/23 08:26:20 statService: started.
1/07/23 08:26:20 dataLog: service started.
1/07/23 08:26:22 dataLog: Last log entry 01/07/23 08:26:10
1/07/23 08:26:25 historyLog: service started.
1/07/23 08:26:25 historyLog: Last log entry 01/07/23 08:26:00
1/07/23 08:30:56 WiFi connected. SSID=BELL939, IP=169.254.230.176, channel=1, RSSI -51db
1/07/23 08:30:56 Updater: service started. Auto-update class is ALPHA
1/07/23 11:49:48 Restart command received.
1/07/23 16:49:50z Real Time Clock is running. Unix time 1673110190
1/07/23 16:49:50z Reset reason: Software/System restart
1/07/23 16:49:50z Trace: 31:1, 1:6[6], 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 10:2, 10:3
1/07/23 16:49:50z ESP8266 ID: 504037, RTC M41T81 (68)
1/07/23 16:49:50z IoTaWatt 5.0, Firmware version 02_08_01
1/07/23 16:49:50z SPIFFS mounted.
1/07/23 11:49:50 Local time zone: -5:00, using DST/BST when in effect.
1/07/23 11:49:50 device name: energy
1/07/23 11:49:50 HTTP server started
1/07/23 11:49:50 influxDB_v2: Starting, interval:10, url:http://192.168.2.202:8086
1/07/23 11:49:50 timeSync: service started.
1/07/23 11:49:50 statService: started.
1/07/23 11:49:50 dataLog: service started.
1/07/23 11:49:51 dataLog: Last log entry 01/07/23 11:49:45
1/07/23 11:49:55 historyLog: service started.
1/07/23 11:49:55 historyLog: Last log entry 01/07/23 11:49:00
1/07/23 11:54:01 WiFi connected. SSID=BELL939, IP=169.254.230.176, channel=1, RSSI -52db
1/07/23 11:54:01 Updater: service started. Auto-update class is ALPHA
1/07/23 12:03:43 WiFi disconnected.
1/07/23 12:03:51 WiFi connected. SSID=BELL939, IP=169.254.230.176, channel=6, RSSI -81db
1/07/23 17:04:08z Real Time Clock is running. Unix time 1673111048
1/07/23 17:04:08z Reset Reason: Power-fail restart.
1/07/23 17:04:08z ESP8266 ID: 504037, RTC M41T81 (68)
1/07/23 17:04:08z IoTaWatt 5.0, Firmware version 02_08_01
1/07/23 17:04:08z SPIFFS mounted.
1/07/23 12:04:08 Local time zone: -5:00, using DST/BST when in effect.
1/07/23 12:04:08 device name: energy
1/07/23 12:04:11 Connecting with WiFiManager.
1/07/23 17:07:50z Real Time Clock is running. Unix time 1673111270
1/07/23 17:07:50z Reset Reason: Power-fail restart.
1/07/23 17:07:50z ESP8266 ID: 504037, RTC M41T81 (68)
1/07/23 17:07:50z IoTaWatt 5.0, Firmware version 02_08_01
1/07/23 17:07:50z SPIFFS mounted.
1/07/23 12:07:50 Local time zone: -5:00, using DST/BST when in effect.
1/07/23 12:07:50 device name: energy
1/07/23 12:07:53 HTTP server started
1/07/23 12:07:53 influxDB_v2: Starting, interval:10, url:http://192.168.2.202:8086
1/07/23 12:07:53 WiFi connected. SSID=BELL939, IP=192.168.2.27, channel=1, RSSI -56db
1/07/23 12:07:53 timeSync: service started.
1/07/23 12:07:53 statService: started.
1/07/23 12:07:53 Updater: service started. Auto-update class is MAJOR
1/07/23 12:07:53 dataLog: service started.
1/07/23 12:07:54 dataLog: Last log entry 01/07/23 12:04:00
1/07/23 12:07:56 Updater: Update from 02_08_01 to 02_07_05
1/07/23 12:07:56 Updater: download 02_07_05
1/07/23 12:08:04 Updater: Release downloaded 8307ms, size 951104
1/07/23 12:08:04 influxDB_v2: Resume posting 01/07/23 08:26:00
1/07/23 12:08:04 historyLog: service started.
1/07/23 12:08:05 historyLog: Last log entry 01/07/23 12:04:00
1/07/23 12:08:17 Updater: signature verified
1/07/23 12:08:26 Updater: firmware upgraded to version 02_07_05
1/07/23 12:08:26 Updater: Firmware updated, restarting.
1/07/23 17:08:36z Real Time Clock is running. Unix time 1673111316
1/07/23 17:08:36z Reset reason: Software/System restart
1/07/23 17:08:36z Trace: 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[8], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
1/07/23 17:08:36z ESP8266 ID: 504037, RTC M41T81 (68)
1/07/23 17:08:36z IoTaWatt 5.0, Firmware version 02_07_05
1/07/23 17:08:36z Updater: Installing update files for version 02_07_05
1/07/23 17:08:36z Updater: Installing GRAPH.HTM
1/07/23 17:08:36z Updater: Installing GRAPH.JS
1/07/23 17:08:36z Updater: Installing GRAPH2.HTM
1/07/23 17:08:37z Updater: Installing GRAPH2.JS
1/07/23 17:08:37z Updater: Installing INDEX.HTM
1/07/23 17:08:39z Updater: Installing TABLES.TXT
1/07/23 17:08:39z Updater: Installing CNFSTYLE.CSS
1/07/23 17:08:39z Updater: Installing EDIT.HTM
1/07/23 17:08:39z Updater: Installing FAVICON.ICO
1/07/23 17:08:40z Updater: Installation complete.
1/07/23 17:08:40z SPIFFS mounted.
1/07/23 12:08:40 Local time zone: -5:00, using DST/BST when in effect.
1/07/23 12:08:40 device name: energy
1/07/23 12:08:40 HTTP server started
1/07/23 12:08:40 influxDB_v2: Starting, interval:10, url:http://192.168.2.202:8086
1/07/23 12:08:40 timeSync: service started.
1/07/23 12:08:40 statService: started.
1/07/23 12:08:41 dataLog: service started.
1/07/23 12:08:41 dataLog: Last log entry 01/07/23 12:08:05
1/07/23 12:08:45 Updater: service started. Auto-update class is MAJOR
1/07/23 12:08:45 WiFi connected. SSID=BELL939, IP=192.168.2.27, channel=1, RSSI -55db
1/07/23 12:08:45 MDNS responder started for hostname energy
1/07/23 12:08:45 LLMNR responder started for hostname energy
1/07/23 12:08:45 influxDB_v2: Resume posting 01/07/23 08:26:00
1/07/23 12:08:46 historyLog: service started.
1/07/23 12:08:46 historyLog: Last log entry 01/07/23 12:04:00
1/07/23 12:08:47 Updater: Auto-update is current for class MAJOR.
1/07/23 12:08:47 Updater: update tables from 0.0.4 to 0.0.7
1/07/23 12:16:21 WiFi disconnected.
1/07/23 12:19:27 WiFi connected. SSID=BELL939, IP=192.168.2.27, channel=11, RSSI -81db
1/07/23 12:26:51 WiFi disconnected.
1/07/23 12:26:52 WiFi connected. SSID=BELL939, IP=192.168.2.27, channel=11, RSSI -82db
the 2 last disconnected are from a router restart
