Seeing issues here with WIFI staying connected. If I rebooted the device around 7:45pm 10-3-2021, it works for a while then drops.
Firmware Version: 02_06_05
RSSi = -66
Message log looks like it is not reporting anything current:
10/03/21 13:31:26 historyLog: service started.
10/03/21 13:31:27 historyLog: Last log entry 10/03/21 13:24:00
10/03/21 13:31:28 Updater: Auto-update is current for class MINOR.
10/03/21 18:40:12z Real Time Clock is running. Unix time 1633286412
10/03/21 18:40:12z Reset reason: Software/System restart
10/03/21 18:40:12z Trace: 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:18, 25:19
10/03/21 18:40:12z ESP8266 ChipID: 6347133
10/03/21 18:40:12z IoTaWatt 5.0, Firmware version 02_06_05
10/03/21 18:40:12z SPIFFS mounted.
10/03/21 13:40:12 Local time zone: -6:00
10/03/21 13:40:12 Using Daylight Saving Time (BST) when in effect.
10/03/21 13:40:12 device name: IotaWatt
10/03/21 13:40:12 HTTP server started
10/03/21 13:40:12 timeSync: service started.
10/03/21 13:40:12 statService: started.
10/03/21 13:40:12 dataLog: service started.
10/03/21 13:40:13 dataLog: Last log entry 10/03/21 13:34:05
10/03/21 13:40:16 WiFi connected. SSID=CurtisZM5G, IP=192.168.1.16, channel=3, RSSI -61db
10/03/21 13:40:16 MDNS responder started for hostname IotaWatt
10/03/21 13:40:16 LLMNR responder started for hostname IotaWatt
10/03/21 13:40:16 Updater: service started. Auto-update class is MINOR
10/03/21 13:40:17 historyLog: service started.
10/03/21 13:40:17 historyLog: Last log entry 10/03/21 13:34:00
10/03/21 13:40:17 Updater: Auto-update is current for class MINOR.
10/03/21 18:47:26z Real Time Clock is running. Unix time 1633286846
10/03/21 18:47:26z Reset reason: Software/System restart
10/03/21 18:47:26z Trace: 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:18, 25:19
10/03/21 18:47:26z ESP8266 ChipID: 6347133
10/03/21 18:47:26z IoTaWatt 5.0, Firmware version 02_06_05
10/03/21 18:47:26z SPIFFS mounted.
10/03/21 13:47:26 Local time zone: -6:00
10/03/21 13:47:26 Using Daylight Saving Time (BST) when in effect.
10/03/21 13:47:26 device name: IotaWatt
10/03/21 13:47:26 HTTP server started
10/03/21 13:47:26 timeSync: service started.
10/03/21 13:47:26 statService: started.
10/03/21 13:47:26 dataLog: service started.
10/03/21 13:47:28 dataLog: Last log entry 10/03/21 13:41:55
10/03/21 19:03:18z Real Time Clock is running. Unix time 1633287798
10/03/21 19:03:18z Reset reason: Software/System restart
10/03/21 19:03:18z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
10/03/21 19:03:18z ESP8266 ChipID: 6347133
10/03/21 19:03:18z IoTaWatt 5.0, Firmware version 02_06_05
10/03/21 19:03:18z SPIFFS mounted.
10/03/21 14:03:18 Local time zone: -6:00
10/03/21 14:03:18 Using Daylight Saving Time (BST) when in effect.
10/03/21 14:03:18 device name: IotaWatt
10/03/21 14:03:18 HTTP server started
10/03/21 14:03:18 timeSync: service started.
10/03/21 14:03:18 statService: started.
10/03/21 14:03:18 dataLog: service started.
10/03/21 14:03:19 dataLog: Last log entry 10/03/21 13:46:15
10/03/21 14:03:23 historyLog: service started.
10/03/21 14:03:23 historyLog: Last log entry 10/03/21 13:41:00
10/03/21 14:03:25 WiFi connected. SSID=CurtisZM5G, IP=192.168.1.16, channel=3, RSSI -63db
10/03/21 14:03:25 MDNS responder started for hostname IotaWatt
10/03/21 14:03:25 LLMNR responder started for hostname IotaWatt
10/03/21 14:03:25 Updater: service started. Auto-update class is MINOR
10/03/21 14:03:26 Updater: Auto-update is current for class MINOR.
10/03/21 19:10:21z Real Time Clock is running. Unix time 1633288221
10/03/21 19:10:21z Reset reason: Software/System restart
10/03/21 19:10:21z Trace: 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:18, 25:19
10/03/21 19:10:21z ESP8266 ChipID: 6347133
10/03/21 19:10:21z IoTaWatt 5.0, Firmware version 02_06_05
10/03/21 19:10:21z SPIFFS mounted.
10/03/21 14:10:21 Local time zone: -6:00
10/03/21 14:10:21 Using Daylight Saving Time (BST) when in effect.
10/03/21 14:10:21 device name: IotaWatt
10/03/21 14:10:21 HTTP server started
10/03/21 14:10:21 timeSync: service started.
10/03/21 14:10:21 statService: started.
10/03/21 14:10:21 dataLog: service started.
10/03/21 14:10:22 dataLog: Last log entry 10/03/21 14:04:50
10/03/21 14:10:26 historyLog: service started.
10/03/21 14:10:26 historyLog: Last log entry 10/03/21 14:04:00
10/03/21 14:10:26 WiFi connected. SSID=CurtisZM5G, IP=192.168.1.16, channel=3, RSSI -64db
10/03/21 14:10:26 MDNS responder started for hostname IotaWatt
10/03/21 14:10:26 LLMNR responder started for hostname IotaWatt
10/03/21 14:10:26 Updater: service started. Auto-update class is MINOR
10/03/21 14:10:28 Updater: Auto-update is current for class MINOR.
10/03/21 19:29:06z Real Time Clock is running. Unix time 1633289346
10/03/21 19:29:06z Reset reason: Software/System restart
10/03/21 19:29:06z Trace: 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:13, 25:13, 25:14, 25:17, 25:18, 25:19
10/03/21 19:29:06z ESP8266 ChipID: 6347133
10/03/21 19:29:06z IoTaWatt 5.0, Firmware version 02_06_05
10/03/21 19:29:06z SPIFFS mounted.
10/03/21 14:29:06 Local time zone: -6:00
10/03/21 14:29:06 Using Daylight Saving Time (BST) when in effect.
10/03/21 14:29:06 device name: IotaWatt
10/03/21 14:29:06 HTTP server started
10/03/21 14:29:06 timeSync: service started.
10/03/21 14:29:06 statService: started.
10/03/21 14:29:06 dataLog: service started.
10/03/21 14:29:07 dataLog: Last log entry 10/03/21 14:22:10
10/03/21 19:35:06z Real Time Clock is running. Unix time 1633289706
10/03/21 19:35:06z Reset reason: Software/System restart
10/03/21 19:35:06z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
10/03/21 19:35:06z ESP8266 ChipID: 6347133
10/03/21 19:35:06z IoTaWatt 5.0, Firmware version 02_06_05
10/03/21 19:35:06z SPIFFS mounted.
10/03/21 14:35:06 Local time zone: -6:00
10/03/21 14:35:06 Using Daylight Saving Time (BST) when in effect.
10/03/21 14:35:06 device name: IotaWatt
10/03/21 14:35:06 HTTP server started
10/04/21 00:34:32z Real Time Clock is running. Unix time 1633307672
10/04/21 00:34:32z Power failure detected.
10/04/21 00:34:32z Reset reason: External System
10/04/21 00:34:32z ESP8266 ChipID: 6347133
10/04/21 00:34:32z IoTaWatt 5.0, Firmware version 02_06_05
10/04/21 00:34:32z SPIFFS mounted.
10/03/21 19:34:32 Local time zone: -6:00
10/03/21 19:34:32 Using Daylight Saving Time (BST) when in effect.
10/03/21 19:34:32 device name: IotaWatt
10/03/21 19:34:35 Connecting with WiFiManager.
10/03/21 19:34:40 HTTP server started
10/03/21 19:34:40 WiFi connected. SSID=CurtisZM5G, IP=192.168.1.16, channel=3, RSSI -63db
10/03/21 19:34:40 MDNS responder started for hostname IotaWatt
10/03/21 19:34:40 LLMNR responder started for hostname IotaWatt
10/03/21 19:34:40 timeSync: service started.
10/03/21 19:34:40 statService: started.
10/03/21 19:34:40 Updater: service started. Auto-update class is MINOR
10/03/21 19:34:40 dataLog: service started.
10/03/21 19:34:42 dataLog: Last log entry 10/03/21 14:27:10
10/03/21 19:34:42 Updater: Auto-update is current for class MINOR.
10/03/21 19:34:45 historyLog: service started.
10/03/21 19:34:45 historyLog: Last log entry 10/03/21 14:22:00
10/04/21 00:36:50z Real Time Clock is running. Unix time 1633307810
10/04/21 00:36:50z Power failure detected.
10/04/21 00:36:50z Reset reason: External System
10/04/21 00:36:50z ESP8266 ChipID: 6347133
10/04/21 00:36:50z IoTaWatt 5.0, Firmware version 02_06_05
10/04/21 00:36:50z SPIFFS mounted.
10/03/21 19:36:50 Local time zone: -6:00
10/03/21 19:36:50 Using Daylight Saving Time (BST) when in effect.
10/03/21 19:36:50 device name: IotaWatt
10/03/21 19:36:53 Connecting with WiFiManager.
10/04/21 00:36:57z Real Time Clock is running. Unix time 1633307817
10/04/21 00:36:57z Power failure detected.
10/04/21 00:36:57z Reset reason: External System
10/04/21 00:36:57z ESP8266 ChipID: 6347133
10/04/21 00:36:57z IoTaWatt 5.0, Firmware version 02_06_05
10/04/21 00:36:57z SPIFFS mounted.
10/03/21 19:36:57 Local time zone: -6:00
10/03/21 19:36:57 Using Daylight Saving Time (BST) when in effect.
10/03/21 19:36:57 device name: IotaWatt
10/03/21 19:37:00 Connecting with WiFiManager.
10/03/21 19:37:05 HTTP server started
10/03/21 19:37:05 WiFi connected. SSID=CurtisZM5G, IP=192.168.1.16, channel=3, RSSI -64db
10/03/21 19:37:05 MDNS responder started for hostname IotaWatt
10/03/21 19:37:05 LLMNR responder started for hostname IotaWatt
10/03/21 19:37:05 timeSync: service started.
10/03/21 19:37:05 statService: started.
10/03/21 19:37:05 Updater: service started. Auto-update class is MINOR
10/03/21 19:37:05 dataLog: service started.
10/03/21 19:37:06 dataLog: Last log entry 10/03/21 19:36:45
10/03/21 19:37:06 Updater: Auto-update is current for class MINOR.
10/03/21 19:37:10 historyLog: service started.
10/03/21 19:37:10 historyLog: Last log entry 10/03/21 19:36:00
